A1466 820-000165-A with low PP3v42
  • bridges_4u
    • Feb 2014
    • 105
    • india
    #41
    Re: A1466 820-000165-A with low PP3v42
    Hi mon2,
    I have placed an order for the resistors and will arrive in 7 days. Will post an update once received.
    • mon2
      • Dec 2019
      • 14097
      As per suggestion by @Piernov, the output of this regulator is very close to the target value. You should be fine to continue as-is. The voltage is only off by 0.03 volts.
      Place back the fuse at ppbus_g3h if it was removed and proceed to test this logic board again.
      • bridges_4u
        • Feb 2014
        • 105
        • india
        #43
        Hi mon2,
        Thank you for your reply. I just saw your reply now. The part would arrive in a day or two. Would you want me to change it and then continue or continue as is?
        • mon2
          • Dec 2019
          • 14097
          You should be ok to continue with the voltage as-is since the difference is very small from the target value.
          If you have removed the PPBUS_G3H fuse, apply it back and check the voltage to ground of PPBUS_G3H.
          • bridges_4u
            • Feb 2014
            • 105
            • india
            #45
            Hi mon2,
            Before I connected the fuse, I checked the PP3v42 line again for the voltage, it is 3.371V which I believe is low and think that the resistors needs to be changed before putting back the fuse. What do you think?
            • mon2
              • Dec 2019
              • 14097
              Yes, to me, this is low. Measure the resistance of the fresh resistors before soldering them onto this board. Double check the soldering after they are on the PCB. Then power up to check if the voltage is higher.
              • bridges_4u
                • Feb 2014
                • 105
                • india
                #47
                Hi mon2,
                Sure. Will do and keep you posted.
                • bridges_4u
                  • Feb 2014
                  • 105
                  • india
                  #48
                  Hi mon2,
                  The resistors came in today. Changed R7095 & R7096. Now L7095 shows 3.3998 V. I reconnected F7140 and check for PPBUS_G3H. PPBUS_G3H is 8.09V. Any pointers?
                  • mon2
                    • Dec 2019
                    • 14097
                    Check the voltage to ground of SMC_RESET_L.
                    • bridges_4u
                      • Feb 2014
                      • 105
                      • india
                      #50
                      Hi mon2,
                      Just one more thing. When i check PPBUS_G3H it shows at 8.15V and then rolls down to 8.09V. I shall post SMC_RESET_L shortly.
                      • bridges_4u
                        • Feb 2014
                        • 105
                        • india
                        #51
                        SMC_RESET_L is 3.361 V.
                        • mon2
                          • Dec 2019
                          • 14097
                          Remove the fuse on ppbus_g3h again and check if this rail remains stable or not.
                          • bridges_4u
                            • Feb 2014
                            • 105
                            • india
                            #53
                            Hi mon2,
                            With F7140 removed,the voltage roll down is still happening at PPBUS_G3H. 8.15 V - 8.09 V.
                            • bridges_4u
                              • Feb 2014
                              • 105
                              • india
                              #54
                              Hi mon2,
                              The voltage roll over is still happening without the fuse.
                              • mon2
                                • Dec 2019
                                • 14097
                                Do not have the schematic in front of me but check the current sense resistor on this same rail used by the ISL device. Remove all power. Believe it is R7050.
                                Meter in lowest resistance scale.
                                Measure the resistance from the ISL pin on one side of the R7050 and with meter probe on the other side of R7050. Be sure to check at the ISL pins.
                                We are confirming that the start to finish trace for R7050 is valid.
                                What is the measured resistance? Is the value the same as shown in the schematic?
                                • bridges_4u
                                  • Feb 2014
                                  • 105
                                  • india
                                  #56
                                  Hi mon2,
                                  The current sense resistors R7121 & R7122 were missing. Replaced those. But still the voltage rolldown is happening. Any suggestions? ISL? There is no green light on the charger as well.
                                  • mon2
                                    • Dec 2019
                                    • 14097
                                    Check that the pogo pin contacts are clean on your paddle (LIO) board that mates with the magsafe adapter. This is very important. Recommend to use a cotton swap or similar with alcohol to clean up each contact.
                                    Also attempt to power up the logic board without a battery. Does this allow for the magsafe light to turn on?
                                    Check that the bridge cable between the main logic board and this LIO board is solid and with no corrosion. These cables are relatively low cost to replace (821-1722-A).
                                    • bridges_4u
                                      • Feb 2014
                                      • 105
                                      • india
                                      #58
                                      Hi mon2,
                                      The bridge cable looks good. The contacts also look good.
                                      • bridges_4u
                                        • Feb 2014
                                        • 105
                                        • india
                                        #59
                                        Hi mon2,
                                        Checked the bridge cable as well.Looks good. Any suggestions?
                                        • mon2
                                          • Dec 2019
                                          • 14097
                                          1) check the voltage to ground of the smbus pins used on the isl side that creates ppbus_g3h. These pairs are used by the SMC as well for communication of the ppbus_g3h voltage.
                                          2) remove all power. Meter in resistance mode. Measure the resistance to ground of each inductor. Looking for low resistance readings.
                                          Post each measurement.
                                          • psdavid65
                                            A1466 820-3437-B Bios Problem
                                            by psdavid65
                                            I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
                                            06-18-2024, 05:26 AM
                                          • Sergio Kub
                                            MAcbook Air A1466 EMC 3178 - 2017 Boot
                                            by Sergio Kub
                                            Could someone help me?
                                            I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
                                            Could it be the BIOS?
                                            07-08-2025, 04:41 PM
                                          • Sergio Kub
                                            Macbook Air A1466 EMC 3178 - 2017 Boot
                                            by Sergio Kub
                                            07-08-2025, 04:12 PM
                                          • dbuergi
                                            Need assistance for reballing / replacing i5 CPU on a Macbook A1466
                                            by dbuergi
                                            i have some A1466 logicboards for gaining soldering and electronic experience. One board has a dead CPU and since i have several spares i want to change it. Unsoldering it was no problem but heat from the top showed that the CPU bent. I think too much heat was the problem.
                                            So for unsoldering my spare parts and soldering back i would ask for some advises.
                                            On most youtube videos you don't get any temperatures. Only helpfull video was one where the heat came from the bottom.
                                            I have a small USB heating plate and a Atten ST-862D with several nozles.
                                            06-27-2025, 02:59 AM
                                          • myth77
                                            A1369 and A1466 top case housing the same?
                                            by myth77
                                            I didnt know where to ask (on what topic) but does anyone know can i use macbook air A1369 TOP CASE (with or without palmrest and keyboard) on A1466? they look the same but i am not sure. On aliexpress they sell them as same but on some places they sell only a1466 for a1466. anybody knows? Maybe the case/housing is the same but keyboard and touchpad different? but if thats the case i would change them..
                                            08-06-2022, 10:06 AM
