I2C communication !
  • guizmo1967
    • Sep 2022
    • 77
    I2C communication !
    I would like to know on average how many chips in a laptop uses the I2C protocol to communicate and which one.
    I know the battery, BQ24735 and the ITE uses SDA and SCL but is there other chip that do ?
    And the SDA, SCL pins always needs to be pullup to 3.3V, no matter what if the laptop turns on or not, right ?
    Thanks !
  • mon2
    • 14663
    Re: I2C communication !
    No firm answer and will vary with the board design.
    I2C and smbus are similar. Both are open-drain pins so the pull-up voltage can also vary to suit. For example, can be 5v, 1v8, etc.
    • guizmo1967
      • Sep 2022
      • 77
      Ok thanks !
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Touchpad also uses I2C
        • gabiz_ro
          • Mar 2011
          • 169
          There are many more, most used
          RAM module for SPD
          Internal display for EDID
          External display (VGA,HDMI) also for EDID
          Also some others like
          some axis accelerators,others sensors,battery management,backlight control,
          • Jane
            BQ24735 - faulty?
            by Jane
            Can you please give your opinion on this matter?
            Laptop does not work. I checked voltages of charging circuit BQ24735 .
            Values are :
            pin 20: VCC 19V
            pin 6: ACDET > 2.4V
            pin 16: REGN 6V
            pin 5: ACOK 2.62V
            Are these values correct and (if BQ24735 is working in the correct way)
            ACDRV (pin 4) should have more than 19V?
            Or I must check any other values to be sure to decide that BQ24735 is faulty?
            AS I have ACDRV about zero, so I guess BQ24735...
            10-21-2022, 11:45 AM
          • BOSCHNJAK
            by BOSCHNJAK
            ABOUT ME INTRODUCTION FILE
            2
            024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
            2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
            2022 BEV, PROJECT ?
            2021 BEV, PROJECT ?
            2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
            2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
            12-28-2023, 02:09 PM
          • estebanpe
            asus x541sa no power (bq24735) no ACDRV
            by estebanpe
            Hello, I have this board that drives me crazy, I can't activate the input mosfets, I have changed the bq24735 with the same result
            These are the IC voltages and I also leave a couple of voltages extra
            1 3.9v
            2 3.9v
            3 0v
            4 0.03v
            5 0.05v
            6 2.6v
            7 0.004v
            8 0.020v
            9 0.020v
            10 0.15v
            11 3.13v
            12 3.10v
            13 3.11vv
            14 0v
            15 0v
            16 6v
            17 5.8v
            18 3.10v
            19 3.10v
            20 19v
            P_CHG_AC_GATE_20 0.010v
            AC_BAT_SYS 3.4v​
            10-15-2024, 05:23 AM
          • Andrewerry
            Make MSP430FR5994 wireless MCU as peripheral interface?
            by Andrewerry
            I have an idea according to MCU Communication Peripherals Guide. Under the software guidance on protocol implementations, a confusing problem, wireless MCU CC2650 and CC2640R2F, can they be regarded as communication peripherals controlled by FR5994?
            I want to customize a kind of communication hardware, including FR5994, a kind of TI BLE chip, a programmable port for the two chips, a kind of energy harvesting peripheral.
            How can it be done?​
            09-11-2024, 02:08 AM
          • ianbak
            BQ24735 Problem (HP 255 G8)
            by ianbak
            I have an HP 255 G8 that runs for as long as its battery holds charge but won't accept AC power.
            I have partially diagnosed the problem and the issue seems to be that there is no ACDRV output from the BQ24735 to turn on the two input MOSFETs. The 24735 has a VCC of 19.57 V, the ACDET input is at 2.93 V and the REGN 6V LDO is outputting 5.98 V, so everything looks good - but ACDRV is stuck at 28 mV.
            I've already replaced the 24735 and both input MOSFETs and nothing has changed.
            I'd appreciate some suiggestions as to what to try next.
            05-20-2024, 08:45 AM
