iphone 7 no power no image
  • Thedan55
    forever learnin
    • Aug 2022
    • 37
    • United Kingdom
    Hi everyone. I've got an iPhone 7 with no power. I'm not too familiar with phone board issues would appreciate a little guidance if you can please.
    When connected to my PSU is cycles between0.007 to 0.178
    With charger connected to lightning i get no voltage on battery connector.
    Battery connector plus to negative no short. while charging stuck at .44a no change with new power button flex and charging fles.
    phone is recognised in itunes when i put it into dfu mode
    Positive terminal diode reading is.478
    tested the digi fpc in diode mode comparing with bv measurements
    Pin 1 says 505 im getting 263
    Pin 3 says 573 I'm getting 245
    Pin 25 says 746 im getting OL (looking at bv its not supposed to be ol)
    any guidance would be immensely appreciated please!
  • mon2
    • Dec 2019
    • 14000
    Re: iphone 7 no power no image
    Watch this video for some ideas:
    https://www.youtube.com/watch?v=ZmMg...WFSuKVl4AaABAg
    • elecsoluces
      • May 2020
      • 66
      • France
      Phone is recognised in DFU mode so try restore via itunes (you will lost data) or try an update with 3utools to save data.
      • Thedan55
        forever learnin
        • Aug 2022
        • 37
        • United Kingdom
        Originally posted by mon2
        Will do thanks
        • Thedan55
          forever learnin
          • Aug 2022
          • 37
          • United Kingdom
          I can't loose data it belongs to a customer
          • Thedan55
            forever learnin
            • Aug 2022
            • 37
            • United Kingdom
            Plus no image
            • Thedan55
              forever learnin
              • Aug 2022
              • 37
              • United Kingdom
              so ive not found any shorts on the board. ive injected but as you might guess no power draw.
              i found cap C7606 practically off the board, barely is connected, i can nudge it and its moving. not taken it off yet.
              this board has been worked on by someone before me so its difficult to know whats been done.
              the area at the bottom end of the board is missing a bunch of caps and filter. i replaced filters and resister from donor, someone told me C3823 and the 2 next to it arent needed for boot.
              im honestly thinking this might be a chestnut issue, but it doesn't seem like its booting. while connected to psu its pulling .57 .62 .64 .78 168 and a few more then goes to 0 then does it again.
              i really have no clue at this point. can anyone help please?
              • mon2
                • Dec 2019
                • 14000
                You are power / boot cycling.
                Review each and every power rail to confirm that each is present.
                Before proceeding, remove all power -> meter in resistance mode -> check the resistance to ground of each of the above power rails.
                A shorted cap can cause this fault. Check for any low resistance on the power rail.
                Rewa (Shenzhen) has great videos on phone repairs.
                • Thedan55
                  forever learnin
                  • Aug 2022
                  • 37
                  • United Kingdom
                  Thanks will do! Appreciate it
                  • Thedan55
                    forever learnin
                    • Aug 2022
                    • 37
                    • United Kingdom
                    right so while testing the power rails i got to vdd boost and found an issue. c3828 has both pads missing, one side which is vdd boost goes into u3801 which enables a bunch of things from what im seeing, touch, pp2v75, mamba meesa.
                    the cap c3828 has lost both pads. can i life u3801 and run a jumper from its vdd boost pad to recreate the point for the missing cap?
                    Also on pin 4 of the touch connector i get ol which i think i shouldn't be getting. But u don't think that's affecting the boot cycle. But I'm not certain
                    • Thedan55
                      forever learnin
                      • Aug 2022
                      • 37
                      • United Kingdom
                      Added image
                      • Thedan55
                        forever learnin
                        • Aug 2022
                        • 37
                        • United Kingdom
                        Anyone?
                        • SluggerB
                          Help with trying to fix phone that is not charging (Pics inside)
                          by SluggerB
                          I have two TCL A30 phones.
                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                          08-12-2024, 08:11 AM
                        • keeney123
                          new OS on a Sonim XP5s phone
                          by keeney123
                          To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                          I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                          05-13-2022, 07:19 PM
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • Wachenaggo
                          iPhone 6s Plus Ghosting Image intermittent LCD Screen not working.
                          by Wachenaggo
                          i got this iPhone 6s Plus Ghosting/Doubling Image intermittent LCD Screen not working and Touch Not working
                          i check CHESTNUT Voltages its there or does anybody know what is this issue....
                          05-08-2023, 08:11 AM
                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                          09-06-2024, 10:56 AM
