DAZAARMB6E0 REV E NO Power
  • Fernon@Repair
    • Jan 2021
    • 34
    • Sri Lanka
    19V power rail ok
    charging ic AC Ok out voltage present
    3 and 5V ok
    io chip RSMRST# voltage out ok
    bios 8 pin 3.3v not present
    battery charging light present
    when press power key ram voltage come and 0
    charging light showing but motherboard not power on
  • mon2
    • 14662
    Re: DAZAARMB6E0 REV E NO Power
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of the bios pin #8.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
      Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
      I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
      https://www.ebay.com/itm/116497313155?var=416785404161
      Here are some of the description from the eBay seller
      The main parameters:
      1. Product name: High-power non-isolated DC boost module power supply.
      2. Product model: 100A2000W.
      3. Input voltage: DC12V-60V.
      4. Input current: 100A (maximum)....
      05-18-2025, 09:45 AM
    • Dr.d
      Help please..Lenovo ideapad 5 14itl05 power and charging problem
      by Dr.d
      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
      04-05-2024, 11:48 AM
      03-31-2024, 02:12 PM
