HP Omen 17t-w200 WHAE error when charger connected
This topic has been answered.
  • questore
    • Dec 2015
    • 503
    • csongrád
    Hi Everyone,
    I faced a strange issue of my friends laptop.
    You might have an idea because I'm out of my deept here.
    The laptop starts every time no problem.
    - When The original 230W charger is plugged in (with or without the battery same) and I start installing windows or start a preinstalled windows, then WHEA error happens or black screen freeze.
    - When I start laptop with only battery then windows installer start fine, install goes nice and fast. After installation I have to disable the nvidia 1070 and start windows this way and then enable the Nvidia 1070 graphic, then it runs Perfectly. Stress test on GPU, CPU and RAM, games like PUBG etc. also fine for hours.
    If I start with nvidia 1070 enabled then 10% of the time it starts no problem, but 90% of the time it freeze black screen or loading icon durring windows start.
    I have tryed:
    - Reset CMOS
    - reflashed newest BIOS
    - flash clean ME BIOS from this forum
    - also tryed to start laptop from battery and after windows boots then plugging AC adapter and disconnect battery, then run every stress test I can think of. No error or freeze after windows has started.
    - removed wifi card (no change)
    - replaced RAM with another good but smaller
    - reseated ram to another slot
    - tryed both ram same time
    - GPU max temp after stressing for 20 minutes is 70 celsius
    - CPU max temp after stressing for 20 minutes 80 celsius
    Any idea what can I do to point the exact problem?
  • Answer selected by questore at 07-21-2025, 03:26 AM.
    questore
    • Dec 2015
    • 503
    • csongrád
    Found the culcpit.
    Guys I was an idiot
    REASON of WHEA:
    I have diassembled and repaded and repasted CPU and GPU when the laptop camo to me because the heatsink was destroyed and i needed to repair it.
    Durring repasting CPU I only did it under simple magnifier (as I have done it 100 times before)
    Now I have rechecked it and there was a tiny stoned residue (abouth 1mm and it was probably from previous paste dryed and build up)
    I carefully scaped it away and repasted cpu core and BUMM. Laptop started as it should and even CPU temp with turbo is under 90 celsius.
    So if you have a WHEA under windows installation language select screen that could be because the CPU turns on the intel turbo and HP does not care about giving you info that the thermal shutdown is happened and that is why fan turns full speed when this WHEA occurs.
    Thanks for everyone for all the ideas that lead to this solution.
    • questore
      • Dec 2015
      • 503
      • csongrád
      Re: HP Omen 17t-w200 WHAE error when charger connected
      I have found a new symptom that led me to a solution and proves that the laptop is good, but there is someting strange going on.
      If I start the laptop from cold boot (meaning complete windows shutdown)
      Then On the next start I can power up the laptop whatever way I like, it will start windows and I dont have to disable the 1070 GPU anymore in windows.
      But it only works until I di a "shutdown" from windows. I have tried multiple times Shutdown-> startup...and after shutdown, the system is starting smooth.
      If I press "Restart" or restart laptop from BIOS and the charger is plugged in, then the Freeze happens and after this nothing solves the windows loading freeze until I unplug the charger, and do a windows recovery and shutdown the laptop.
      So The problem only happens if I restart the computer and not doing a cold start.
      Never ever even heard of this kind of problem.
      What could be the cause?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try earlier bios version .
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          It looks like you have not enough power. I would check how much power lost you have from dcin to current sensor. I would chheck that your first mosfet it is not shorted. Which charging ic do you have.
          Regards
          • questore
            • Dec 2015
            • 503
            • csongrád
            I have already downgraded BISO from F56 to F54 and now it is on F48. No change.
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              I would also check in the bios if your charger is recognised.
              • questore
                • Dec 2015
                • 503
                • csongrád
                In windows "batteryview" shows that when i plug in the AC it it recognized and charging the battery.
                The only thing that is very strange is that it shows that the battery current and full capacity is also 75000mAh and it is a 100% health.
                But the battery is obviously only 8300mAh and it is well beyond 100% health.
                I have tried depleting battery to 30% then charge back but no change.
                • mon2
                  • Dec 2019
                  • 14239
                  Check the voltage to ground of the SCL and SDA lines on the battery while it is connected to the logic board.
                  • Stevedb
                    Stevedb
                    • Feb 2018
                    • 624
                    • Belgium
                    Did you check the mosfets already for internal short
                    • questore
                      • Dec 2015
                      • 503
                      • csongrád
                      Sorry, yes, all of them are fine source-draing, gate-source are all OK
                      Also checked the power adapter 3rd sense pin.
                      - 19,71V when not plugged in and 1.78V all the time, after plugged in.
                      Resistance between plus DC 19,5V and 3rd sense pin is 100Kohms when not plugged in to laptop.
                      • questore
                        • Dec 2015
                        • 503
                        • csongrád
                        Did you mean SMC and SMD on battery only these exists.
                        Both CMS and SMD is 3.18V to ground.
                        Or do you mean in the BQ chip pin 8 and pin 9 SCL and SDA ?
                        • questore
                          • Dec 2015
                          • 503
                          • csongrád
                          I have found a problem on the GPU.
                          When I start to stress test the GPU it runs on 1870Mhz, but this type of GPU maximum Frequency is 1645Mhz even on boost mode.
                          How can i fix this? Is is possible thart someone has overclocked it? Is the GPU bios in another IC then the simple BIOS?
                          Attached a picture of the clocks from GPU-Z.
                          How can i change the clock to default?
                          • Stevedb
                            Stevedb
                            • Feb 2018
                            • 624
                            • Belgium
                            I think it has seperate bios chip for gpu. Are there shematics for this device?
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              https://www.badcaps.net/forum/showth...435#post955435
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • questore
                                • Dec 2015
                                • 503
                                • csongrád
                                Thanks for the schematics i think i will need it.
                                I have read, this behavior of new GPU-s are normal. I have checked and my laptop T1200 also doing the same in GPU-z. But I wanted to reflash GPU just to be sure, but https://www.techpowerup.com/vgabios does not have the same GPU bios for this subsystem device id: 103C-8261 only "10DE 0000" and i dont know if it is safe to flash it by force.
                                So maybe back to square 1.
                                What i have noticed is if i disable the 1070 then windows restart is working also with charger connected. So maybe it could be a AC adapter issue? should i try to add more juice with mybench power supply while AC is connected and see it windows feezes?
                                • questore
                                  • Dec 2015
                                  • 503
                                  • csongrád
                                  No luck, still Freeze and no extra current drawn from power supply.
                                  Now my only idea is measure everything around the charging chip, and if no fault find then replace it.
                                  Anyone has better idea?
                                  • Stevedb
                                    Stevedb
                                    • Feb 2018
                                    • 624
                                    • Belgium
                                    How much wattage is your charger is it the original from that device.
                                    • Sephir0th
                                      • Oct 2020
                                      • 1282
                                      Could be anything between faulty DC-IN Mosfets, issue with one of the power supplies related to the GPU, till a dying GPU itself. Maybe even a combination of those. However, with guess work only it will be hard to solve.
                                      FairRepair on YouTube
                                      • questore
                                        • Dec 2015
                                        • 503
                                        • csongrád
                                        Charger is original one with 230watt. Also tried with a replacement charger that only has 180watt and freeze also.
                                        • questore
                                          • Dec 2015
                                          • 503
                                          • csongrád
                                          More info about the problem:
                                          - If I switch windows energy management from balanced to performance mode, then th laptop freezes in about 1 minute even if I just browsing folders.
                                          - I hear some whine somewhere around GPU mosfet area but cant realy point the exact location.
                                          Next step is that I look carefully with microscope around the area where the whine can be heard and if I dont found anything then run around the edges of the mosfets with soldering iron to reassure correct solder joints.
                                          • flat-earther
                                            how to prevent a connected charger from draining battery when not charging?
                                            by flat-earther
                                            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                            So the battery is backfeeding the charger and being drained.
                                            How can I prevent...
                                            08-07-2025, 01:04 PM
                                            HP OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-020na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:44 PM
                                            HP OMEN X OMEN X by 900-187na OMEN X i7-7700K Specification for Upgrade or Repair
                                            This specification for the HP OMEN X OMEN X by 900-187na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by 900-187na boardview and OMEN X OMEN X by 900-187na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
