Notebook HP 240 G8 not turning on, charging is ok.
  • ch3nzu
    • Jul 2021
    • 43
    • indonesia
    Hai guys, i have a problem with this hp laptop.
    I already found there is a problem with power button, usb-c board (see picture) that cause its not turning on.
    When i remove this small board, laptop can turn on by shorted the power switch pin with tweezers. (Pin 14 from left side)
    But when its attached, laptop wont start when i press the power button.
    Already check 3.3V at power button swith, its respond when I press it (0V)
    I think maybe i have a problem with usb 3.0 ic here, i just wonder if this is oke to remove the ic, and power in on to test this? Or do i need to find a replacement first before test?
    NB: Mainboard HEDWIG02 6050A3285801 MB A01
    If anyone can share its schematic, thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Notebook HP 240 G8 not turning on, charging is ok.
    I faced same issue on this very mb. It was a shorted tiny cap on the daughter board. Check each and every cap on this board and hopefully one may be shorted.
    • ch3nzu
      • Jul 2021
      • 43
      • indonesia
      Many thanks, I checked all the caps as you told, then I found this cap is shorted (see picture).
      Now the hp laptop is turn on normally.
      I just remove it, not replacing it because i dont know it value. Is that oke?
      • mon2
        • Dec 2019
        • 14634
        Test the unit to see if it remains stable. Stream YouTube videos for a while. If all is well, this part is not critical. Probably a low value bulk capacitor that does not influence the normal operation.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Glad to know you fixed it. yes its safe to leave that cap removed.
          • ch3nzu
            • Jul 2021
            • 43
            • indonesia
            Already tested the laptop for 1 hour, its look normal.
            Thanks again for the comment and support guys.
