A2141 - 5V/0A - liquid damage
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    I have Macbook A2141 with minor liquid damage. I already cleaned PCB and done some measurements.
    I noticed that PPBUS_G3H is missing. So I removed F7000 and F7001.
    There is 12.25V on PPVBAT_G3H_CHGR_REG
    PPBUS_G3H > ground is about 1Ω. So, there is a short.
    I didn't find much informations about this model.
    Could someone help me, what to check next?
    Marty
  • mon2
    • 13994
    Re: A2141 - 5V/0A - liquid damage
    Which side of PPBUS_G3H is with the low resistance?
    Is it the producer side (ISL) or the consumer side?
    Post the details of the pin # of the removed fuse pcb pad for this measurement.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      Hello, thanks for reply
      On F7000 pin #1 there is 12.25V
      On F7000 pin #2 there is 0V (shorted-1Ω to ground)
      On F7001 pin #1 there is 12.25V
      On F7001 pin #2 there is 0V (shorted-1Ω to ground)
      • mon2
        • 13994
        It is possible that you have a shorted high side mosfet on the CPU rail.
        Measure the resistance between F7000/F7001 pin #2 (either is ok) and the Vcore rail that powers the CPU.
        That is, the PPBUS_G3H is considered the high voltage to power the logic board. The Vcore voltage is built upon a high and low side mosfet that switch on/off to dial down the high voltage to a much lower safe voltage for the CPU.
        If the high side mosfet is leaky, the CPU will be damaged.
        Post the measurement. The next logic step is use a DC lab power supply to dial up 1 volt and inject this voltage onto the same low resistance side of the fuses. Then monitor the current draw and also which component(s) heat up. The CPU can be confirmed if the heat sink is removed.
        The general rule is to keep the voltage for injection to a low value to protect the CPU - in case it is still alive.
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          It's from F7000/F7001 pin #2 > PPVCC_S0_CPU
          • martyjelen
            • Mar 2023
            • 127
            • Czech republic
            So, does it mean CPU is burned?
            • mon2
              • 13994
              I think you are ok here but best to check against a known good board.
              Reference:
              https://boards.rossmanngroup.com/thr...-ground.37575/
              Would you have an adjustable power supply?
              Dual it to 1 volt. Red power supply probe on the ppbus_g3h line with the short. Black power lead to ground.
              With this setup; no other power adapter or battery; who is heating up? Is it the CPU or some capacitor?
              • martyjelen
                • Mar 2023
                • 127
                • Czech republic
                I don't have much to lose with this case. I dialed up 1V to ppbus_g3h. Nothing seems to get hot.
                • mon2
                  • 13994
                  What is the current draw on your power supply during this injection? Is the heatsink on or off the CPU?
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    Current draw is about 750mA. Heatsink is on, but I check PCB with thermal camera, so I think it should be visible, if something is wrong with CPU or am I wrong?
                    • mon2
                      • 13994
                      Is the power supply being current limited to 750 mA? Can it support higher current?
                      • martyjelen
                        • Mar 2023
                        • 127
                        • Czech republic
                        I set limit to 5A. Current draw is still 750mA.
                        • mon2
                          • 13994
                          While injecting this 1 volt from your dc power supply, measure the voltage to ground at PPVCC_S0_CPU. Do you see a voltage reading?
                          • martyjelen
                            • Mar 2023
                            • 127
                            • Czech republic
                            There is nothing. 0V.
                            • mon2
                              • 13994
                              Review the resistance to ground of L9581 and L9081 as noted here:
                              https://repair.wiki/w/A2141_2019_16%22_MacBook_Pro
                              • martyjelen
                                • Mar 2023
                                • 127
                                • Czech republic
                                Seems OK, there is more than 1k ohms.
                                • mon2
                                  • 13994
                                  Is your meter auto ranging or manual select for the resistance scales?
                                  Can you post a pic of the meter face while taking this 1 ohm reading?
                                  Suspecting that perhaps the meter is stating the resistance is higher than the selected scale with the "1" = over limit. So you need to use the next higher meter scale till you have a valid measurement.
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    I can select ranges. Did you mean that 1ohm reading from PPBUS_G3H > ground?
                                    If I change range to kΩ, it shows 0,001kΩ
                                    • martyjelen
                                      • Mar 2023
                                      • 127
                                      • Czech republic
                                      So, it really reads 0,9Ω-1Ω from PPBUS_G3H > ground.
                                      • mon2
                                        • 13994
                                        Short your meter probes. What is the resistance?
                                        • mon2
                                          A1466 Macbook Air (Liquid damage repair)
                                          by mon2
                                          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                          Macbook AIR Model A1466 Diagnostic 09-01-2021
                                          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                          Problems & Resolutions
                                          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                          09-01-2021, 09:31 AM
                                        • rilley
                                          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                          by rilley
                                          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                          And the resistor L4004 is literally burned.
                                          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                          07-10-2024, 01:57 AM
                                        • Jenzo
                                          MacBook A1989 overheating after liquid damage
                                          by Jenzo
                                          Hey everyone,
                                          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                                          I can't figure out how...
                                          05-13-2023, 07:58 AM
                                        • mitchw
                                          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                          by mitchw
                                          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                          I quickly took it apart and washed the liquid residue off the mainboard.
                                          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                          Now the laptop...
                                          07-16-2025, 07:55 AM
                                        • larrysito111
                                          dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                                          by larrysito111
                                          got here a liquid damaged alienware
                                          the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                                          so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                                          so with the usb-c external monitor is getting to bios and OS
                                          otherwise not
                                          so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                                          but still not the internal monitor
                                          (tested 3V and 5V going to the...
                                          06-12-2025, 04:16 PM
