HP 17 DAY11AMB6E0 revE problem
  • baddjavo
    • Jun 2018
    • 88
    • Serbia
    Yesterday i got hp 17inch laptop, no power wont start. Dead.
    After pressing pwrbtn 3x blinks white led on dc connector.
    No 3.3v, no 5v because nothing on enable pin 1.
    s5_on signal missing.
    LDO 3.3v on pin 5 and LDO 5v on pin 7 outputs are good.
    pwrbtn 3.3v good.
    schematics and screenshots attached.
  • mon2
    • Dec 2019
    • 14259
    Re: HP 17 DAY11AMB6E0 revE problem
    Review the charger IC @ PU1.
    Meter in DC volts scale (20v or higher is ok).
    What are the voltage to ground measurements for the following?
    REGN (pin 16)
    ACDRV (pin 4)
    ACDET (pin 6)
    ACPRES (pin 5)
    • baddjavo
      • Jun 2018
      • 88
      • Serbia
      dcin 20v.
      REGN (pin 16) 6.00v
      ACDRV (pin 4) 20v
      ACDET (pin 6) 2.68
      ACPRES (pin 5) 2.96
      • mon2
        • Dec 2019
        • 14259
        ACDRV (pin 4) 20v its ok
        ACDRV is not ok. The 2 x DCin mosfets are N-channel type.
        To enable the N-channel mosfets, the GATE voltage must be higher than the voltage being passed between source / drain pins.
        If @20v, the gate voltage is the same. A good voltage should be ~25 volts on the gate pin.
        As it is common, often the 2nd DCin mosfet is leaky.
        Remove all power. Meter in resistance mode.
        Measure the resistance across the mosfet pins as follows:
        PQ20:
        Pin 3 & 4
        Pin 3 & 1
        Pin 1 & 4
        Measure and post each reading for the DCin mosfets.
        Update:
        Remove PR22 resistor on ACDRV.
        Power up again.
        What is the voltage to ground of the PR22 PCB pad pin connected to ACDRV?
        • baddjavo
          • Jun 2018
          • 88
          • Serbia
          For some reason i cant measure pin 4, its varies. But voltage on pq20 gate pin is 25V. pq20 should be fine.
          Previosly i measured pin3, its 20V. My mistake
          "Do Not add test pad on BATDIS_G signal" why is that ?
          PQ20:
          Pin 3 & 4 0.7 M
          Pin 3 & 1 4.3 M
          Pin 1 & 4 inf
          if u insist i will remove PR22 and measure voltage on pin 4
          • mon2
            • Dec 2019
            • 14259
            If you have 25V, you are fine on the gate.
            • baddjavo
              • Jun 2018
              • 88
              • Serbia
              mon2, do u have any idea what next ? Missing s5_on signal. Maybe clock generator is bad dunno how to check.
              • mon2
                • Dec 2019
                • 14259
                Review if there is a possible shorted component on the board.
                Check the resistance to ground of each coil / inductor on the logic board. A low resistance may indicate a shorted part causing the power supply to shut off.
                Aside from the above, you may have a corrupt bios. Often there is a main bios and a lower density bios for the EC chip. Each can be corrupted and you must load the proper version for your board. Not my area of experience so wait on other comments but start with the power rail review and confirm no caps are shorted.
                No power during the resistance checks.
                • baddjavo
                  • Jun 2018
                  • 88
                  • Serbia
                  No shorts. Checked all main of coils, and some minor coils.
                  No power on bios chip, there is 3.3v on EC chip U11 on pins 26,50,92,114,121,106;
                  except +3V not present on pin 11.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    EC_RST/RSMRST#/EC_PWROK present? THRM_ALERT checked?
                    • baddjavo
                      • Jun 2018
                      • 88
                      • Serbia
                      NBSWON1# pin 107 - 3.2V
                      LID_EC# pin 123 - 3.3V
                      EC_WRST pin 14 - 3.3V
                      RSMRST# pin 119 - zero
                      THRM_ALERT pin 80 - 3.2V
                      EMU_LID pin81 - zero
                      EC_PWROK pin 20 - zero
                      ACIN pin 97 - 3.3V
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        R189-voltage on both pin 1 & 2?
                        D6-Voltage on both pin 1 & 2?
                        iT SEEMS MB IS STUCK IN THERMAL ALERT.
                        • baddjavo
                          • Jun 2018
                          • 88
                          • Serbia
                          D6 pin2=0.2v, pin1=zero.
                          R189 0.2v diode side, other side 0.48v
                          How its possible any voltage coz that voltage coming when 3.3v and 5v regulator, after s5_on....
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Yes,no voltage on both pins of D6 is correct. Are you getting 3.3V on pin1 & 3 of Q16 and zero on pin2?? If this is so, Thermal circuit is fine.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Have you flashed known good clean me bios?? Whats the status of AD_ID?
                              • baddjavo
                                • Jun 2018
                                • 88
                                • Serbia
                                changed adapter ... motherboard working, all voltage present CPU, MEM...
                                BUT no picture ))
                                • baddjavo
                                  • Jun 2018
                                  • 88
                                  • Serbia
                                  Thank you mcplslg123 u gave me hope.
                                  Tried multiple displays, cleaned flat cable. Nothing.
                                  pin40=3.3V, pin1,2=19.5v, pin4=zero
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Pin4 of edp connector shouldnt be zero but these voltage will be present only when mb is posting. Are you sure mb is posting? Easiest way to check is plug a usb keyboard and check if numlock key glows on toggling it. If numlock is glowing, mb is posting and we can proceed to troubleshoot display issue. If otherwise, problem lies elsewhere and we can proceed in that direction. confirm us with your observation.
                                    • baddjavo
                                      • Jun 2018
                                      • 88
                                      • Serbia
                                      numlock working, glowing and toggling !
                                      • baddjavo
                                        • Jun 2018
                                        • 88
                                        • Serbia
                                        correction !
                                        pin40,pin39 = zero
                                        pin38, pin37, pin36 = 3.3v
                                        pin1,2 = 19.5v
                                        pin4 = zero
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • SDNarcia
                                          Dell 15R-5521 keyboard problem (KBC?)
                                          by SDNarcia
                                          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                          As additional information,...
                                          07-20-2024, 10:47 PM
