Lenovo t440s nm-a052 dead bios chip
  • kuraimangetsu
    • Nov 2022
    • 78
    • iraq
    Hi guys
    i got a dead t440s the bios chip is "W25Q128BV"
    testing with multimeter all good as i think
    but i get a 0.052 on the 1th PIN of the chip
    if i remove the bios i get the same 0.052 with the adapter removed
    and 0.024 when i plug the adapter.
    so what do you think?
  • mon2
    • Dec 2019
    • 14659
    Re: Lenovo t440s nm-a052 dead bios chip
    Pin #1 = /CS = CS#.
    This is an active LOW chip select pin. If the voltage is low, the chip is being selected. This voltage may also be low if the power rail is missing for this group of pins.
    A multimeter cannot monitor the activity of this pin if it is toggling high and low. You will need a scope to view signals that are switching at any speed. Or a logic / bus analyzer like Total Phase SPI bus tool. Then you can log the data being extracted out of this flash memory device upon boot.
    I would check the voltage to ground of each pin on this flash device. Post the list
    Also confirm the presence of the other voltage rails on this logic board. If a voltage rail is absent, power down and configure the meter to resistance mode. Measure the resistance to ground reading of that power rail.
    • kuraimangetsu
      • Nov 2022
      • 78
      • iraq
      Pin #1 = /CS = CS#.
      pin1 and pin2 have 0.052v adapter connected
      pin1 and pin2 have 0.024v adapter connected
      pin1 and pin2 have 80.0 kohm res to gnd adapter connected
      pin1 and pin2 have 0.900 mohm res to gnd with no adapter connected
      other voltage rails
      1.2
      5.1
      3.3
      present
      • mon2
        • Dec 2019
        • 14659
        Never check resistance with power to the board.
        Confirm other power rails at each inductor on the board. The fault may be due to other missing power rails.
        • kuraimangetsu
          • Nov 2022
          • 78
          • iraq
          here's an image for the readings
          Last edited by Vesko356; 06-22-2023, 06:38 AM. Reason: Image attached to the post.
          • mon2
            • Dec 2019
            • 14659
            The 0v inductors are likely the CPU rails. Often multiple rails will be used to share the heavy currents and are split in phases of turning on/off cycles.
            Remove all power. Meter in resistance mode.
            Check the resistance to ground of these inductors.
            • kuraimangetsu
              • Nov 2022
              • 78
              • iraq
              after digging it was the "vcc3lan" mosfet that wont open to the resistance. so after jumping the mosfet pin to the resistance i got the 3.3 on the res and got like 1.3v on the pin1 bios.
              removed the caps connected to vcc3lan that i think it's shorted and got back the 3.3v on the bios
              • mon2
                • Dec 2019
                • 14659
                Very good. So the laptop is repaired and working now?
                • kuraimangetsu
                  • Nov 2022
                  • 78
                  • iraq
                  Sry. for the late replay.
                  yeah. it's working right now.
                  attached the jumper location on the Q69 to the resistor
                  • andree952
                    • May 2021
                    • 4
                    • holland
                    hi can you say which ones capasitors do you have removed?
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • double_DD
                      How can I be sure that my EC chip is dead?
                      by double_DD
                      As the title suggests, how can I be sure that my EC chip is really dead?
                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                      03-12-2025, 07:47 AM
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • zunasthegreat
                      Dead corsair VS450 with blown TNY chip (cwt)
                      by zunasthegreat
                      I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
                      The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
                      08-30-2025, 03:11 AM
