A1466 820-000165-A with low PP3v42
  • mon2
    • 14667
    Re: A1466 820-000165-A with low PP3v42
    Yes.
    • bridges_4u
      • Feb 2014
      • 128
      • india
      Hi mon2,
      The results are the almost same. The voltage at L7095 is 0.270V.
      • mon2
        • 14667
        What is the input voltage on pin #6 of this regulator?
        • bridges_4u
          • Feb 2014
          • 128
          • india
          HI mon2,
          It is 14.3V.
          • mon2
            • 14667
            Reflow the regulator chip. Use flux.
            • mon2
              • 14667
              Also, remove all power. Meter in resistance mode.
              Check the resistance to ground of this output inductor.
              If there is no short or low resistance then review the resistance of the feedback resistors on this regulator. Do not, repeat do not remove the resistors but check their values. These resistors will define the output voltage.
              Do the measurements of the resistors match the schematic values?
              • bridges_4u
                • Feb 2014
                • 128
                • india
                #27
                Hi mon2,
                R7080 was missing on the mobo. Replaced it. The voltage has come up to 3.371V which is not near to the ideal 3.425V. I am yet to check the other resistors.
                • bridges_4u
                  • Feb 2014
                  • 128
                  • india
                  #28
                  R7096 - 143.1 kohms
                  R7095 - 163.5 kohms
                  The resistance to gnd on output of L7095 is cycling from 3.3 KOhms to 2.6 Mohms and over again. What could be happening? The only component off the board is C7090.
                  • mon2
                    • 14667
                    Remove all power. Apply flux and remove r7095 or slightly shift the part with low air pressure so it is one one pad only. Do not lose the part. Measure it's resistance. Use low air pressure!
                    Then repeat to test R7096.
                    See the formula on how the resistors affect the Vout.
                    Vout = 1.25V * (1 + Ra / Rb)
                    If these resistors are lost, do not power up else the Vout will spike and the board will be killed.
                    • bridges_4u
                      • Feb 2014
                      • 128
                      • india
                      #30
                      Hi mon2,
                      • mon2
                        • 14667
                        Do not worry about this swing. Assorted components will charge and discharge during the resistance checks and impact the final value.
                        The key point is that this resistance is not considered to be low. The max current out of this regulator is 300mA so it cannot support a very low resistance of a load at the output.
                        Focus on the feedback resistor values. Be sure their values make sense so best to remove and check each when they are out of circuit. Do the check one part at a time. If out of range, they will affect the output voltage.
                        Again, double check that both are not removed after this work else the board will be killed.
                        • bridges_4u
                          • Feb 2014
                          • 128
                          • india
                          #32
                          Here are the reading of R7095 & R7096 after being disconnected.
                          R7096 - 202 KOHMS
                          R7095 - 347 KOHMS
                          • mon2
                            • 14667
                            What is the resistance to ground at L7095, pin #2 ?
                            • bridges_4u
                              • Feb 2014
                              • 128
                              • india
                              #34
                              Hi mon2,
                              • mon2
                                • 14667
                                So output is not shorted.
                                Most regulators have a minimum input capacitance requirement for stability of the regulator.
                                Check if the voltage to ground is stable at the input pin #6 of this regulator.
                                • bridges_4u
                                  • Feb 2014
                                  • 128
                                  • india
                                  #36
                                  Hi mon2,
                                  The voltage at pin 6 of U7090 is 14.02V and is stable.
                                  • mon2
                                    • 14667
                                    Suggest to purchase fresh resistors @ 1% tolerance or to remove from a donor board for testing.
                                    R7096 - 202 KOHMS
                                    R7095 - 347 KOHMS
                                    Replace the FB resistors @ R7095 & R7096.
                                    With the measured values, the
                                    = 1.25V * (1+347/202)
                                    Vout = 3.397 volts.
                                    • bridges_4u
                                      • Feb 2014
                                      • 128
                                      • india
                                      #38
                                      Hi mon2,
                                      I do not have any donors lying around. When it comes to buying it, the tolerance i can get hold of is 5%. can it be used?
                                      • mon2
                                        • 14667
                                        It is best to purchase 1% tolerance - it should be available in your local markets but 5% will have to do as a backup.
                                        Purchase the values noted in the schematic and then test again. Measure the resistor value before stuffing onto your PCB.
                                        If you stuff the values shown in the schematic into the equation, the Vout should be 3v42.
                                        • piernov
                                          • Jan 2016
                                          • 4439
                                          • France
                                          #40
                                          5% tolerance will obviously make it worse. 0.05V difference isn't a lot, that said PP3V42_G3H is indeed more accurate than this usually but probably not worth adjusting feedback for that.
                                          • psdavid65
                                            A1466 820-3437-B Bios Problem
                                            by psdavid65
                                            I received a 2013 Macbook Air A1466 A1466 820-3437-B motherboard WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?
                                            06-18-2024, 05:26 AM
                                          • dimis1975
                                            Macbook A1466 2014 not charging with macsafe 2 charger
                                            by dimis1975
                                            I have a macboook air a1466 that stopped charging the battery.
                                            BAT PINS: with or without ADAPTER IN
                                            1- GND
                                            2- GND
                                            3- GND
                                            4-0V sense pin
                                            5-3.42V
                                            6-3.42V
                                            7- 8.4V
                                            8- 8.4V
                                            9- 8.4V
                                            AC Adapter plugged in: after a lot of of hours some times start charging
                                            No BAT Connected- Green to Orange
                                            AC Adapter plugged in: BAT Connected- no light
                                            The strange thing, when I tried a mac charger usb-c with usb-c to macsafe 2 adapter works normally and charging.
                                            Any ideas what’s wrong please?...
                                            08-05-2025, 03:43 AM
                                          • Sergio Kub
                                            MAcbook Air A1466 EMC 3178 - 2017 Boot
                                            by Sergio Kub
                                            Could someone help me?
                                            I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
                                            Could it be the BIOS?
                                            07-08-2025, 04:41 PM
                                          • Sergio Kub
                                            Macbook Air A1466 EMC 3178 - 2017 Boot
                                            by Sergio Kub
                                            07-08-2025, 04:12 PM
                                          • dbuergi
                                            Need assistance for reballing / replacing i5 CPU on a Macbook A1466
                                            by dbuergi
                                            i have some A1466 logicboards for gaining soldering and electronic experience. One board has a dead CPU and since i have several spares i want to change it. Unsoldering it was no problem but heat from the top showed that the CPU bent. I think too much heat was the problem.
                                            So for unsoldering my spare parts and soldering back i would ask for some advises.
                                            On most youtube videos you don't get any temperatures. Only helpfull video was one where the heat came from the bottom.
                                            I have a small USB heating plate and a Atten ST-862D with several nozles.
                                            06-27-2025, 02:59 AM
