Dell Cedar_intel -MB 13269-1 1D05V_S0 short?
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    (Dell board 13269-1 fx3mc rev a00)
    1D05V_S0 (PL4801) on the output side showed 0 or 1 ohm, does it mean soc (pch) gone? even injected maximum 1v, took about 400 mA, but soc does not seems to be hot.
    Basically the board was not triggering, despite rtc circuit, rsmrst, etc was ok, but not getting slp_s4 and slp_s3 from pch.
    schematic:
    https://www.badcaps.net/forum/showth...=112466&nojs=1
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Cedar_intel -MB 13269-1 1D05V_S0 short?
    PCH is definitely shorted.
    • usyusy
      • Sep 2021
      • 171
      • Pakistan
      ok boss, got it, thanks
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • aaronkatrini
        DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
        by aaronkatrini
        I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
        - Put the card in my testing motherboard and start running Heaven benchmark
        - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
        - Try to start it again and I get a slight move from the PSU fan - a clear short
        - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
        - Put the...
        05-18-2025, 04:18 PM
      • playit
        laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
        by playit
        the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
        02-25-2025, 08:15 AM
      • usyusy
        Dell E6430 19v line short
        by usyusy
        Dell E6430 19v line short,
        (QAL80 LA-7781P)
        19v rail, output side was showing a short (checked after removing CLR), a polar capacitor (PC1074-processor decoupling) in the core section was getting heat, when replaced that cap, the short gone, but when power on the machine, again that cap was heating (even had removed the processor already). so not understanding even no processor attached why this cap was getting shorted again and again
        any guidance please.
        Schematic:
        https://www.badcaps.net/forum/attachment.php?attachmentid=239428&d
        08-23-2023, 12:01 AM
