Apple iPad A2197 - stuck on 0.08a
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Both with the lightning cable or with the powersupply directly on the battery connector the device is stuck on 0.08a powerdraw.
    Nothing gets hot at all. I don't work on many iPads so no clue where to go from here.
    Took some quick measurements:
    PPVCC_MAIN 4.5v
    PPVDD_CPU 0.9v
    PPVDD_GPU 0.0v (no screen attached so guessing that's normal)
    PP0V9_NAND 0.9v
    edit:
    To put the device aside for a bit I partially put it back together and plugged it in out of curiosity. Devices takes 2.3a one time, until I unplug it. Then when I plug it back in it's stuck on 0.08a again until I disconnect the battery for a few sec, then I can reproduce the 2.3a powerdraw. When it draws 2.3a the PMIC goes to 40 degrees celcius, but that's it.
  • grimacelord
    Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
    by grimacelord
    Hello.
    Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
    If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
    For example, when I connect the iPad to...
    04-15-2022, 11:06 AM
  • ApplePie14
    iPad Air 4 is stuck in DFU mode
    by ApplePie14
    My iPad Air 4 is stuck in DFU mode.
    I tried restoring it with iTunes but it failed with Error 9. With 3Utools, it gets stuck at “Sending RootTicket” and times out.
    The PP2V625_NAND line was shorted, so I removed the faulty capacitor and attempted recovery again, but the issue persisted.
    The short is resolved, but the resistance value is low at 5.5Ω.
    Measuring the voltage on that line showed 8.3mV.
    Will installing a normal capacitor resolve this?
    Translated with DeepL.com (free version)
    09-04-2025, 03:54 AM
  • a_p3rson
    Apple Watch Charging Controller Schematics / Boardview - 820-02601
    by a_p3rson
    Hi there,
    I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
    You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
    This daughterboard uses an interesting...
    04-21-2025, 11:41 PM
  • GeirAndersen
    iPad .pcb file collection
    by GeirAndersen
    I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
    Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
    IPAD COLLECTION 1
    +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
    +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
    +---iPad mini3 820-00008(A1599) 820-00002(A1600)
    +---iPad mini4 820-00180(A1538) 820-00177(A1550)
    +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
    +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
    12-09-2024, 09:28 AM
  • mferna14
    Apple 820-01958-A logic board stuck on 5V .19amp
    by mferna14
    Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
    02-21-2025, 03:42 PM
