820-00244 Data Recovery
  • donnos
    • Sep 2016
    • 11
    • Malaysia
    i'm being tasked with data recovery with this dreadful mac12 which is famous for CPU issue.
    at the moment there is no CPU Vcore and power sequence stops at ALL_SYS_PWRGD with the following missing PM_PCH_PWROK
    anybody knows whats the criteria for PM_PCH_PWROK output from u7800? (no shorts on CPU side)
  • volinakis
    Chromebook recovery failed - how to fix it
    by volinakis
    So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
    Finally I found a site where they suggested to try with an older image and ... it worked!
    What I did:
    - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
    09-18-2023, 03:26 PM
  • myth77
    macbook pro a2141 can not make recovery
    by myth77
    So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
    So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
    06-19-2022, 11:21 AM
  • ugamazing
    820-00850 & 820-01949, No WiFi *In Recovery*
    by ugamazing
    I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
    1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
    2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
    01-25-2023, 05:39 PM
  • alfredposadas09
    cant enter recovery mode lenovo c13 yoga chromebook
    by alfredposadas09
    cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
    11-09-2024, 10:09 AM
  • conghuyms
    Macbook air m1 can't access the recovery options by pressing and holding the power button
    by conghuyms
    I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
    After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating,...
    10-14-2024, 06:43 AM
