Lenovo 100-15idb NM-A681 no turning on
  • xRaPiDxX
    • Feb 2021
    • 35
    • Poland
    Hello, laptop is not turning on. Motherboard Mark: NM-A681 rev 1.0 UMA
    Here are the measurements I've taken:
    PR301:
    2.2mohm and goes down
    PQ301:
    S: 19.59V
    G: 19.575V
    D: 20.1V
    PQ302:
    S: 19,594V
    G: 19.576V
    D: 0,0022V
    Diode test: 0,5341V
    I don't have short circuit between S and G.
    What should I measure next? Please help
    Greetings 😁
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Lenovo 100-15idb NM-A681 no turning on
    Originally posted by lapfix
    lenovo ideapad 100 CG410/CG510 NM-A681 Schematic and BVD
    https://www.badcaps.net/forum/showth...37#post1044937
    Become a Badcaps supporter
    Thanks to all supporters.​
    • mon2
      • Dec 2019
      • 14271
      Remove all power -> meter in resistance mode.
      Measure the resistance between the following pins on each of the above mosfets:
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      Post each measurement.
      • xRaPiDxX
        • Feb 2021
        • 35
        • Poland
        Thanks for reply. I checked signal ACOFF and there is 0v. I measured on 98 pin od kbc, so do I need to replace KBC? I still learn.
        • mon2
          • Dec 2019
          • 14271
          Can you link or post the schematic? The above mosfets, are not enabled. If they are N-channel type, then gate voltage must be boosted to ~25v to enable. If P-channel, gate must be lower than the source / drain voltage.
          The charger IC will decide when to enable or not.
          Post the schematic link. Then post the resistance checks after removing all power. Checking if the mosfets are defective.
          • xRaPiDxX
            • Feb 2021
            • 35
            • Poland
            PQ301:
            Source - drain: 0.623mohm
            Source - Gate: 0.1955mohm
            Gate - drain: 0.44mohm
            PQ302:
            Source - drain: 0.27mohm and goes to 1mohm
            Source - Gate: 0.195mohm
            Gate - drain: 0.43mohm and increase to ~1mohm
            I use schematic and boardview from this post:
            • mon2
              • Dec 2019
              • 14271
              Check the voltage to ground of PACIN.
              • xRaPiDxX
                • Feb 2021
                • 35
                • Poland
                Voltage to ground PACIN: 3.26V
                • mon2
                  • Dec 2019
                  • 14271
                  Locate PQ307B. Check the voltage to ground of pins 3, 4 and also 5. Post the readings.
                  • xRaPiDxX
                    • Feb 2021
                    • 35
                    • Poland
                    Pq307b:
                    3-0.0234v
                    4-gnd
                    5-0.0086v
                    • mon2
                      • Dec 2019
                      • 14271
                      Check the voltage to ground of pq998.
                      Next, remove all power. Meter in resistance mode. Check the resistance across pr309.
                      • xRaPiDxX
                        • Feb 2021
                        • 35
                        • Poland
                        Voltage to ground PQ998:
                        1-0.0086V
                        2-0.035V
                        3-GND
                        PR309- 31.82kohm
                        • mon2
                          • Dec 2019
                          • 14271
                          Check the voltage to ground of pr309. Check both sides.
                          • xRaPiDxX
                            • Feb 2021
                            • 35
                            • Poland
                            PR309
                            Pin 1 (PACIN) - 3.263V
                            Pin 2 (PACIN_G) - 0.0086V
                            • mon2
                              • Dec 2019
                              • 14271
                              Remove all power. Check the resistance to ground of pin #2 of pr309.
                              • xRaPiDxX
                                • Feb 2021
                                • 35
                                • Poland
                                Pin #2 of PR309: 128.30ohm
                                • mon2
                                  • Dec 2019
                                  • 14271
                                  Flux and remove pq998. Then check the voltage again on each side of pr309.
                                  • xRaPiDxX
                                    • Feb 2021
                                    • 35
                                    • Poland
                                    After removing pq998:
                                    PR309:
                                    1-3.259V
                                    2-0.0086V
                                    • mon2
                                      • Dec 2019
                                      • 14271
                                      Something is wrong in this region. Flux and remove pq307. Then check the voltage again on each side of pr309. The resistance to ground on the gate pin should not be so low.
                                      • xRaPiDxX
                                        • Feb 2021
                                        • 35
                                        • Poland
                                        After removing PQ307
                                        1-3.32 voltage to ground, 100.67kohm (no power)
                                        2-3.309 voltage to ground, 147.77kohm (no power)
                                        So do i need to find and replace PQ307?
                                        • mferna14
                                          Lenovo Flex 5 15IIL05 not turning on
                                          by mferna14
                                          Dear precious friends., I am working on a Lenovo Flex 5 15IIL05 (Motherboard LC55-15C 19792-1 448.0K105.0011). The problem with it, does not turn on at all. I see the battery charging LED but no response from the power button. Output coils 3.3V & 5v are perfect. LDO 3V is also present, I measured this on the power button. The on/off button is working perfectly. I re-programmed with new bin files & the status is still the same. I do not see any abnormal voltage & any Shorts or any kind of liquid spill. The MB is clean. I am using this schematics Lenovo Flex 5-14IIL05 19792-1, seems...
                                          03-15-2025, 11:31 AM
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
                                        • derradji89
                                          Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                          by derradji89
                                          Hi everyone 🤗
                                          I have a Lenovo MIX 320-10lCR computer.**
                                          1. **Operating System**: Windows 10 ** Education** 64-bit.
                                          2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                          3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                          4. **BIOS Chip Reflashing**: Currently,...
                                          04-19-2025, 03:04 PM
