problem with keyboard macbook a1297
  • giove
    • 26
    • Italy
    Hi, I have a macbook a1297 emc2414 motherboard 820-2914-B with password prompt on startup. I unmounted the bios chip and reprogrammed deleting everything after $SVS from the binary file. After reassembly it boots normally with the operating system. Unfortunately, probably by disassembling the motherboard, the keyboard no longer works.
    I have unplugged and plugged the connector several times but nothing to do not even the start button works. To start it I have to disconnect the battery and put the power supply connector. Is it possible that the keyboard broke? do you think replacing it works? I have many doubts because before disassembling the motherboard at least the power button worked ...
    Also what is the keyboard pinout to locate the Power button?
    Thanhs
    Roberto
  • mon2
    • Dec 2019
    • 14662
    Re: problem with keyboard macbook a1297
    See attached.
    1) In the absence of the keyboard, the PCB designers have left shorting pads on each side of the PCB which can be used to emulate a power button using tweezers.
    2) The keyboard & trackpad functions are mapped to a USB port on a USB hub. The actual keyboard and trackpad USB functions are handled by a Cypress PSOC chip = 8051 or Cortex M0 processor with USB interface.
    3) Start with the usual power rail checks on the keyboard connector. Be sure that you are inserting the flex cable deep enough into the keyboard FPC (blade) connector. Be sure that the flat bar is in the open state (use 2 hands and finger nails to open the wimpy black bar - going from memory here) -> then insert the cable as deep as it can go -> then close the flat locking bar to compress the contacts onto the FPC cable.
    • giove
      • 26
      • Italy
      ok then by grounding pin 5, which is at 3.4Volt, the macbook turns on correctly and turns off keeping pin 5 grounded. I noticed that by pressing the power button the voltage on pin 5 drops from 3.4V to 1.7V. Is the resistance probably too high? Is it a keyboard problem?
      • mon2
        • Dec 2019
        • 14662
        Yes, it appears that the keyboard contact is not a perfect one where when it is pressed, should be a hard short to ground to power this board ON/OFF. Perhaps some dirty contact?
        Consider a work around and apply a resistor from SMC_ONOFF_L to ground. You will have to experiment with the values. Test with 1k, etc.
        The idea is to pull-down this voltage level which then will also allow for the keypress to yet further lower this voltage so that the ON/OFF functions.
        Somewhere on this forum is a thread with the same fault and the tech posted the value that worked for him. Same fault / same fix (going from my fading memory).
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
        • Vliegenier04
          Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
          by Vliegenier04
          Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
          I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
          Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
          06-16-2025, 12:03 PM
        • MrDadosz
          Lenovo Legion 15IMH05 keyboard problem
          by MrDadosz
          Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
          When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
          In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
          Shortcuts Fn + F1-F12 are working. Keyboard is fine.
          I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
          08-15-2024, 05:07 AM
        • fmajbour
          Acer Nitro 5 model A515-51 keyboard problem
          by fmajbour
          I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
          Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
          i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
          I have check the keyboard connector on the mainboard every thing looks ok.
          Then i replaced the keyboard with new one ......same problem exact same keys problem.
          I need your advice if anyone face...
          11-13-2023, 09:50 PM
          HP ProBook 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 430 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
          09-06-2024, 06:21 AM
