Lenovo G50-80 20V ISSUE
  • motanya
    • Nov 2021
    • 160
    • Kenya
    I have a Lenovo G50-80 motherboard. aclu3/aclu4 UMA NM-A362 REV1.0. That if I connect the charger main power rail voltage moves up and down a maximum of 4v and zero continuously, I opened jumper PJ708 laptop powered on but no vcore of course. If I close the jumper and remove coil pl9 the initial problem remains. Now I have figured out the issue is the PC988 capacitor because if removed the laptop powers on well and displays if I replace the same capacitor from a working board the main problem remains. What might be the problem?
  • mon2
    • Dec 2019
    • 14027
    Re: Lenovo G50-80 20V ISSUE
    Remove all power. Check the resistance to ground of the main power rail that is fluctuating.
    What is the resistance?
    • motanya
      • Nov 2021
      • 160
      • Kenya
      41.32kOhms
      • mon2
        • Dec 2019
        • 14027
        This is a good and high resistance. No short on this rail.
        Is this resistance WITHOUT PC988 installed ?
        If yes, the fault is with this capacitor being shorted / partially shorted and causing the voltage rail to swing due to a higher than normal current draw.
        Respectively, measure the resistance across the PC988 component if it is off the logic board and on your work bench. It should continue to show a lower than normal resistance.
        It is a bulk capacitor and ideally should be replaced with this capacitance value or close to. Be cautious of the voltage rating of the cap since this is the high side power rail from your power adapter.
        • ash91
          • Jun 2023
          • 31
          • SAUDI
          try replace PQ40 and check the resistance after.
          • code share
            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
            by code share
            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
            Here's what I've tried so far:
            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
            • Booted successfully on AC power only with the battery disconnected
            • Visual inspection of the battery — no swelling, burn marks, or connector damage
            • Battery
            04-21-2025, 12:50 PM
          • Nagyesz
            Lenovo ideapad 3 15IL05 - ram issue
            by Nagyesz
            I've encountered an issue I've never experienced before..
            The Lenovo works perfectly, it has 4gb soldered ram and an additional slot. With just the 4gb the laptop passes all tests, everything is working. However no matter what frequency or capacity of ram I add to the extra slot the display starts artifacting completely randomly in both in the bios and in win and the only solution is to shut down.
            I've inspected the pins of the extra slot with a magnifying and didn't notice anything unusual. I've also tried multiple ram modules, but the issue is the same....
            01-11-2025, 05:17 AM
          • dal00
            Lenovo ThinkPad X1 Carbon Gen6 (NM-B48) Thunderbolt issue
            by dal00
            Hi!
            My Thinkpad X1gen6 (NM-B48) have had issues with thunderbolt for over a year now. No TB3 or HDMI working and the screen randomly flickering sometimes but going away other times. As if there was a glitch in the connection.
            When it was starting to fail I switched between assist mode and the non assist mode a lot because I didn't understand what was going on and some times it helped. (but really it probably made it worse by writing more to the flash) At one point when it had failed a switch like that hung the laptop with a black screen and I had to hard reset. That...
            09-07-2022, 08:27 AM
          • Pfudaniel
            reading EC with svod4 Lenovo NM-D271 issue
            by Pfudaniel
            Hello, im trying to read the EC of lenovo NM-D271 butthe files come up empty after read.
            Im using pinout provided from online database made by Adytia.
            Pin detection is succesfull and i read in 384 size.
            I was hoping to have some help to get the EC read succesfully. might be a pinout issue ? if anyone got more info on this id love to hear it.
            Thanks.
            03-29-2025, 03:04 AM
          • rookieme
            Lenovo NM-C861 backlight issue
            by rookieme
            the mainboard at first booted only sometimes with memory error.
            After ram rework it boots fine but the new issue is no backlight.
            Display did not had any issue so I guess something from the motherboard.
            At the JEDP1 I have 19V at pins 1 & 2, DISPOFF# at pin 15 is 0V and INVT_PWM at pin 16 is 2,82V.
            Same values are with lid closed.
            Lid switch works ok when tested with windows software.
            Is there something else I'm missing?
            10-24-2024, 03:11 AM
