Lenovo Thinkpad X13 Battery not charging
  • mferna14
    • Jun 2018
    • 1046
    Hi., I am working on a Lenovo ThinkPad X13 Board # NM-C891. The unit is working fine but the battery does not charge & the laptop does not stay on with a charged battery, if I removed the Adapter cord it just turns off. I put in a new battery & when I turn on, it gives beeps & then laptop does not turn on at all. I checked the battery terminal (JDC1). The reading are as follow:
    Pin 1-2 GND
    Pin 3 NOT Connected
    Pin 4 M_TEMP 2.2v which is very abnormal. This should change to low (GND) when good battery is attached. The volts on this pin never changes with or without the battery or the AC Power in or out.
    Pin 5 DATA 3.3v
    Pin 6 Clock 3.3v
    7-8 Positive (No voltage at all)
    M_TEMP signal is directly coming from UCE1A (MEC1663-WC_WFBGA144) .... Do you think this chip got defective. Is this chip programmable?? Can someone look into this. Thanks in advance
  • mon2
    • 14660
    Re: Lenovo Thinkpad X13 Battery not charging
    Pin #4 is driven by the battery pack. Given that both tested batteries are unable to pull this line low, review the actual battery contacts. Next, check the resistance from this battery contact on the connector back to the UCE1A chip.
    That is, the MEC1663-WC is using an input pin (ADC = analog to digital converter) to detect if the battery is connected or not by monitoring the M_TEMP signal.
    After the above checks, use a piece of wire to manually drive the M_TEMP pin low @ junction of PR0101 & PC0102.
    • mferna14
      • Jun 2018
      • 1046
      Our saver mon2!!! thanks for the tips I will check tomorrow... Regarding this manual drive "piece of wire to manually drive the M_TEMP pin low @ junction of PR0101 & PC0102." So as I understand One end of the wire goes to the M_TEMP battery terminal & the other end to the junction of PR0101 & PC0102!! Is it right what I have understood???
      • mon2
        • 14660
        No. One end of the wire to the junction of PR0101 & PC0102 and the other side of the wire to ground.
        • mferna14
          • Jun 2018
          • 1046
          Ok thanks, will do this & inform you tomorrow...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Pin7-8 too should show voltage as long as battery is charged(one of the batteries is new as per your post). Resistance check to GND on pin7-8?
            • mferna14
              • Jun 2018
              • 1046
              Thanks for all replies, my client has taken the laptop for data backup, once he gets it back, I will troubleshoot once again & let you guys know.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • jared101
                Lenovo Ideapad 320-15IKA NM-B452 not charging battery
                by jared101
                NM-B452
                Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
                On the BQ24780SRUYR charging ic
                VCC 20V
                SMBUS lines
                SDA 3.3V
                SCL 3.3V
                Current Sensing lines
                ACP/ACN 2.3 ohms
                SRP/SRN 21.2 ohms
                REGEN line 6V
                PHASE .84V with no battery installed(this may be normal)
                08-03-2022, 09:19 PM
              • Julian Bailey
                HP ProBook 445 G8 Battery not charging
                by Julian Bailey
                Hi all
                We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                I have gone around the board with a MM and cant find anything
                Windows shows the battery fine,...
                10-11-2024, 10:34 AM
              • mferna14
                Lenovo Carbon X1 Battery not charging
                by mferna14
                Hi, Working on a Lenovo X1 Carbon 1st Gen (Type 3444) Laptop. Came in for battery problems. Upon testing the battery, I noticed that one of the cells is bursted & has to be replaced. Ordered a Brand New battery. Now it works on battery but does not charge at all. I see in Windows 10 it shows the charging sign & AC power connected but stuck on 79%. I did a press-in switch reset at the botton of the laptop, but did not help. Checked the Voltage on the chip BQ24760RSBR, all seem to be fine. Battery voltages are ok 14.4v but on the battery coil L24, when AC is plugged in I only get 1.8V. Then...
                02-24-2023, 05:25 PM
