Laptop Zenbook UX480 Fuse L
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Laptop Zenbook UX480 Fuse L
    My friend, you have to clarify whether the board works as expected without battery present. If not, there is no point to troubleshoot a battery issue right now, since the Charging controller works like expected from measurements.
    You have to understand, that the device follows a sequence. All power rails are supposed to come in a predetermined order. If you finally start to look at the whole board, instead of concentrating on random points, experienced members here might be able to tell where to look at.
    At this point the only thing we know is, Main power rail, 3.3V and 5V supply is present. that's not much and not sufficient to troubleshoot a motherboard.
    Maybe i'm wrong and the board is working. Please clarify.
    FairRepair on YouTube
    • corrize
      • Apr 2021
      • 294
      • France
      I know a little bit the sequence and how to the first components works, mosfets, charging chip (open or close mosfets and drive mosfets for charging battery), and the 3.3v-5v chip.
      I supposed if these components worked, the next step was the superIO chip wich waiting start signal from power button.
      But I’m knowledge seeker, I expected if mosfets, charging chip and 3.3v-5v chip working, at this step, the battery can charge, even if the superIO or other chip has an issue. Because I supposed the charging chip is independant for manage the battery charging, but I guess I’m wrong.
      And I don’t know wich chip manage the light (charge and power).
      I have no simplified schematics of the sequence. If you have, it is welcome.
      • Sephir0th
        • Oct 2020
        • 1289
        You somehow managed to repeatedly not answer the question, whether the board fully works without charger only or not. For this reason I can't ask the necessary questions.
        And regarding the EC, when 3VALW/5VALW are present, there is usually no point to check around the EC, since at this point it is already running and has (de-)asserted a few signals. They can fail in this state but that's a really rare case.
        • corrize
          • Apr 2021
          • 294
          • France
          I don’t know if the laptop works only with battery (and without adapter), because the battery is empty. But it’s a good idea to test with only battery.
          The diagnose is in stand by, I’m waiting the new resistor for replace the dead one. This resistor is close the ram memory power chip, so the ram should not be able powered. Will see after replacement.
          Nice to learn the EC works (it’s a bga one).
          • Sephir0th
            • Oct 2020
            • 1289
            Well, finally there was a Spelling mistake by myself. I have meant "with charger only".
            • corrize
              • Apr 2021
              • 294
              • France
              #26
              OK, as I said above, with adapter only, no light, no sign of life, nothing after pressing power on button, (and battery don't charge).
              • Sephir0th
                • Oct 2020
                • 1289
                Without power present, check resistances to GND of each power rail on your board (of the working power rails too!).
                If you don't know the designation of the various power rails, take a picture of the board and write the values near the coils.
                • corrize
                  • Apr 2021
                  • 294
                  • France
                  #28
                  I replaced the resistor, but no change.
                  So, the diagnose can continue.
                  I summarize :
                  On this board, I saw 3 different issues :
                  1 - the first « true » issue : a capacitor shorted close the CPU VRM dual mosfet.
                  2 – oxydation (close DC jack mosfets)
                  3 – the owner tryed to unplug the LVDS connector without disconnecting the battery, and that burned the connector and the fuse
                  I plugged the laptop (without battery) : no light, nothing.
                  When I press the power button : the same, no reaction
                  19v ok at first mosfets, and 24v at gates
                  +5v and 3.3v présents
                  charging chip seams to be good
                  With adapter and and battery (empty) plugged, no charging. At the coil closest : 0.86v, it should be 12v ou 15v (battery charge voltage).
                  Battery only : not tested : the battery is empty
                  See the attached picture with measurments at coils (graphic chip VRM at 1.2 Ohms is very low but not shorted).
                  I supposed a corrupted bios but no light at all when I press the power button, so I don't know ?
                  • corrize
                    • Apr 2021
                    • 294
                    • France
                    #29
                    I add, on picture, all coils without measurments are 0v. So only 3 coils have voltage battery coil : 0.86v, and 5v and 3.3v.
                    Do you see something weird or all is normal pls ?
                    • corrize
                      • Apr 2021
                      • 294
                      • France
                      #30
                      Update : I replaced bios and I saw for the first time the charging LED on, and when I press the power button, the power LED on. So that was a bios issue.
                      But now, even with the power LED on, the laptop don’t start, all coils are 0v (except 3.3v 5v and 1.8v), (I don’t plugged the battery).
                      I have not yet started a new diagnose.
                      Before, I wanted to ask you if that could be a corrupted or bad bios or not pls ? Because I have no experience of bios issues.
                      • corrize
                        • Apr 2021
                        • 294
                        • France
                        #31
                        Update : since the last time, I recovered 1.05v at PCH coil.
                        So, the voltages that was present : 3v, 5v, 1.8v and 1.05v.
                        « Was » because I replaced the ram memory driver chip (richtek 5E=) because oxydated and I loosed 19v rail. Now, the resistance at DC jack shunt resistor is something like 182 Ohms, the same as the ram memory coil.
                        I checked ; I have 0 Ohms between DC jack shunt resistor and the ram memory coil, so continuity.
                        That’s means the 19v was able to reach ram memory ?
                        I can’t understand how it is possible ? What can be dead between shunt resistor and ram memory coil ? The ram memory driver chip ? The dual mosfet ?
                          ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook 13 Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX331FN-DH51T Ultra-Slim Laptop boardview and UX331FN-DH51T Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          09-06-2024, 07:33 AM
                          ASUS ZenBook 14 UX461FN-DH74T Ultra-Slim Convertible Laptop Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook 14 UX461FN-DH74T Ultra-Slim Convertible Laptop Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 UX461FN-DH74T Ultra-Slim Convertible Laptop boardview and 14 UX461FN-DH74T Ultra-Slim Convertible Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...
                          ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook 14 Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX433FA-DH74 Ultra-Slim Laptop boardview and UX433FA-DH74 Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                          09-06-2024, 09:30 PM
                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-06-2024, 08:47 AM
