Dell studio xps 1340 (DA0IM3MBAG0) hot System 5v/3v chip
  • dwnisup91
    • May 2023
    • 11
    Hey
    I'm a beginner trying to fix a dead dell laptop motherboard. When the power adapter and the FFC that connects the power button is connected I noticed the Sys 5v/3v chip gets extremely hot to touch. I disconnected the FFC and the Sys 5v/3v chip was still warm. The voltages of Pq43 and Pq46 are at 19v which I think is fine. PQ42 and PQ44 both show 3.1v which I think shows something is wrong. I checked the chemical capacitors PC170 and PC159 and I get 0v. I am not sure why this happened or what to do to fix the issue. Any help or advice is appreciated! Thanks
  • mon2
    • Dec 2019
    • 14172
    Re: Dell studio xps 1340 (DA0IM3MBAG0) hot System 5v/3v chip
    If it hot to touch, the part may be defective or is overloaded.
    Remove all power and check the resistance to ground of the output rails of this component. Check for a low resistance which means you have a shorted part.
    • dwnisup91
      • May 2023
      • 11
      I checked the resistance on the 5v/3v chip and got nothing on my multimeter. So the chip is shorted?
      • mon2
        • Dec 2019
        • 14172
        What is the exact measurement on your multimeter? Can you share a pic of the measurement from the front face of the meter?
        Is your meter auto-ranging for the resistance scales or is a manual select version?
        If manual select, if the range is too low to measure, the meter face will show '1' or 'OL' for over limit. At that stage, select a higher resistance scale till the meter can offer a valid measurement.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Resistance on pin7 of PU9?
          • dwnisup91
            • May 2023
            • 11
            The angle is awkward but this is the resistance shows 98.3
            • dwnisup91
              • May 2023
              • 11
              This resistance of the 5v/3v chip is .117. This resistance kept increasing. I took a a picture when the reading slowed down.
              • mon2
                • Dec 2019
                • 14172
                Based on the pic in post #6, the measurement is ~98k ohms.
                Switch to the next lower scale of 20k. The meter should show '1' or 'OL' for over limit. This confirms that the measurement is > 20k ohms. No fault here.
                • Sephir0th
                  • Oct 2020
                  • 1282
                  Measure in 200 Ohms range. Everything else is simply useless and confusing at this point.
                  FairRepair on YouTube
                  • dwnisup91
                    • May 2023
                    • 11
                    My multimeter doesn't give a reading when set to 20k or below for pin 7.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      The pic in post#6 doesnt correspond to 3v/5v PWM. I think i have different schematic. Please link your schematic to avaoid confusion. I used Quanta im3(jolie) rev 3A
                      • dwnisup91
                        • May 2023
                        • 11
                        The schematic I was linked to on the forum was rev 1B. I have access to 3A and 1B and can use either moving forward.
                        https://www.badcaps.net/forum/showthread.php?t=118930
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Both the version show 3v/5v regulator as PU9 and its MAX17020. Look for this chip and measure resistance on pin7. the chip may be with other name like TPS51427/PM6686/ISL6237
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                          • ed1i
                            Dell Inspion 7610 bios chip
                            by ed1i
                            Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
                            01-16-2025, 02:14 PM
                            HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation Studio Specification for Upgrade or Repair
                            This specification for the HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor Z27x Studio Display boardview and Studio G4 + DreamColor Z27x Studio Display schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                            09-06-2024, 06:00 AM
                          • donnietr
                            Need help id'ing chip on a Dell g15 5515
                            by donnietr
                            Hello all,
                            I have this dell g15 Ryzen Edition 5515. Board GDL56 LA-K453p. It had liquid damage when i bought it. Cleaned it up really well and then used thermal camera to see what got hot.
                            Found the power pdw1 and pdw2 under the graphics card were getting hot. Pdw2 was hottest, i had a similiar chip on another board so i put it on this board.
                            The other chip is now hot as well, which it was to begin with.
                            Thats the problem as i dont know what to call it, like is it a mosfat? or what?
                            I will attach a picture of both the boardlabel and of the area with the chips....
                            07-18-2025, 08:03 PM
                          • ezenia
                            Dell G3 3579 BIOS chip ID
                            by ezenia
                            I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
                            06-16-2025, 08:07 PM
