Laptop Zenbook UX480 Fuse L
  • corrize
    • Apr 2021
    • 294
    • France
    Hello, on this laptop, there is a black fuse 0603 with letter « L », it is blow up (close LVDS connector). I can't find it nor equivalent on alixpress. Can you help pls ?
  • corrize
    • Apr 2021
    • 294
    • France
    Re: Laptop Zenbook UX480 Fuse L
    Maybe, it’s this one.
    https://fr.aliexpress.com/item/4000812956401.html
    The 1.75A ?
    • hardware1
      • Sep 2021
      • 2946
      • N/A
      Originally posted by corrize
      Hello, on this laptop, there is a black fuse 0603 with letter « L », it is blow up (close LVDS connector). I can’t find it nor equivalent on alixpress. Can you help pls ?
      I think it should be that one (0603, 1.75A, 32V).
      If you can't find it, you can use (0603, 2A, 32V) with letter (N), it's the closest one.
      Also you must measure and see if there's any short to ground before or after the fuse.
      all donations are welcome,
      • mon2
        • 14634
        Can you post a pic of the area where this fuse is on the logic board?
        In comparing a mix of other Asus logic board, there is a polyswitch fuse of 0.5A in 0603 package. Also found 0.75A in 0805 package on a few boards.
        P/N SMD0603P050TF
        So the concern is on the actual rating of the component.
        Also, if you really had a polyswitch fuse onboard then that fuse will reset after a period of time once the power and excessive load event is removed.
        • corrize
          • Apr 2021
          • 294
          • France
          Thx for reply, I will order it so.
          It’s not a reset fuse, the laptop is off long time ago.
          It’s a screen fuse, see picture, it is below, at left of LVDS connector
          • mon2
            • 14634
            Actually, a "P" means Polyswitch / polymer switch. They self-heal after a period of time. If the fuse has a lot of wear then yes, the fuse will no longer self-heal.
            Remove all power. Check the resistance across the fuse pads.
            To me, the part looks larger than an 0603 -> perhaps a 1206 size?
            https://www.aliexpress.com/item/32804658202.html
            https://p-nt-www-amazon-ca-kalias.am.../dp/B0B6DJBPBT
            1206 SMD fuse with code K:
            https://www.littelfuse.com/media?res...206l-datasheet
            To check the size:
            a) measure it with a micrometer
            OR
            b) review that the part beside is a SOT23-6 device. Hunt down any part in SOT23-6 package and review the length of the part.
            Then compare the fuse length to validate if the fuse is 0603 / 0805 or 1206.
            My bet is on 1206.
              • 21692
              I don`t think it is. The forward slanted P is the logo for Polytronics
              • mon2
                • 14634
                Well noted. Still shows up a PPTC.
                https://www.pttc.com.tw/smd.aspx
                  • 21692
                  It does
                  1206 Marking K SMD1206P010TF/30
                  0603 SLR series Marking K SMD0603P050SLR
                  0805 SLR series Marking L SMD0805P200SLRT ,it could be a different part from a different manufacturer though
                  The datasheets are quite good,each one has a useful cross reference
                  • corrize
                    • Apr 2021
                    • 294
                    • France
                    The fuse marked « P.. » is good, I saw it, I know what it is now.
                    There is another issue.
                    I plugged the laptop, no light, nothing.
                    19v ok at first mosfets, and 24v at gates
                    +5v and 3.3v présents
                    but when I plug the battery (empty), no charging. At the coil closest : 0.86v, it should be 12v ou 15v (battery charge voltage). I guess the charging chip is dead.
                    19v present feeding this charging chip but voltages around the chip are low.
                    I noticed that often the charging chips can be dead but not shorted. Have you a tips for quickly check if the chip is dead pls (without check all voltages) ?
                    • mon2
                      • 14634
                      Which charger IC is onboard?
                      Review the HIGH side mosfet that is linked to the charging of the battery. The charger makes use of 2 external mosfets to 'dial' down the voltage from the 19v main power leg.
                      Respectively, both of these mosfets - high and low side must switch on/off to provide a desirable charge voltage.
                      Remove all power -> meter in resistance mode.
                      Check the resistance of each of the battery charger mosfets:
                      source (1-2-3) & drain (5-6-7-8)
                      source (1-2-3) & gate (4)
                      gate (4) & drain (5-6-7-8)
                      Post each measurement.
                      On the battery, connect the adapter and measure the voltage to ground of each of the battery pin connector. Interested in the SMBUS SCL and SDA voltage readings.
                      • corrize
                        • Apr 2021
                        • 294
                        • France
                        The chip is BQ24780S
                        I guess the mosfets are good because there is 19v at drain (of the first mosfet) and 0.86v at gate and I saw 0.86v at a component a the out of the charging chip. So mosfets provide 0.86v because there is only 0.86v at gate
                        The values of mosfets :
                        Mosfet 1
                        source (1-2-3) & drain (5-6-7-8) : 33 MOhms
                        source (1-2-3) & gate (4) : 180 K
                        gate (4) & drain (5-6-7-8) : 20 M
                        Mosfet 2
                        source (1-2-3) & drain (5-6-7-8) : 5.5M
                        source (1-2-3) & gate (4) : 156 K
                        gate (4) & drain (5-6-7-8) : 3.6 M
                        I can't understand why the battery connector values are useful ? That should be the same than the mosfets provide ?
                        • corrize
                          • Apr 2021
                          • 294
                          • France
                          The measurements of the charging IC : BQ24780S (DC jack plugged, battery unplugged)
                          The chip is dead ?
                          1 - ACN : 19v
                          2 - ACP : 19v
                          3 - CMSRC : 18.8v
                          4 - ACDRV : 24.6v
                          5 – ACOK : 5.94v
                          6 – ACDET : 2.62v
                          7 – IADP : 0v
                          8 – DCHG : 0v
                          9 – PMON : 0v
                          10 – PROCHOT : 0v
                          11 – SDA : 3.29v
                          12 – SCL : 3.29v
                          13 – CMPIN : 0.17v
                          14 - CMPOUT : 6v
                          15 – BATPRES : 0v
                          16 – TB_STAT : 0.16v
                          17 – BATSRC : 0.86v
                          18 – BATDRV : 0.89v
                          19 - SRN : 0.86v
                          20 – SRP : 0.86v
                          21 –ILIM :1.16v
                          22 - GND : 0v
                          23 - LODRV : 0V
                          24 - REGN : 6v
                          25 - BTST : 5.8v
                          26 - HIDRV : 0.86v
                          27 : PHASE : 0.86v
                          28 : VCC : 19.04v
                          • mon2
                            • 14634
                            • corrize
                              • Apr 2021
                              • 294
                              • France
                              OK, found. It's a basic data bus (battery speaking with charging chip I guess ?)
                              I measured 3.27v at the SCL and SDA pins of charging chip, and at the white and yellow wires on the connector of battery (plugged and the adapter too).
                              0v at the + of battery
                              • corrize
                                • Apr 2021
                                • 294
                                • France
                                Found this bad guy close the audio amp chip, it's shorted ; 0 Ohms. I will remove it tomorrow but I dont know the value (no schematics for this model). And I guess it's not the issue, I already find a shorted cap on the main power rail on this board and there is no coil shorted.
                                • corrize
                                  • Apr 2021
                                  • 294
                                  • France
                                  Not the guilty, I compared to another board very similar (UX481) and it’s an inductor and not a capacitor, so it’s is good. So, back to the charging chip.
                                  • Sephir0th
                                    • Oct 2020
                                    • 1289
                                    Since the charging controller asserted ACOK and a few secondary power rails are present, I'd more suspect fault later in the sequence.
                                    I didnunderstood it like, even without battery the board isn't coming on, so...
                                    FairRepair on YouTube
                                    • corrize
                                      • Apr 2021
                                      • 294
                                      • France
                                      So what pls ? What do you mean ?
                                      Do you supect a little component after the charging chip or a main big chip ?
                                      The original issue for this laptop was a bad cap close the dual mosfet of CPU VRM. But the dual mosfet is not shorted and after replace the cap, no short nowhere but oxydation at some places. I guess the CPU is ok, and I see no reason to suspect Super IO or chipset (even I was expecting a light on after plug the adapter).
                                      • corrize
                                        • Apr 2021
                                        • 294
                                        • France
                                        I have a new way. Around a 5E= chip, a resistor without any resistance (oxydation) and 3 caps shorted so I will see that…
                                          ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook 13 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX331FN-DH51T Ultra-Slim Laptop boardview and UX331FN-DH51T Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-06-2024, 07:33 AM
                                          ASUS ZenBook 14 UX461FN-DH74T Ultra-Slim Convertible Laptop Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook 14 UX461FN-DH74T Ultra-Slim Convertible Laptop Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 UX461FN-DH74T Ultra-Slim Convertible Laptop boardview and 14 UX461FN-DH74T Ultra-Slim Convertible Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...
                                          ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook 14 Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX433FA-DH74 Ultra-Slim Laptop boardview and UX433FA-DH74 Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
