Asus GU502DU - CPU fet dead, now no battery charging
  • down1nit
    • Oct 2016
    • 29
    I normally am able to search and repair by myself, but not on this one. Nice Asus laptop had a short on one of the dual fets feeding the cpu, lucky customer! The board works, boots ok, but the battery does not charge. I don't have a Laptop Battery Analyzer yet so I ordered a replacement. Now I'm 3 replacements deep and I'm out of ideas.
    Here are the measurements around BQ24780s that I know to get. this is on my bench supply set at 19.5 and the latest, best battery I have:
    ACN/P are both 19.5 and
    ACDRV is 25.46
    ACDET is present at 2.654
    ACOK is really high at 5.97V (too high? It's resistors measure ok so maybe the chip?)
    REGN is at 6.03 which seems SOMEWHAT normal to me? I am not sure.
    BAT+ is present at 13.10V
    bat clock is 3.3 and seems to go to 2.9 every half second. pulsing low?
    bat data is similar, pulsing as it were.
    BATDRV stays low at 13.13 although that voltage is higher than it was 2 minutes ago... is this a wait and come back thing... it's only pulling 20mA.
    I've looked for shorts everywhere I can think of.... I'm out of ideas but am ready to take measurements if anyone has some advice.
    Boardview and schematic are attached.
    13.15v now.
    [MOD EDIT] Schematic & boardview moved to new thread --> https://www.badcaps.net/forum/troubl...atic-boardview
  • mon2
    • 15863
    Re: Asus GU502DU - CPU fet dead, now no battery charging
    ACOK is often pulled up to the REGN pin.
    Measure the voltage to ground of the SRN and SRP pins.
    Post the measurements.
    • reformatt
      • Feb 2020
      • 1666
      You have checked PQ8901/8902 right? One of these goes short after a 19V rail overload, which causes battery charging to be disabled.
      • down1nit
        • Oct 2016
        • 29
        Got it, that makes sense. Good to check.
        SRP - ~40M to ground
        SRN - ~40M to ground
        .471 on diode mode SRN/P
        As much as I know how to check them. The resistances across pins are all megaohm range. Gates, sources, drains all seem fine in all directions. Diode mode (red on ground) shows .397 on AC_BAT_SYS which is right after PQ8902, which seems low-ish?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3682
          • slovakia
          • hard-enduro
          some times short on main rail, overload battery and damage battery circuit
          • down1nit
            • Oct 2016
            • 29
            I tried a couple other bq24780s from dead boards, they showed different symptoms that I didn't like so I put the original back on.
            I'll toy around with different chips, wouldn't be the first time a chip was partly broken internally. Thank you.
            • down1nit
              • Oct 2016
              • 29
              Reread what they said, yeah, on my 4th battery right now. Also, found a used BQ24780s and it has the exact same symptoms as the OG BQ did.
              • reformatt
                • Feb 2020
                • 1666
                Well battery should be charging unless it's being disabled via the EC through SMBUS.
                Maybe take a look at the DC jack as this is a common failure of Acer/Asus laptops. This one has an extra connection that indicates the jack is fully inserted. On other designs, this connection must be grounded to enable ACDET. However this one has some additional circuitry via PQ6004A/B to detect adaptor insertion. In fact, there is a short table there indicating charging is disabled if this is not present.
                So check ADP_INSERT_NG#. If it's low, then charging is disabled and system is throttled. When the jack is crook, you don't hear the short 'click' when you push it fully in. You could just short this line to ground to see if the battery will charge if the jack is U/S.
                • mon2
                  • 15863
                  The posted readings for SRN and SRP are resistance readings to ground and their diode mode readings, not voltage readings to ground.
                  Meter in dc volts mode (30v or higher is ok).
                  Apply the power adapter.
                  Measure the following carefully as the logic board is powered.
                  Red meter probe to SRN pin on the charger IC. Black meter probe to ground. What is the measurement?
                  Repeat with SRP pin on the charger IC and ground.
                  Then remove all power and with no battery.
                  Meter in lowest resistance mode.
                  Place one meter probe on SRN pin and other meter probe on the SRP pin. What is the total current path resistance for this battery charge circuit?
                  Post each measurement.
                  • down1nit
                    • Oct 2016
                    • 29
                    This was it. Hopefully my experience will allow other techs to find this circuit which was clearly printed, but ignored by me. I put a blob in between pins 1 and 2 on PQ6004 and the (third) battery is now charging at 3 amps and climbing. Reformatt, thank you. This is the first I've seen this circuit, I suppose my shop is not as high volume?!?
                    mon2 I love you.
                    Thank you as well. You asked me to plug in the adapter and I did not. Apologies. I do not have an adapter yet.
                    Notes:
                    I have been using my bench power supply the whole time, I scraped away some of the coating by PC6007 to solder my wire to. I have not been using the customer's power supply, as they did not bring it, and I do not have one with this barrel and pin configuration. I definitely do not have an official Asus branded adapter, and as such I will remedy this. I'll also grab a generic one to salvage the barrel, so I can cut it off and then clip into it with a power supply. Oftentimes the circuitry for Adapter detect can be found in the barrel, even on generic ones, however having a BRANDED OEM [super powerful] version of whichever barrel your customer's laptop takes is a good idea as well. I will remove the blob before testing with the customer's power adapter as it seems a useful circuit.
                    • reformatt
                      • Feb 2020
                      • 1666
                      I wasn't aware you were bypassing the connector entirely by soldering to the board. I must admit I didn't read your first post in depth, so missed the bench power supply reference. Had I registered, I would have been straight up recommending you don't go any further without a known good adaptor. HP's for example are really picky, so you need to go this route on future repairs as a sanity check.
                      The adaptor detection in this model is simply a connection shorted to ground via the barrel when the adaptor is fully plugged in. There are no smarts in the adaptor, unlike the Dell's which have a one-wire circuit. Some models have a FET that shorts out ACDET till this connection is grounded and turns off the FET. In both cases, it prevents full current/surges till the adaptor is fully seated in the plug. That's my assumption anyhow.
                      Anyway, trap for young players.
                      • down1nit
                        • Oct 2016
                        • 29
                        You're all right mate. It's a set up you've read hundreds of times, you were looking for the familiar or unfamiliar. I actually should know better, I'm not really new at this and I am embarrassed (but proud to have made an example for google searchers).
                        The adapter is absolutely part of the "equation" of board repair, in that it's sometimes variable.
                        Also I just read that sometimes the onewire resistor is in the tip, sometimes it's in the transformer box. This true? Guess I was lucky with mine.
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • Iherduleikgemz
                          Asus FX505DY - Battery not charging - BQ24780S
                          by Iherduleikgemz
                          Hello everyone
                          I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                          I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                          01-13-2025, 03:54 PM
                        • Julian Bailey
                          HP ProBook 445 G8 Battery not charging
                          by Julian Bailey
                          Hi all
                          We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                          The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                          I have gone around the board with a MM and cant find anything
                          Windows shows the battery fine,...
                          10-11-2024, 10:34 AM
                        • johnbeton
                          Asus X415EA not charging battery
                          by johnbeton
                          I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
                          So far I measured all the pins on the bq24780s controller with the following result:
                          1. ACN = 0.0V
                          2. ACP = 19.02V
                          3. CMSRC = 18.5V
                          4. ACDRV = 23.9V
                          5. ACOK = 5.9V
                          6. ACDET = 2.57V
                          7. IADP = 0.17V
                          8. IDCHG = 0V
                          9. PMON = ?
                          10. PROCHOT = 5.05V
                          11. SDA = 3.3V
                          12. SCL = 3.3V
                          13. CMPIN = 0.47V
                          14. CMPOUT = 6.0V
                          15. BATPRES = 0.0V
                          16....
                          05-19-2025, 04:05 AM
                        • kodox
                          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                          by kodox
                          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                          what i've done:
                          - flashing...
                          12-29-2024, 02:49 AM
