HP Probook 470 G4 - Power and Charging Problem
  • Sephir0th
    • Oct 2020
    • 1262
    Re: HP Probook 470 G4 - Power and Charging Problem
    This result means you have to remove the heatsink and raise voltage to 2Volts. I'm sure you'll feel something after a while.
    FairRepair on YouTube
    • Scoff
      • Jul 2017
      • 101
      • Uk
      #42
      OK thanks. I've removed the heatsink, increased the voltage to 2v and yes, the PCH area does start to get a little warm, up to around 39 degrees. The amps draw goes up to 1.80 Amps and fluctuates around there. No more hissing noise from the power supply this time.
      Does this confirm game over for this particular board? If so that's a shame, being my first ever attempt, however I know a fair bit more about laptop boards in general and their workings, than I did when I started - so not a total loss. Perhaps a tricky board to start off with, or maybe there was somehow an error on my part while troubleshooting. Perhaps there was an issue with the 19v power rail initially, which replacement of the mosfet corrected, but there were other faults beyond this.
      I want to say thanks to everyone that contributed to this thread - it was a bit help in getting to this point.
      • Sephir0th
        • Oct 2020
        • 1262
        Yes it is the end of the attempt. At least for technicians without experience in BGA replacing and without decent tools.
        In reality all the Youtube nonsense and scam about the "easy repairs" does not work anymore more most of the time. As already shared, the sad reality is, a dead BGA is one of the most common outcomes which you always need to have in your mind. Often also very hard to diagnose, because a BGA can fail without obvious signs like a shorted Power rail. The diagnostics part can be way worse
        I can't tell exactly but if I remember correct it needed 10 chip-level attempts to my first successful repair.
        So this is normal. If you have to spend your own money then you have to expect to loose it with your first attempts. So regarding this, think about how much money you want to spent, what sort of devices you want to source.
        Unfortunately, remotely it is impossible to tell whether you did something wrong or not. You need to find out by yourself.
        Personally I do always advise to check the whole board like explained before for other issues before starting with the "real"work, otherwise you'll not only loose money but also time.
        Regards
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • cope
          Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
          by cope
          I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
          Some history:
          Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
          As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
          Now, with a new battery the system will start up and run off...
          05-13-2024, 09:40 AM
        • piernov
          Laptop battery charging circuit
          by piernov
          1. Some theory
          1.1. Introduction
          Almost every laptop has a charging circuit of some sort, that does a few things:
          • Manages switching between AC adapter and battery power
          • Manages battery charging and generates power rail to charge battery
          There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
          • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
          • Narrow VDC (NVDC)
          Texas instrument has a nice overview of these technologies with some more details at https:...
          11-15-2020, 01:31 PM
        • kodox
          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
          by kodox
          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
          what i've done:
          - flashing...
          12-29-2024, 02:49 AM
        • Shinju
          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
          by Shinju
          Hey All!
          Long time forum member here with a problematic laptop issue!
          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
          The laptop would not power on with the new battery installed without the power supply being plugged in.
          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
          10-20-2021, 04:58 PM
