DG424/DG524 NM-B301 Rev 1.0 no display and power issue
  • mon2
    • Dec 2019
    • 14340
    Re: DG424/DG524 NM-B301 Rev 1.0 no display and power issue
    Indeed, it is. Do you have +1.8ALW rail present?
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Yes I have sir
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        PL401 - 3.3V
        PL402 - 5V
        EC_RSMRST# 0v
        EC_ON - 3.3V
        VR_CPU_PWROK - 3.3V
        ALW_PWRGD- 6.5V
        EC_VR_ON - 3.3V
        SUSP# -0v
        PCH_PWR_EN - 3.3V
        SYS_PWROK - 0v
        PM_SLP_S3# - 0v
        Unit is taking 30miliamp of power stable
        +1.8VALW- 1.8V
        EC_RTCRST#_ON- 4.2v
        SYSON - 0V
        LDO1_VIN -0V
        LDO2_VIN -3.3V
        PMIC_VCC -5.1V
        +5VLP - 5.1V
        ALW_PWRGD -3.8V -pulsing 5v
        • mon2
          • Dec 2019
          • 14340
          My earlier point of view may be incorrect.
          The EC is creating (driving) the signal with netname EC_RSMRST#. That is, the EC is in control of this reset line and the EC is keeping this line low using one of its GPIO pins. This may be due to the EC not working / not being powered / not being clocked / corrupt firmware used by the EC.
          Remove all power, what is the resistance to ground of EC_RSMRST# ?
          On your logic board, do you have the resistor stuffed @ RC9350 ?
          Do you have the power rails present on the EC?
          What are the voltage to ground readings of the following signals?
          EC_SMB_CK0
          EC_SMB_DA0
          PMIC_SMB_CLK0
          PMIC_SMB_DAT0
          • mon2
            • Dec 2019
            • 14340
            ALW_PWRGD- 6.5V
            Can you confirm this voltage to ground? It does not look correct.
            See attached. This status line should be ~3v (max).
            What is the voltage to ground of your +3VALW rail ?
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              #26
              EC_SMB_CK0
              EC_SMB_DA0
              PMIC_SMB_CLK0
              PMIC_SMB_DAT0
              Tommorow sir I can check this signal , im on day off righnow
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                #27
                I already check this before I poted it here its about 2kilioms and going up to ground, so not shorted Im sure about that. Is it normal to have pulsing?
                • mon2
                  • Dec 2019
                  • 14340
                  No, it is not normal to have pulsing. This is an 'always on rail' so it should be a stable +3V an is required to power other critical parts.
                  If it is pulsing, then that regulator must be investigated for the EN (enable) pin of that chip. Is the EN pin pulsing as well ?
                  Update:
                  EC_ON is the ENABLE for the +3VALW rail. You have posted this to be @ 3v3 which is a good voltage for EC_ON.
                  Is EC_ON stable @ 3v3 ? If yes, then the logic board is requesting for the +3VALW to be ON.
                  At this point of the quick review - PU401 may be defective if there is no excessive load on the +3VALW rail.
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    #29
                    Sorrymy mistake +3VALW is stable and not pulsing the ALL_PWRGD is pulsing not the +3VALW sorry
                    • mon2
                      • Dec 2019
                      • 14340
                      Ok - just read your last post. Best to update and post a fresh list when you can.
                      Need to confirm the voltage on ALL_PWRGD - it cannot be so high as posted earlier.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        #31
                        ok sir noted thanks for the help as always. First dayin the morning I can give you the updated readings again
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          #32
                          Hi sir good day
                          EC_SMB_CK0 -3.3v stable
                          EC_SMB_DA0 -3.v stable
                          PMIC_SMB_CLK0- 3.3v stable
                          PMIC_SMB_DAT0 -3.3v stable
                          EC_ON -3.3v stable
                          regarding with the
                          ALW_PWRGD - 3.3v - 3.9v is it normal ?
                          • mon2
                            • Dec 2019
                            • 14340
                            No, this rail should not be so high since the pull-up voltage is to +3VALW.
                            The +3VALW rail is created by PU401. Specifically, confirm that the FB leg of PU401 indeed has a 1k resistor as shown in the schematic.
                            Do not power up the board if the FB circuits are ever missing else the output may overshoot and kill every part that is voltage sensitive and operates from the +3VALW rail.
                            Remove the solder blob @ PJ402 to isolate all downstream (aka consumer) circuits from this power rail.
                            Power up again. Confirm that you have stable +3v3 @ PL401. If you do not, replace PU401.
                            If you observe fluctuations on the power good line then +3VALW is not stable.
                            At +3v9 output on +3VALW, this may have caused damage for voltage critical parts.
                            • Sephir0th
                              • Oct 2020
                              • 1283
                              Originally posted by kalilinux25
                              PL401 - 3.3V
                              ALW_PWRGD- 6.5V
                              EC_RTCRST#_ON- 4.2v
                              Even stated 6.5V present there before. So something is very wrong here. Voltage at EC_RTCRST#_ON also doesn't seem right.
                              FairRepair on YouTube
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                #35
                                PR405 is present and 1K value is correct
                                REMOVE jumper PJ402
                                test PL401 stable 3.4v
                                there is a pulsing on the ALW_PWRGD Im getting 4.5 to 4.8v
                                • almirsilvestre
                                  • Jun 2020
                                  • 42
                                  • Brasil
                                  #36
                                  Yes sir its avaialble.
                                  Thank you very much...you saved me with this boardviewer...from the bottom of my heart...thank you very much
                                  • rounin
                                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                    by rounin
                                    🛠 Original Issue
                                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                    04-19-2025, 01:18 AM
                                  • ugamazing
                                    by ugamazing
                                    12-17-2024, 07:05 PM
                                  • shahnld
                                    Lenovo legion 5 pro startup issue
                                    by shahnld
                                    Good day Experts
                                    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                    08-24-2025, 12:31 PM
                                  • ahmarzo
                                    Acer laptop battery draining issue
                                    by ahmarzo
                                    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                    08-02-2025, 06:39 AM
                                  • elmark
                                    HP 15-cw1002ua strange keyboard issue
                                    by elmark
                                    HP Pavilion 15-CW1002UA
                                    S/N 5CD0251CBC
                                    P/N 7KE54EA
                                    Hello guys!
                                    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                    It powers on OK and has no other issues except the following:
                                    • CAPS LOCK does not work at all
                                    • Fn button toggles Flight Mode
                                    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                    • (with SHIFT pressed: 't%' and 'y^' respectively)
                                    I initially thought it was a keyboard malfunction (internal short, etc.),
                                    but when I press and hold...
                                    06-27-2025, 01:10 AM
