Dell ac power adapter type cannot be determined
  • Inforgalaxie
    • Apr 2023
    • 39
    • Portugal
    Hi, there is a tipic problem on Dell but my is very strange.
    On PU111 i have this voltages:
    Pin1:0.78V
    PIN2: 0V
    PIN3: 3,19V
    PIN4:3.07V
    PIN5: 5V
    PIN6:0V
    PL3 have 3.19V
    What you think that can be? SIO? because PIN6 is 0V?
    I Attach schematic.
    There is a way to solve this problem?
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell ac power adapter type cannot be determined
    You can unsolder temporary PU111 and bridge pin3 to pin4 to see if it solve the problem, or check the charging DC in jack, there may be a poor contact between the center pin and the jack, if you are sure the charger is genuine and working.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Inforgalaxie
      • Apr 2023
      • 39
      • Portugal
      The Bridge PIN3 and PIN4 solve the problem...
      I not have a new PU111.. The is any problem if i just bidge to solve the problem?
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        If you don't use a docking station, you can leave it like that, otherwise you must replace it.
        • diamon
          • 107
          • Netherlands
          Don't you have a other Dell motherboard laying around?.
          Few days ago, I used a Dell E6320 motherboard (chip PU1) to fix a Dell E7240 motherboard (chip PU111).
          The adapter did not get recognized in the bios, and with bridging pin 3+4 it did worked again.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
            Dell Thunderbolt Firmware
            by SMDFlea
            Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
            Some models have a choice of 2 different firmwares, it depends on the dell SKU.
            The SKU is in brackets (****)
            EDIT: NVM65...
            01-26-2025, 06:22 AM
          • F R 2568
            Dell Latitude 5420 does not start (no post) need help to find the reason why
            by F R 2568
            Hello all,
            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
            If the laptop is only connected to the AC adapter (battery removed):
            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
            The power/battery...
            01-08-2025, 05:45 AM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
