ASUS GA401QM Missing 5v
  • ResoluteHawk
    • Nov 2021
    • 153
    Hello;
    I have an ASUS G14 GA401QM that currently has no 5v rail among other things stated below in points #3 and #4. I'd like to see if it's condition can be improved.
    1) Originally this laptop had a problem with a shorted main power rail, so measuring at the current sense resistor after the DC IN FETs yielded a very low resistance. Before proceeding further I measured the CPU coils. We get 8.2 Ohms on the farthest right coil (PL8105) and 3.3 Ohms on the four to left left of it (PL8101 through PL8104). When I injected 1v into the current sense resistor, PQH9402 got warm. I removed it and the short disappeared. Replaced it and the short is still gone.
    2) Plugging in the power adapter yields no charging light so I disconnect the power. Measuring at the current sense resistor yields a short again. I go back to PQH9402 and measure Pin 1. We're shorted again. I measure PQH9404 and that one is ok. Taking PQH9402 off the board again relieves the short. I have yet to replace it again because clearly something else is wrong.
    - PQ9404: Pin #1 in resistance mode measures 3.08 MOhms and in diode mode measures 0.594v drop.
    - Where PQH9402 should go: Pin #1 in resistance mode measures 15.55k Ohms and in diode mode measures 0.315v drop.
    3) This is where I measured the resistance on the 3.3v and 5v coils. The 3.3v rail at PL8702 measures 3.4k Ohms. Measuring Pin #8 on the BIOS chip in diode mode reads 0.133v drop however reads 595 Ohms in resistance mode, when it should be in the kOhms.
    4) The 5v coil at PL8701 measures 12.9 Ohms and the coils for the VRAM right next to it at PL9402 and PL9401 measure 14 Ohms. This is about half of what it should measure.
    I don't know where to go next although I have a few pointers to what the issue might be. I suspect it's either a) The EC, b) a VRAM module, c) the GPU itself, or d) A failing PCH.
    In any case, it seems like the 5V rail is out with a kill list unless I'm missing something and it's actually another rogue voltage rail.
    Schematic and boardview are attached.
  • Sephir0th
    • Oct 2020
    • 1282
    Re: ASUS GA401QM Missing 5v
    First, it is strongly advised to always change the complete buck converter, so high-side, low-side, controller and driver (if present). That's a unwritten rule.
    Then, if the 5V Rail is affected you might deal with multiple defective semiconductors. That's a common outcome when dealing with a shorted +5VALW or +5VS.
    However, first suspect should be of course the controller which control the repeatedly blown mosfet (didn't check the schematics so far).
    And then we'll see whether there is more.
    FairRepair on YouTube
    • ResoluteHawk
      • Nov 2021
      • 153
      I'm not 100% sure of the problem at this point, but it looks like the EC might be the culprit. I'll have to do some more looking around before I take it off.
      • ResoluteHawk
        • Nov 2021
        • 153
        If I measure the capacitors around the EC chip, the ones on the EC Power circuit are all shorted to ground (1 Ohm on C3002, C3003, C3004, C3005, C3006, C3007).
        C3008 however measures 2.27k Ohms and a 0.317v drop.
        Is it safe to say that the EC is screwed at this point?
        • Sephir0th
          • Oct 2020
          • 1282
          My friend, you either ask for assistance and follow the advice or you just do "your thing". Both at the same time does not work, and I can't assist this way.
          Buy yeah, the EC could be bad in addition.
          • ResoluteHawk
            • Nov 2021
            • 153
            Ok I just removed the EC chip.
            Changes:
            The capacitors on the EC Power circuit are no longer shorted to ground (they all measure in the K Ohms).
            C3008 now measures 0.636v drop and 26.4k Ohms
            No changes:
            PL8701 is still at 13 ohms.
            Coils for GPU memory are still at 15 Ohms.
            • ResoluteHawk
              • Nov 2021
              • 153
              BIOS chip on Pin #8 now measures about 1.8k Ohms.
              • reformatt
                • Feb 2020
                • 1406
                It's not normal to have this many faults simultaneously. What is the background of the laptop? Simultaneous issues on multiple power rails are usually the result of something external like a power surge so you may have other issues beyond this.
                Could be a big time waster.
                • ResoluteHawk
                  • Nov 2021
                  • 153
                  Could be.
                  The guy said that he was trying to change the RAM and it wouldn't turn on afterward. He went to reinstall the factory RAM and nothing changed.
                  • reformatt
                    • Feb 2020
                    • 1406
                    Hard to believe TBH.
                    • ResoluteHawk
                      • Nov 2021
                      • 153
                      I think I'm just going to call this board a "no fix."
                      Looks like the short may have gone all the way through to the GPU memory modules and into the GPU (resistance on GPU video memory modules is now 9 Ohms after removing EC).
                      • reformatt
                        • Feb 2020
                        • 1406
                        Yeh, multiple faults across different rails, and a dead EC makes you wonder what happened. Especially when a complete dickhead has had his hands in there. Be a no fix from me as there's likely to be more dead pieces of silicon (maybe dead PCH/CPU/GPU).
                        People like that think nothing of wearing a wedding ring and scraping it across a board with battery connected for example.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          @reformatt the last part of your comments on post#12 is a classic one.
                          • ResoluteHawk
                            • Nov 2021
                            • 153
                            Ok so I have an update and think I know what happened. I've been working on other laptops and decided to have another crack at this after thinking about it.
                            My theory:
                            The previous owner tried reinstalling his RAM but forgot to disconnect the battery before doing so and when he installed the new RAM it destroyed the SIO chip and shorted out one of the GPU memory drivers and the Audio IC on the 5V rail.
                            When I plug in power to the laptop and look at the board under my thermal camera, the Audio IC gets extremely hot (~350 F) and I see the 5V coil getting warm (80 F). I still haven't replaced that GPU memory driver that I had previously removed.
                            The interesting thing is that all of the main power rails are being generated, the CPU VCore is healthy, and GPU memory isn't shorted to ground. My previous post where I mentioned the GPU memory being 9 Ohms was after I applied heat to the board and removed a faulty component. I didn't realize that it took a while for it to return to it's normal resistance. It's Samsung memory so the resistance on it is going to be lower (~20 Ohms). I still get 1.8v on the BIOS chip when power is plugged in and the chip isn't shorted to ground on Pin #8 so we probably have a good PCH (or so it appears).
                            Wouldn't it be amazing if this was a perfectly healthy board and taking the Audio IC off the board relieves the low resistance on the 5V rail and then replacing the SIO chip fixes the laptop?
                            Wouldn't hurt to try right?
                            I'll have an update soon.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              I dont think insering a ram stick with battery connected will damage audio ic/sio as its not related at all. Ram has something to do with memory controller and cpu-nothing else. I think you had a short on 5V rail and these audio etc may got killed.
                              Anyway, no harm in removing the components. If resistance goes to normal value after removal,worth trying.
                              • ResoluteHawk
                                • Nov 2021
                                • 153
                                So I actually found the cause for this and managed to fix it, but I forgot to update this thread.
                                The issue where the 5v is a low resistance was actually due to a shorted GPU VRAM driver and one of the Dual N channel MOSFETs associated with it, which gets power from Pin #14 on PU9401. The problem is that if this driver is bad, it will kill either of the Dual N Channel MOSFETs (PQH9402, PQH9404) or both of them. That's why it was killing one of them when power was inserted and thus, I got stumped. Until I realized that the driver was the culprit.
                                I took off PQH9404 and resistance was back up to 3M Ohms. Great!
                                Once I took the VRAM driver off the board (PU9401), resistance on the gate of PQH9404 went to OL, which is actually a good thing. After replacing the driver and PQH9404 (again), inserting power now yields a charge light and a good power on, and the gate of PQH9404 and PQH9402 both measure 3M Ohms.
                                Since there aren't many threads on the ASUS G14 on this forum, I thought that I should update this to let people know that if they have this issue on the GPU VRAM rail, you MUST replace BOTH THE DRIVER AND THE MOSFET.
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  And the audio controller has healed by itself?
                                  I suggest to check the GPU in detail, under load with all drivers installed.
                                  • Nagy Daniel
                                    Lowest possible resistance on laptop motherboard rail - Guide Table request
                                    by Nagy Daniel
                                    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                    So, I generated a table with AI so I can...
                                    03-04-2025, 08:24 AM
                                  • BC_TechForum_drb
                                    Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                                    by BC_TechForum_drb
                                    Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                                    Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                                    Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                                    2/ Figure 1 Gfx-D500-B Front Facing
                                    3/ Figure 2 +5v supply (zoom-in)
                                    Intro:
                                    While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                                    12-07-2023, 09:55 PM
                                  • Sephir0th
                                    DELL XPS 15 9560 - No VCore, Power Off after few seconds
                                    by Sephir0th
                                    Hello Community,
                                    i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
                                    It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
                                    Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
                                    I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
                                    05-09-2021, 11:22 AM
                                  • theflyingsquirrel
                                    Samsung Chromebook Pro missing 1.2V power rail and no boot
                                    by theflyingsquirrel
                                    I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                                    When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                                    06-11-2025, 08:11 AM
                                  • noflux
                                    Surface pro 5 (Model 1726) missing 3.3V power rail
                                    by noflux
                                    Hello All
                                    Have a Surface pro 5. Main board model; M1007506-015. Main 15v power rail is present.
                                    1st image;
                                    Missing 8v rail at inductor (circled in blue). Suspect main cause is power is being drawn at dead short on C4517.
                                    2nd image;
                                    3.3v rail was measured at 0.17v (at top most capacitor with red cross in 1st image).
                                    Capactors crossed out in red are shorted.
                                    Are the 5v and 3.3V rails tied in somehow e.g. generated at a single IC?
                                    2nd and 3rd image;
                                    C4517 circled in red is shorted at pin...
                                    06-18-2023, 03:45 PM
