To me, sounds like crapware that has poor decision logic in the EC that is performing these integrity checks. If AD_ID is indeed 0v then at the very least, the charging should halt and the CPU speed should be throttled to force the logic board to consume less power as the power adapter's power rating is unknown.
HP Omen 17t-w200 WHAE error when charger connected
This topic has been answered.
Strange thing is that if charger is low wattage, then ec prevents the laptop from starting, so ec is sensing the charger ID. Still strange.To me, sounds like crapware that has poor decision logic in the EC that is performing these integrity checks. If AD_ID is indeed 0v then at the very least, the charging should halt and the CPU speed should be throttled to force the logic board to consume less power as the power adapter's power rating is unknown.
Still no solution.Comment
See Post #40
150W charger has 1.0V on AD_ID (only was here like 1 minute for diagnosing another laptop that failed so dont have this item on my bench anymore)
230W charger has 1.7V on AD_ID
Or do you mean measure Id middle pin on the adapter itself without connecting to the laptop?Comment
WHEA error is mostly 'coz of bad SOC.. It'll work intermittently without issue 'coz of heat applied during repair process. has faced this on a couple of Asus/Dell. Only on one occassion, i got success by replacing SOC. Rest i gave up as i dont had same SOC to replace.Comment
1. Repasted CPU ang GPU and did a full thermal pad replacement, not temprerture maxes in 89 celsius after 30 minutes of stress test cpu and gpu together
2. More info about trying to start windows by disabling GPU in windows device manager: it works until 2-3 restarts then if freezes just like when charger connected.
The only thing working is that disconnecting charger while windows boots then reconnecting it.
Whea still exists and windows cannot even tell what is the actual problem.
HP can go to hell i dump this poor guy.Comment
Found the culcpit.
Guys I was an idiot
REASON of WHEA:
I have diassembled and repaded and repasted CPU and GPU when the laptop camo to me because the heatsink was destroyed and i needed to repair it.
Durring repasting CPU I only did it under simple magnifier (as I have done it 100 times before)
Now I have rechecked it and there was a tiny stoned residue (abouth 1mm and it was probably from previous paste dryed and build up)
I carefully scaped it away and repasted cpu core and BUMM. Laptop started as it should and even CPU temp with turbo is under 90 celsius.
So if you have a WHEA under windows installation language select screen that could be because the CPU turns on the intel turbo and HP does not care about giving you info that the thermal shutdown is happened and that is why fan turns full speed when this WHEA occurs.
Thanks for everyone for all the ideas that lead to this solution.
- Selected Answer
MORE INFO:
Windows installer 10 and 11 will still freeze on load if the charger connected but after every driver is installed then the problem does not occur anymore.
I think i will ask HP about a permanent solution because I suspect we need to integrate some driver into windows installer to prevent this error.
Have a nice day guysComment
by flat-eartherI have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
So the battery is backfeeding the charger and being drained.
How can I prevent... -
This specification for the HP OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) boardview and OMEN OMEN by Desktop PC - 870-050na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...09-12-2024, 03:44 PM
This specification for the HP OMEN OMEN by Desktop PC - 870-104na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-104na boardview and OMEN OMEN by Desktop PC - 870-104na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 03:44 PM
This specification for the HP OMEN OMEN by Desktop PC - 870-128na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-128na boardview and OMEN OMEN by Desktop PC - 870-128na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 03:44 PM
This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...09-12-2024, 03:44 PM
- Loading...
