X540UBR REV 2.0, No Power
  • Jmine
    • Dec 2022
    • 52
    • Sri Lanka
    The 3v/5v IC (2n5bto7) was getting hot when connected to PSU and I measured the resistance to the ground of every pin.
    phase2 pin and vclk were shorted to the ground. to determine the direction of the short, I disconnected the coil which was connected to phase 2 and the short was not from the IC, but from the power rail.
    I injected 1V to see what was getting warmer, about 500mA current draw was observed and The PCH side of the SoC is getting warmer.
    I have 2 Questions for you guys,
    Is the vlck low resistance to the ground normal?
    It is safe to assume that the PCH is Done?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: X540UBR REV 2.0, No Power
    If PCH part of SOC is getting hot at 1V injection and consumption of 500mA does indicate a shorted PCH.
    • Jmine
      • Dec 2022
      • 52
      • Sri Lanka
      Does that mean when injecting voltage a good pch must not get warm at all?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        It may get a little hot. Its the consumption on dc supply which indicates whether its shorted or not. there is no fix scale to declare a pch shorted.
        • barry101
          Apple 820-3662 VCore shorted to ground.
          by barry101
          Hi, Would appreciate some help.
          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
          Get charger light but no fan spin or chime. No liquid damage.
          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
          Today, 07:34 AM
        • Chaks
          Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
          by Chaks
          TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
          The specs says ...
          High antenna efficiency 868MHz ISM Band
          5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
          The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
          1. Should I Fix it with a glue.
          2. Should I fix it with a double side adhesive tape
          3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
          12-09-2024, 11:06 AM
        • Rolin
          Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
          by Rolin
          Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
          10-30-2022, 10:18 PM
        • loopster
          645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
          by loopster
          Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
          This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
          Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
          My resistance value is 2.2 Ohms, which doesn't look good to me.
          Thanks to everyone willing to give a value.​
          06-05-2025, 02:33 PM
        • playit
          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
          by playit
          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
          09-02-2023, 02:43 AM
