Asus X540B dead
  • Jane
    • Aug 2010
    • 189
    Asus X540B dead
    Asus X540B has no voltages on the large inductors. I checked 19V rail and the voltage is comming to the first mosfet( to drain) but no voltage on Gate nor on Source. I checked the first and the following mosfet but neither seems to be shorted.
    What should be the next step?
    Thank you for help
  • mon2
    • Dec 2019
    • 14677
    Re: Asus X540B dead
    1) link the schematic if available in the schematics forum.
    2) which charger IC is onboard? Perhaps the TI BQ series? Need the full details.
    • Jane
      • Aug 2010
      • 189
      Re: Asus X540B dead
      Please find enclosed a picture of mainboard.
      There is BQ 24780s charging IC. But there is no Vin voltage coming to that IC BQ24780S.
      Unfortunatelly I did not find a schematic.
      Is it possible ( or good) to bypass 19V to that BQ24780s and test the mainboard?
      Or is it risky?
      Thank you for reply
        • 21946
        Re: Asus X540B dead
        Or is it risky?
        Thank you for reply
        If you don`t know what the risks are and what the consequences could be,don`t do it.
        • mon2
          • Dec 2019
          • 14677
          Re: Asus X540B dead
          Post a clear pic of the charger IC area to show the parts.
          Vin will be fed by a 3 pin dual diode. Locate it and check the voltage to ground of each pin of this diode.
          Likely will be a sot-23 smd package. This part will accept a power feed from the power adapter and also the battery. It will auto select the higher voltage to power the charger IC.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Re: Asus X540B dead
            Remove the 2nd mosfet and connect adapter. Do you get 25V at pin4 of 1st mosfet?
            • Jane
              • Aug 2010
              • 189
              Re: Asus X540B dead
              @mon2: Please find enclosed a picture of charging IC area. I measured voltages on the
              diode marked with red arrow. Is it correct?The path seems to lead to input pin of the charger IC, I think. However, voltages on 3 pins were about 0.03V.
              P.S. I also enclosed a picture of input area
              @mcplslg123. There is no Vin (input voltage) coming to the charger IC. Do you think there can be any voltage on the pin4 of 1st mosfet( when I remove the 2nd mosfet) if there is no voltage on the charger IC?
              I expected the voltage to the 4 pin( Gate) should go from the charger IC.Or am I wrong?
              • mon2
                • Dec 2019
                • 14677
                Re: Asus X540B dead
                Yes, this dual diode powers the charger IC.
                Review the right side trace in the picture which leads to the battery connector. This same trace is broken or was intentionally cut near the end. This trace must be fixed to allow for the battery pack to power the charger IC.
                You can use a piece of wire from the same diode pin to the thick trace and scrape off some of the green solder mask, then flux and solder the wire. Or you can do the same with a short piece of exposed wire across the pcb trace itself.
                Next, remove all power. Meter in resistance mode. One meter probe to the left diode pin or pcb trace. Be sure you are touching the copper trace and not the green solder mask. Other meter probe to the dcin power connector. You should have continuity leading to the power adapter connector. This is so the power adapter can power the charger IC.
                Confirm it.
                • Jane
                  • Aug 2010
                  • 189
                  Re: Asus X540B dead
                  Thanks a lot for help. The trace was broken.
                  Now the laptop starts.
                  Asus logo appears for a second but then laptop turns off.
                  Do you think it can be LCD problem - short?
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
                  • Scotchmist
                    Asus GA502D keeps blowing mosfet
                    by Scotchmist
                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                    I have removed the mosfet and can run the laptop no problem
                    The MOSFET is FDPC5018SG
                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                    08-24-2024, 02:23 PM
                  • MicroSMD Lab
                    ASUS ROG Zephyrus GPU Mosfet repeat failure
                    by MicroSMD Lab
                    The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                    01-10-2024, 06:36 AM
                  • someonenotyou
                    ASUS G513R - cannot remove MOSFET
                    by someonenotyou
                    Hi.
                    I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                    I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                    Of course, I did not force it, but tried to lift it up with tweezers.
                    Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                    10-10-2025, 11:05 AM
                  • Timp74
                    Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                    by Timp74
                    Hi All,
                    Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                    I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                    08-13-2021, 01:11 PM
