pavilion 15 Y11A motherboard low ACDRV signal
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Greetings...
    Please, I need help in fixing the above board problem. The board number is DAY11AMB6E0 REV: E.
    0.8V is the voltage that was able to deliver into the system due to ACDRV being stuck at 0.8V. The system works when 19V is introduced to the PQ20 drain, but the battery does not charge.
    Below is the IC's reading when plugged in:
    1. 0.8
    2. 0.8
    3. 0.8
    4. 0.8
    5. 0
    6. 1.6
    7. 0.4
    8. 0.5
    9. 0.5
    10. 0
    11. 1.9
    12. 1
    13. 1
    14. GND
    15. 0
    16. 6
    17. 5.9
    18. 0
    19. 1
    20. 19.7
    There is no break between PR 211, 137 and the IC.
    Attached is the schematics diagram of the charging IC: BQ24738H
  • mon2
    • Dec 2019
    • 14342
    Re: pavilion 15 Y11A motherboard low ACDRV signal
    Remove all power -> remove PR22 off the logic board. Do not lose this 4k resistor.
    Power up again and check the voltage to ground of ACDRV pin of the charger IC. Measure directly at the charger IC pin.
    Post the measurement.
    • Zilicon
      • Nov 2020
      • 142
      • Nigeria
      The measurement is 0.8V
      • mon2
        • Dec 2019
        • 14342
        Measure the voltage on each side of PR16.
        • mon2
          • Dec 2019
          • 14342
          Fault in this area. This threshold voltage must be > 2v4 for the charger IC to detect the adapter. Then the ACDRV boosted voltage will follow.
          Remove all power. Meter in resistance mode.
          Measure the resistance of each resistor @ PR16 and PR213.
          Post each measurement.
          • Zilicon
            • Nov 2020
            • 142
            • Nigeria
            the voltage on PR16 resistor: 19.7 and 1.6
            • mon2
              • Dec 2019
              • 14342
              The final lower voltage @ 1v6 is not the correct voltage for ACDET. It should be higher and must be greater than 2v4 for the charger IC to detect a valid power adapter.
              Remove all power. Meter in resistance mode. Check the resistance of:
              PR16
              PR213
              Meter probes across each resistor to measure.
              One of these resistors is not the correct value and causing the lower ACDET voltage.
              • Zilicon
                • Nov 2020
                • 142
                • Nigeria
                The resistance of
                PR16: 499k, 69.9k
                PR213: 0, 69.9k
                • mon2
                  • Dec 2019
                  • 14342
                  I am not sure I am following the measurement readings.
                  Meter in resistance mode. No power to the logic board.
                  One meter probe to one pin of PR213; other meter probe to other pin on PR213.
                  Repeat for the other resistor.
                  Post the measurement. If you see '1' = over limit, then switch to a higher resistance scale on the meter. If you have an auto adjusting meter, then it is ok as-is.
                  • mon2
                    • Dec 2019
                    • 14342
                    Wait - is the battery connected? If yes, please remove it and measure again.
                    • Zilicon
                      • Nov 2020
                      • 142
                      • Nigeria
                      PR16: 430k, 230k (sometimes it will read 450k, 400k)
                      PR213: 69.9k, 67k
                      the above measurement was taken directly from the resistors, probes were swapped for readings. hat explains the double double readings. while previous readings taken was done with the com probe in ground.
                      • Zilicon
                        • Nov 2020
                        • 142
                        • Nigeria
                        Originally posted by Zilicon
                        The resistance of
                        PR16: 499k, 69.9k
                        PR213: 0, 69.9k
                        These were taken with the com probe in the ground.
                        No battery or power on the system
                        • mon2
                          • Dec 2019
                          • 14342
                          Ok. Carefully flux and remove resistor PR17 off the logic board. Do not lose this part.
                          We want to remove this part from the equation to see if the ACDET value changes.
                          Then power up with the adapter and check the voltage again @ ACDET pin.
                          Based on the resistor voltage divider calculator, if you have ~19v as input to PR16 and if the resistors are with a stable resistance, the voltage should be ~2v66 at ACDET.
                          It should not be 1v6. That is too low. If you still have this low voltage then recommend to replace at least PR16.
                          If you do not have these resistor values, we can try to work out with other values.
                          • Zilicon
                            • Nov 2020
                            • 142
                            • Nigeria
                            The ACDET changed.
                            it increases to 2.7V ACIN on pin no 5 now has a voltage, 2.9V at PR217
                            • mon2
                              • Dec 2019
                              • 14342
                              Very good -> check the ACDRV pin now.
                              • Zilicon
                                • Nov 2020
                                • 142
                                • Nigeria
                                the ACDRV remains at 0.8V. it remains the same after PR22 removal.
                                • mon2
                                  • Dec 2019
                                  • 14342
                                  What is the voltage to ground @ ACDET pin # 6 of the charger IC ?
                                  • Zilicon
                                    • Nov 2020
                                    • 142
                                    • Nigeria
                                    @ACDET pin has 2.7V after PR17 was removed.
                                    • mon2
                                      • Dec 2019
                                      • 14342
                                      Post a fresh list of measurements of the charger IC.
                                      At this point ACDRV should return to ~25v so the charger IC may be defective and needs to be replaced but let us review your new list.
                                      • Zilicon
                                        • Nov 2020
                                        • 142
                                        • Nigeria
                                        Thank you so much @mon2, I just had it resolved now. thank you a million times.
                                        what happened was that PQ35 pin 1 which is GND was absent. Hence, there was voltage at the pin, and pin 3. so I created a ground for the pin. That solves the problem.
                                        thank you so very much.
                                        • Fernon@Repair
                                          MSI mpg b560m bazooka motherboard RSMRST# signal missing
                                          by Fernon@Repair
                                          I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
                                          My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
                                          VCCRTC ok
                                          RTCRST# ok
                                          ATX_5VSB ok
                                          SIO_3VA ok
                                          3VDSW ok
                                          DPWROK ok
                                          SLP_SUS# ok
                                          VSB_ENABLE# ok
                                          5VDUAL ok
                                          3VSB showing 4.17V
                                          PCH_1P8_VSB ok
                                          PCH_VCCIN_AUX ok
                                          RSMRST# No voltage
                                          this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
                                          06-03-2025, 10:49 AM
                                          HP Pavilion Pavilion Laptop 14-dv2514sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2514sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2514sa boardview and Pavilion Laptop 14-dv2514sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv0631sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0631sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0631sa boardview and Pavilion Laptop 14-dv0631sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2500sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2500sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2500sa boardview and Pavilion Laptop 14-dv2500sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
