Dell Inspiron 7306 Hellcat 13 TGL MB - No Power
  • speggio91
    • Apr 2020
    • 83
    • Italy
    Hello all, sorry for the double post (i've posted this question on another thread of schematic request).
    i'm working on this board that doesn't have any power at all, the usb-c ammeter stay off and the thermal camera doesn't show anything heating up.
    I have no experience with usb-c powered boards, but I know there's a thunderbolt chip negotiating with the power supply and the power management chip.
    Could it be the intel jhl8040r thunderbolt controller (U7101) to be dead?
    Probing the caps around it i didn't find anything shorted.
    Can someone give me some hint to start hunting for the probable issue with this board please?
    I know I didn't give many informations but judging by the fact that neither the usb-c meter is turning on made me thing about the thunderbolt chip.
    Thanks to anyone that will contribute
  • mon2
    • 14201
    Re: Dell Inspiron 7306 Hellcat 13 TGL MB - No Power
    Confirm that the type c power adapter is working and test your type c meter to confirm again that both are working as a team.
    Do you see the power up default of 5 volts on your type c meter?
    Then insert this combination into your logic board. If the meter goes dark, then you have a short condition on the logic board.
    Power cycle everything that is connected and flip the USB C connector by 180 degrees. This will test the other side of the type c interconnect.
    What are the results after flipping the power connector head?
    • speggio91
      • Apr 2020
      • 83
      • Italy
      Thank you very much!
      Both usb-c power supply and meter are working well, I've tested them on other usb-c powered devices such as Macbook air, hp laptops and they delivered the power needed by those devices.
      The default behaviour of the Usb-c power supply I have is that even after I plugged it into the power outlet and connected the ammeter, it won't deliver any voltages until I have plugged it into the device. So in every case, the usb-c meter won't be powered on at all until it will be connected to the devices usb-c port.
      In the case of this Dell laptop, the screen of the meter stay off and it won't show any voltages, neither 5 volts.
      I know that the ammeter is not powered on because it's not emitting any beeping sound that is typically heard when the power start flowing through it, into the usb-c laptop.
      I've checked also that the power supply is capable of delivering the requested voltage and it is, it matches the 20V 3.25A of power needed by that dell. It's not the original power brick that came with the laptop but i will probably ask the owner to give it to me just to be sure it's not just a power adapter issue that need a specific chip to negotiate the voltage to the laptop board.
      I've removed the motherboard from the case and flipped the usb-c connector with no changes on the final result, still no sign of life or power.
      • mon2
        • 14201
        Remove all power. Meter in DIODE mode.
        Red meter probe, yes red to ground.
        Black meter probe to the CC1 line of the TPS power delivery chip.
        What is the reading?
        Repeat for the CC2 line.
        These 2 lines are used to detect if the power adapter is mated or not and are used to extract and negotiate the power delivery contracts from the adapter.
        • speggio91
          • Apr 2020
          • 83
          • Italy
          I've probed on diode mode pins 46 and 44 of U7202 and..
          pin 46 show 0.00V, pin 44 0.025V
          I also probed some other pins (1, 9, 11, 45) and all of them measure 0.00V
          Does it mean the PD chip is dead?
          I've measured also ED7301 until ED7308 and all of them are above 0.500V in diode mode.
          I wasn't able to find on the board C7213 and C7208.
          What should be the next step? Power injection in one of the shorted pins of the PD chip to see what does heat up or remove the chip to measure those pins again?
          • mon2
            • 14201
            ED7307 and ED7308 should report the same readings as what you measure at the connector pins.
            Can you confirm the readings again?
            The diode readings do not show a fault but the connector readings are common to a short.
            • speggio91
              • Apr 2020
              • 83
              • Italy
              I confirm you that the readings on ED7307 and ED7308 are 0.00V and 0.025V, earlier I wasn't able to find those components on the board and I assumed that they were located right next to U7020 but intead they were in another position. So the reading I reported earlier weren't the right ones.
              • mon2
                • 14201
                Ok - with care - remove ED7307 and ED7308 off the logic board. Flux and low air pressure.
                It is possible that an ESD transient event has killed these ESD diodes on the CCx lines. By removing these parts, you can check again if the diode readings improve or not.
                If the diode readings remain the same, then will conclude that the power delivery controller is defective.
                Keep these diodes in case they are still ok.
                • speggio91
                  • Apr 2020
                  • 83
                  • Italy
                  Removing ED7307 and 7308 didn't change the reading, but removing C7208 (it's in parallel with ED7308) the reading on pin 46 changed to 0.020V.
                  During the resoldering process of the diodes unfortunately ED7308 slipped away from the tweezers and cannot be found again.
                  The situation now is, both ED7307 and C7213 are soldered back and pin #44 still reads 0.025V.
                  If i solder back C7208 the reading of pin #46 goes to 0.00V.
                  Measuring C7208 in resistance mode, give me OL. With the capacitance function the value is 0.419 nF.
                  Are those diodes meant to protect the PMC from ESD discharges?
                  • speggio91
                    • Apr 2020
                    • 83
                    • Italy
                    I desoldered U7202 and took some measurements.
                    The pin #8 that should be the one that generate 3.3V on S5 state has 3.5 Ohm to ground resistance which it seems quite low, isn't it?
                    I've tried to inject 3V and immediately PU5302 get hot.
                    Measuring PIN #6 (that is part of the 5V_S5 line) of PU5302 show me a resistance to ground even lower, 2ohms.
                    Both PC5311 and PR5301 are fine, no short to ground was detected.
                    Do you think that those 2 lines 3.3V S5 and 5V S5 are really shorted to ground?
                    Should I try to replace U7202 ignoring those resistance values?
                    I'm afraid the the issue is more extended than what it seemed..
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • Scaff
                      Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
                      by Scaff
                      I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
                      06-08-2025, 01:46 AM
                    • zlr8r
                      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                      by zlr8r
                      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                      Ill try and give as much info as I can.
                      Dell Inspiron 17 (7786) Laptop
                      Service Tag: 5J0NHT2
                      Bios: 1.9.0
                      When I received this , it would only flicker on the KB backlight for a second, then off and on.
                      Then it started getting weirder!
                      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                      12-12-2023, 09:31 PM
