Re: Acer Aspire 5 A515-51G power on but black screen
Look at page12 of diagram. Its detailed there. Shifting of resistors depends on which brand of onboard ram you have. The concept is to pull alll the ram id's to "1" to make it no onboard memory. If you dont understand it still, tell us the onboard memory details.
I also attach the boardview below
MOD Edit: Link to boardview -> https://www.badcaps.net/forum/showthread.php?t=100189
Can you tell me how do I disable the internal ram module on this model?
thank you!
in the meantime I checked the welded module and it's from samsungLast edited by SMDFlea; 09-02-2023, 12:04 PM.Leave a comment:
for the moment I have made the measurements on the coils (see photo)
it seems that PL096 has no voltage so also +VCC_GTLeave a comment:
This mb is known to have failing onboard ram. Worth try disabling it. Schematic and bdv -both are available on forum. I has such a case twice and my board wad LA-E891P.Leave a comment:
Check for PLT_RST# too and if present stay at BIOS in my opinion. Exclude write errors and similar.
If nothing turns out, detailed visual inspection of the motherboard for open lines, ripped components and so on.Leave a comment:
yes this model has 4gb ram soldered and 4gb removable.
Both with 8gb and with only 4gb soldered, the consumption is 0.50/0.51 A
here the video:
https://streamable.com/akf8r0(you can also notice the screen that when you turn on it makes a slight glow and even after)
ps: the laptop restarts once because i didn't connect the batteryLast edited by resistor83; 03-14-2023, 03:23 PM.Leave a comment:
I beleive ram is onboard on this model. Worth trying disabling it. Is there not much variation in consumption on your dc supply?? I mean like it goes straight away to say 550mA and moves a bit and stand still after that??Leave a comment:
The laptop is complete with everything, display ram etc. The customer says that one day suddenly
it didn't work anymore, it turns on but you can't see anything on the screen.
DDR_DRAMRST 1,21V
Some Acers need horribly long till they show picture after hard reset, like 3 -5 Minutes or so, often doing at least two reboots.
So first clarify whether it is like that or similar. Patience might be the key then. Also check whether CapsLock is reacting by any chance with external keyboard and/or whether you're able to reset it with the CTRL+ALT+DEL combination, after a few minutes of the board staying on.
before trying to flash the bios I kept the laptop on for several minutes but nothing changed
I also tried to hold the fn+esc key and then turn it on, two things happened: the first time the fan went to its maximum but for a few seconds it then turned off (computer always on) and then it started spinning normally when the cpu heats up a bit
The second time I tried to turn it on instead the fan was running at maximum continuously, I was hoping something would have happened and I kept it on for at least 7 8 minutes but nothing changed
Whit external keyboard capslock don't appearLast edited by resistor83; 03-13-2023, 03:00 PM.Leave a comment:
So first clarify whether it is like that or similar. Patience might be the key then. Also check whether CapsLock is reacting by any chance with external keyboard and/or whether you're able to reset it with the CTRL+ALT+DEL combination, after a few minutes of the board staying on.Leave a comment:
History of the laptop?? You received it as no display case or you fixed a dead unit?? Pl clarify.
DRAMRST# present??Leave a comment:
I flashed the bios with this https://www.badcaps.net/forum/showpo...8&postcount=30 but the problem remained the sameLeave a comment:
"on for a few minutes the fan starts spinning a bit and then shuts down again and the pc stays on all the time"
looks like normal reset. did u flash bios?Leave a comment:
hi, i have your exact same problem with an acer A515-45
I opened a post here https://www.badcaps.net/forum/showthread.php?t=116721
my notebook arrived without the ssd mounted so I don't see if it loads the operating system.
Have you tried connecting an external hdmi monitor?Last edited by Egidio85; 03-11-2023, 09:57 AM.Leave a comment:
hi, i have an acer aspire 5 a515-51g that turns on but has a black screen.
I tried to flash the bios with this https://www.badcaps.net/forum/showpo...8&postcount=30 but the problem is still there
To be precise: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts spinning a bit and then shuts down again and the pc stays on all the time.
What could it be?
What measurements can I take?
sorry but my electronic competence is not very high
motherboard: LA-E892P
C5V01 REV 1C
ps: I also add that when I press the power button there seems to be a slight backlight, the color swap slightly and it becomes darker than when it is off
MOD Edit: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=123072
.Last edited by SMDFlea; 09-02-2023, 11:59 AM.Tags: None
This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:00 AM
This specification for the Acer Aspire Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) boardview and Acer Aspire 5 A515-45 15.6 inch Laptop (AMD Ryzen 5 5500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Black) schematic. Our users have donated over 1 million...09-07-2024, 03:10 AM
This specification for the Acer Aspire Acer Aspire 3 A315-56 15.6 inch Laptop (Intel Core i5-1035G1, 8GB RAM, 256GB SSD, Full HD IPS Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 3 A315-56 15.6 inch Laptop (Intel Core i5-1035G1, 8GB RAM, 256GB SSD, Full HD IPS Display, Windows 10, Black) boardview and Acer Aspire 3 A315-56 15.6 inch Laptop (Intel Core i5-1035G1, 8GB RAM, 256GB SSD, Full HD IPS Display, Windows 10, Black) schematic. Our...09-07-2024, 02:50 AM
This specification for the Acer Aspire Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) boardview and Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD...09-07-2024, 01:00 AM
This specification for the Acer Aspire Acer Aspire 1 A114-32 14 inch Laptop (Intel Celeron N4020, 4GB RAM, 64GB eMMC, HD Display, Windows 10 in S Mode, Office 365 Personal, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 1 A114-32 14 inch Laptop (Intel Celeron N4020, 4GB RAM, 64GB eMMC, HD Display, Windows 10 in S Mode, Office 365 Personal, Black) boardview and Acer Aspire 1 A114-32 14 inch Laptop (Intel Celeron N4020, 4GB RAM, 64GB eMMC, HD Display, Windows...09-06-2024, 10:00 PM
- Loading...
