Help with Asus Zenbook 14 UM433D main board
  • alltvrepairs
    • Jan 2014
    • 252
    • Malta
    I have been donated this Notebook. The battery connector was broken by owner. I have tried to resolder direclty to main board worked fine but accidentally a piece of copper fall on the board near the supply charging connector and switched off. Tried with the multimeter for possible shorts or evident damage but could not find any obvious.
    Any help pls or someone having a replacement main board at a reasonable price?
    Tks
    Last edited by SMDFlea; 07-20-2023, 07:31 AM. Reason: Removed " and/or schematics" from thread title
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Help with Asus Zenbook 14 UM433D main board and/or schematics
    I would suggest to put high definition pictures with the resistance to ground on all coils and also resistance from current sensor to ground. If you not have auto range multimeter put the meter on resistance 200 ohm. If you have no reading just write OL.
    Resistance is measured with no power , no battery , no memory .
    Good luck
    Regards
      • 21932
      Tks
      Edited the thread title and removed "and/or schematics" as you alredy posted a request https://www.badcaps.net/forum/showpo...71&postcount=7
      Laptop repairs go in this section.Are you wanting to try and repair it or not ? .If all you want to do is buy a new board then please post in the "Looking To Buy" forum, Vesko has posted the link. If you want help post pictures of the area where the copper fell,and post your measurement as asked for at post #2.
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ejs101084
        Need Asus Zenbook 14 Q425m Main Board # UX3405MA Schematic or boardview
        by ejs101084
        Can someone submit board view and or schematics for
        Motherboard Part# UX3405MA
        08-13-2024, 04:00 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
