Hello, on this laptop, there is a black fuse 0603 with letter « L », it is blow up (close LVDS connector). I can't find it nor equivalent on alixpress. Can you help pls ?
Laptop Zenbook UX480 Fuse L
Re: Laptop Zenbook UX480 Fuse L
Maybe, it’s this one.
https://fr.aliexpress.com/item/4000812956401.html
The 1.75A ? -
If you can't find it, you can use (0603, 2A, 32V) with letter (N), it's the closest one.
Also you must measure and see if there's any short to ground before or after the fuse.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Can you post a pic of the area where this fuse is on the logic board?
In comparing a mix of other Asus logic board, there is a polyswitch fuse of 0.5A in 0603 package. Also found 0.75A in 0805 package on a few boards.
P/N SMD0603P050TF
So the concern is on the actual rating of the component.
Also, if you really had a polyswitch fuse onboard then that fuse will reset after a period of time once the power and excessive load event is removed.Comment
Actually, a "P" means Polyswitch / polymer switch. They self-heal after a period of time. If the fuse has a lot of wear then yes, the fuse will no longer self-heal.
Remove all power. Check the resistance across the fuse pads.
To me, the part looks larger than an 0603 -> perhaps a 1206 size?
https://www.aliexpress.com/item/32804658202.html
https://p-nt-www-amazon-ca-kalias.am.../dp/B0B6DJBPBT
1206 SMD fuse with code K:
https://www.littelfuse.com/media?res...206l-datasheet
To check the size:
a) measure it with a micrometer
OR
b) review that the part beside is a SOT23-6 device. Hunt down any part in SOT23-6 package and review the length of the part.
Then compare the fuse length to validate if the fuse is 0603 / 0805 or 1206.
My bet is on 1206.Comment
It does
1206 Marking K SMD1206P010TF/30
0603 SLR series Marking K SMD0603P050SLR
0805 SLR series Marking L SMD0805P200SLRT ,it could be a different part from a different manufacturer though
The datasheets are quite good,each one has a useful cross referenceLast edited by SMDFlea; 03-09-2023, 12:32 PM.Comment
The fuse marked « P.. » is good, I saw it, I know what it is now.
There is another issue.
I plugged the laptop, no light, nothing.
19v ok at first mosfets, and 24v at gates
+5v and 3.3v présents
but when I plug the battery (empty), no charging. At the coil closest : 0.86v, it should be 12v ou 15v (battery charge voltage). I guess the charging chip is dead.
19v present feeding this charging chip but voltages around the chip are low.
I noticed that often the charging chips can be dead but not shorted. Have you a tips for quickly check if the chip is dead pls (without check all voltages) ?Comment
Which charger IC is onboard?
Review the HIGH side mosfet that is linked to the charging of the battery. The charger makes use of 2 external mosfets to 'dial' down the voltage from the 19v main power leg.
Respectively, both of these mosfets - high and low side must switch on/off to provide a desirable charge voltage.
Remove all power -> meter in resistance mode.
Check the resistance of each of the battery charger mosfets:
source (1-2-3) & drain (5-6-7-8)
source (1-2-3) & gate (4)
gate (4) & drain (5-6-7-8)
Post each measurement.
On the battery, connect the adapter and measure the voltage to ground of each of the battery pin connector. Interested in the SMBUS SCL and SDA voltage readings.Comment
The chip is BQ24780S
I guess the mosfets are good because there is 19v at drain (of the first mosfet) and 0.86v at gate and I saw 0.86v at a component a the out of the charging chip. So mosfets provide 0.86v because there is only 0.86v at gate
The values of mosfets :
Mosfet 1
source (1-2-3) & drain (5-6-7-8) : 33 MOhms
source (1-2-3) & gate (4) : 180 K
gate (4) & drain (5-6-7-8) : 20 M
Mosfet 2
source (1-2-3) & drain (5-6-7-8) : 5.5M
source (1-2-3) & gate (4) : 156 K
gate (4) & drain (5-6-7-8) : 3.6 M
I can't understand why the battery connector values are useful ? That should be the same than the mosfets provide ?Comment
The measurements of the charging IC : BQ24780S (DC jack plugged, battery unplugged)
The chip is dead ?
1 - ACN : 19v
2 - ACP : 19v
3 - CMSRC : 18.8v
4 - ACDRV : 24.6v
5 – ACOK : 5.94v
6 – ACDET : 2.62v
7 – IADP : 0v
8 – DCHG : 0v
9 – PMON : 0v
10 – PROCHOT : 0v
11 – SDA : 3.29v
12 – SCL : 3.29v
13 – CMPIN : 0.17v
14 - CMPOUT : 6v
15 – BATPRES : 0v
16 – TB_STAT : 0.16v
17 – BATSRC : 0.86v
18 – BATDRV : 0.89v
19 - SRN : 0.86v
20 – SRP : 0.86v
21 –ILIM :1.16v
22 - GND : 0v
23 - LODRV : 0V
24 - REGN : 6v
25 - BTST : 5.8v
26 - HIDRV : 0.86v
27 : PHASE : 0.86v
28 : VCC : 19.04vLast edited by corrize; 03-11-2023, 09:51 AM.Comment
I can't understand why the battery connector values are useful ?On the battery, connect the adapter and measure the voltage to ground of each of the battery pin connector. Interested in the SMBUS SCL and SDA voltage readings.Comment
OK, found. It's a basic data bus (battery speaking with charging chip I guess ?)
I measured 3.27v at the SCL and SDA pins of charging chip, and at the white and yellow wires on the connector of battery (plugged and the adapter too).
0v at the + of batteryComment
Found this bad guy close the audio amp chip, it's shorted ; 0 Ohms. I will remove it tomorrow but I dont know the value (no schematics for this model). And I guess it's not the issue, I already find a shorted cap on the main power rail on this board and there is no coil shorted.Comment
Since the charging controller asserted ACOK and a few secondary power rails are present, I'd more suspect fault later in the sequence.
I didnunderstood it like, even without battery the board isn't coming on, so...Last edited by Sephir0th; 03-12-2023, 09:29 AM.Comment
So what pls ? What do you mean ?
Do you supect a little component after the charging chip or a main big chip ?
The original issue for this laptop was a bad cap close the dual mosfet of CPU VRM. But the dual mosfet is not shorted and after replace the cap, no short nowhere but oxydation at some places. I guess the CPU is ok, and I see no reason to suspect Super IO or chipset (even I was expecting a light on after plug the adapter).Comment
This specification for the ASUS ZenBook 14 UX461FN-DH74T Ultra-Slim Convertible Laptop Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 UX461FN-DH74T Ultra-Slim Convertible Laptop boardview and 14 UX461FN-DH74T Ultra-Slim Convertible Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...09-06-2024, 07:33 AM
This specification for the ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX331FN-DH51T Ultra-Slim Laptop boardview and UX331FN-DH51T Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-06-2024, 07:33 AM
This specification for the ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX433FA-DH74 Ultra-Slim Laptop boardview and UX433FA-DH74 Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 07:33 AM
This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...09-06-2024, 09:30 PM
This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 08:47 AM
- Loading...
