HP Omen 17t-w200 WHAE error when charger connected
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: HP Omen 17t-w200 WHAE error when charger connected
    i would for sanity try to replace all gpu mosfets. Maybey it wil solve the problem . How much voltage is your main power rail and your dcin connector.
    • questore
      • Dec 2015
      • 471
      • csongrád
      Good Idea, that would be my next step after reinforcing mosfet joints.
      • Sephir0th
        • Oct 2020
        • 1262
        if you suspect a partial failed buck converter, the unwritten rule is to not just replace the Mosfets, but also every other related semiconductor, like drivers and the PWM controller of course, because they tend to damage each other.
        FairRepair on YouTube
        • questore
          • Dec 2015
          • 471
          • csongrád
          Thank you. I usualy do that, even if it is just one failed power mosfet.
          But lets hope it is just a contact problem because otherwise it takes 14 day to get mosfet and controller for me.
          • questore
            • Dec 2015
            • 471
            • csongrád
            Hmm I have measured that PQ9002 and PQ9005 High side gates are in ohms range.
            - PQ9002 High side resistance to ground is 900 Ohms
            - PQ9005 High side resistance to ground is 55 Ohms
            - PQ9006 High side resistance to ground is 11,5 KOhms
            - PQ9001 High side resistance to ground is 11,5 KOhms
            For me it seems that PQ9002 and PQ9005 are faulty as well, but I think I replace PU9002 and PU9003 controllers as well.
            These are uP1909QDN8 and i got the info about the exact board schematic here:
            https://www.electronica-https://pt.com/esquema/notebooks/mot...31-1530-75300/
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #26
              Your measurements are irrelevant to asset the condition of the fet, It's not at all the proper way to measure it, you must measure resistance (or voltage drop) across S-G-D (S-D, D-S, S-G, D-G) of the fet itself (better out of circuit).
              BTW the link in your post is broken.
              Become a Badcaps supporter
              Thanks to all supporters.
              • questore
                • Dec 2015
                • 471
                • csongrád
                #27
                Gate to source is 0 Ohm and since i dont have ESR meter, I have to remove them one by one to know the faulty ones.
                link
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #28
                  link
                  Well 0 Ohm G to S is another story, definitely such a fet is defective if you're sure you measure it properly.
                  • questore
                    • Dec 2015
                    • 471
                    • csongrád
                    #29
                    I remove all of them and get back with the measurements out of circuit.
                    • Sephir0th
                      • Oct 2020
                      • 1262
                      The measurements of the Mosfets are inconclusive since you have measured Dual-Mosfets without mentioning and this way probably without realising.
                      • questore
                        • Dec 2015
                        • 471
                        • csongrád
                        #31
                        I have known those are dual mosfets, Every second chip is in pair in these, so i can measure mosfets from their pair pads because they are empty.
                        The only thing that is strange, that after I have restarted the power and shut it down properly and then removed all power again, then the all mosfets high gates values are changed to 1,5 ohm.
                        • questore
                          • Dec 2015
                          • 471
                          • csongrád
                          #32
                          I have Ordered 5 pack of Mosfets and 5 pack of controllers.
                          To be continued in 2 weeks when they arrived, or sooner if someone has better idea
                          • questore
                            • Dec 2015
                            • 471
                            • csongrád
                            #33
                            SOLUTION:
                            After eliminating every hardware issue i decided to not change any mosfet since they not produce error on heavy load if nvidia is turned on after windows already started.
                            I have cleaned the BIOS ME region with the official HP BIOS upgrading software. and then booted windows 10 install usb in UEFI mode.
                            After the windows installer is installed windows without a problem and I have booted in UEFI from SSD also i knew that the problem is solved.
                            No errors or blue screens eversince.
                            • questore
                              • Dec 2015
                              • 471
                              • csongrád
                              #34
                              Problem is back, I'm crying
                              The only thing that happened since it was working was that I take apart the heatsink because one of the heatpad does not contacted, So I have replaced the heatpad to a thicker one.
                              HELP
                              • questore
                                • Dec 2015
                                • 471
                                • csongrád
                                #35
                                PROBLEM FINALLY SOLVED:
                                The culcpit of the problem was the Realtek Gigabit Ethernet Controller driver.
                                I was also surprised but after investigating the device HardwareID-s I narrowed down the problem to one PCI-E controller A151.
                                Maybe some of you ask: Why it was that disabling the NVIDIA card solved the problem. Later I found that when wrong driver is installed then the PCI-e A151 was used by the Network card and so the 2 devices interfered.
                                After the official driver was installed to the LAN device, the problem was finally gone.
                                Thanks for everyone that helped in the way.
                                • questore
                                  • Dec 2015
                                  • 471
                                  • csongrád
                                  #36
                                  MORE INFO: After a Few days, the problem always came back until finally the consequence is risen.
                                  The restart only freezes if previously the laptop is heated up above 55-60 Celsius.
                                  If I wait until it cools down in windows the it restarts fine.
                                  I personally think this is a very bad hardware design since I can run any stress test inside windows once it is booted up.
                                  • questore
                                    • Dec 2015
                                    • 471
                                    • csongrád
                                    #37
                                    After thorough systematic tests the followings facts are sure:
                                    1. Windows boot failes if the power adapter plugged in for a certain amount of time. About after 5 minutes (With or without battery connected it does not matter)
                                    2. If I do a cold PowerON. The power adapter is not plugged in for half an hour and then I plug it in and start the computer, then it boots correctly.
                                    I start diagnosing the charger circuit with a thermal camera, And checking the components around the charger IC.
                                    Anybody has better idea?
                                    • questore
                                      • Dec 2015
                                      • 471
                                      • csongrád
                                      #38
                                      3. If I disable the NVIDIA GPU and restart the laptop, then reboot is OK then enable NVIDIA GPU and it runs OK
                                      4. NVIDIA GPU is stable even on 118% power draw boost mode durring a 2hour stress test.
                                      5. CPU stress test runs without problem.
                                      + charger circuit seem to work fine, If laptop is turned off and after the battery is full then nothing gets hot on the board.
                                      HELP I'M OUT OF IDEAS
                                      • questore
                                        • Dec 2015
                                        • 471
                                        • csongrád
                                        #39
                                        After another project I have that have a wrong contac charger ID pin and did something similar freeze, I have checked every component on ID pin circuit.
                                        I have 1.7V on te AD_ID pin when connected AC. It that good value for a 230watt charger? I found that D5100 i having Diode values 0.7V in one direction and 1.2V in the other way (multimeter in diode mode).
                                        Should I check this Diode out of circuit to see its faulty?
                                        Other strange thingaboth this.if I remove the AD_ID connector, then the same behaviour happens as normaly. No message that charger is low wattage or anything
                                        (It even more suspicious that Schematic says that "Change to 1SS355 as Current loss" )
                                        • questore
                                          • Dec 2015
                                          • 471
                                          • csongrád
                                          #40
                                          I have managed to get a genuine 150Watt HP charger and AD_ID is 1.0v. This means that 1.7v might be OK for 240W charger ID pin.
                                          Another thing that is a conclusion is that if you plug in a charger that is lower than expected, then the laptop simply not reacts to power button. (150W < 200W as expected)
                                          BUT this does not explain why nothing bad happens when I NOT plug in the AD_ID connector, only the simple charger connector. In this case te AD_ID is 0V and laptop starts normaly.
                                          Anyone knows this?
                                            HP OMEN OMEN by Desktop PC - 870-260na OMEN 870 i5-7400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-260na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-260na boardview and OMEN OMEN by Desktop PC - 870-260na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 03:44 PM
                                            HP OMEN OMEN 870-033ng OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN 870-033ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN 870-033ng boardview and OMEN OMEN 870-033ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            HP OMEN OMEN by Desktop PC - 870-240na OMEN 870 i5-7400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-240na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-240na boardview and OMEN OMEN by Desktop PC - 870-240na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                                            This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                                            This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
