DG424/DG524 NM-B301 Rev 1.0 no display and power issue
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day this unit has a display at first and after flashing the bios chip got broken the original one is W25q64fwsiq and changed with W25q64fwsiG
    no idea if they are compatible after flashing unit wont power if pressed lightly, but if you tried long press it will power but no display , So I tried all bios in the forum same issue.
    I take the board out , its taking 80miliamp and cpu is gettign hot but power led is not turning on
    Unit is
    DG424/DG524 NM-B301 REV 1.0
    2017-03-09
    SR2Z6 Intel Celeron N3450
    Photo from power suppply
    checking voltage from
    PL3401- +VNN it has 1.0v
    PL401 - 3.3V
    PL402 - 5V
    EC_RSMRST# 3.3V
    EC_ON - 3.3V
    VR_CPU_PWROK - 3.3V
    ALW_PWRGD- 3.3V
    EC_VR_ON - 3.3V
    SUSP# -3.3V
    PCH_PWR_EN - 3.3V
    SYS_ON - 3.3V
    PM_SLP_S3# - 3.3V
    +1.8VS - 1.8V
    1.8VALW_PG -3.8V (why?)
    this reading is on UNIT IS PLUG and taking only 80 milliamp
  • mon2
    • Dec 2019
    • 14198
    Re: DG424/DG524 NM-B301 Rev 1.0 no display and power issue
    All of a sudden, the flash memory devices are becoming a hot topic.
    The 2 flash memory devices are NOT the same.
    The original has a 'Q' suffix. This means that the QE='1'. So QSPI mode is enabled.
    The replacement is with a 'G' suffix. QE='0'.
    To use the replacement, you must find a method to configure the QE bit to be '1'.
    Do search for a compatible tool and share the details here. If there is a need, can develop one, as time permits.
    Update:
    Wish to clarify...there is an assumption on my part that the original chip is still onboard with QE='1'. The only way to confirm is to check the schematics.
    That is, it is possible the mfr of the logic board used this part but only after changing QE='0'.
    Then normal spi mode applies.
    Do note this possibility.
    If possible, test the replacement with and without QE='1' setting.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Update:
      Thanks for the detailed and very clear clarrification sir, Not I udnerstand why its doing this type of issue , what Im gonan do now is jsut jumper the brroken ppins to the spi flasher hoping it will works without issue, Il update on this also
      UPDATE it was just a bios chip issue,
      beacuse the old one is broken I just soldered the broken pin to a jumpewr wires , now its fully working , thank you fior helping sir
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        https://www.badcaps.net/forum/showth...FDG524+NM-B301
        this bios wroks on my board thanks
        • mon2
          • Dec 2019
          • 14198
          Thanks for the update and closure.
          Given that you went back to the original and all is working, reviewed the flash memory IC on this schematic.
          See attached.
          Based on the flash pin labels, very confident that the original flash chip is being deployed in QSPI mode. That is, QE='1' is required.
          The part # from the original flash IC has the 'Q' so it is factory default in QSPI mode.
          The replacement part was not (by default) and would not work here unless you manually enable the same QE bit to be a '1' using a programmer.
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            See attached.
            Thank you sir for providing this data on me, very helpful to my future repairs thanks always
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              See attached.
              Update sir , unit working not normal windows wont load , keeps loading screen windows. after resting the unit, it wont power agian taking 30miliamp , cpu not hotting up no response on the power switch, what are your suggestion sir?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                What is the status of SUSP# ? IS it coming up??
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Unit works again sir after trying a clean bios but Issue is stock on loading screen of windows , with or without SSD, its running on bootable usb only, Hope its not a EC bin issue.
                  • mon2
                    • Dec 2019
                    • 14198
                    Try the safe mode boot of the windows os.
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      after flashing the board it will display and afther powering off the unit, it wont powered again
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        no unit dont have any ssd ,its just running on bootable usb sir
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          PL401 - 3.3V
                          PL402 - 5V
                          EC_RSMRST# 0v
                          EC_ON - 3.3V
                          VR_CPU_PWROK - 3.3V
                          ALW_PWRGD- 6.5V
                          EC_VR_ON - 3.3V
                          SUSP# -0v
                          PCH_PWR_EN - 3.3V
                          SYS_PWROK - 0v
                          PM_SLP_S3# - 0v
                          Unit is taking 30miliamp of power stable
                          +1.8VALW- 1.8V
                          EC_RTCRST#_ON- 4.2v
                          SYSON - 0V
                          LDO1_VIN -0V
                          LDO2_VIN -3.3V
                          PMIC_VCC -5.1V
                          +5VLP - 5.1V
                          ALW_PWRGD -3.8V -pulsing 5v
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            In my opinion a Bad or Dry balls under SOC. Perhaps the heat applied during desoldering/soldering bios chip is making temporary connections under SOC. Thats my gut feeling but may be something else.
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              maybe Ill try to resolder the soc sir?
                              • mon2
                                • Dec 2019
                                • 14198
                                EC_RSMRST# 0v
                                EC is parked in the reset mode if this signal is LOW = 0 volts.
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  EC_RSMRST# 0v
                                  that mens I have a bad Sio chip?
                                  • mon2
                                    • Dec 2019
                                    • 14198
                                    If available, can you link or post the schematic?
                                    No, the reset line will be an external signal created by an external group of parts.
                                    Check if there is a RC (resistor capacitor) circuit on this line. It should start from 0 volts but rest at 3v3 to release this line and only then then the EC will start it's function. The EC is a stand alone 8051 microcontroller with its own firmware. If parked in reset mode, the EC is sitting idle.
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      Yes sir its avaialble.
                                      https://www.badcaps.net/forum/showthread.php?t=77943
                                      https://www.badcaps.net/forum/showthread.php?t=114458
                                      • kalilinux25
                                        • Mar 2018
                                        • 2089
                                        • ZAMBOANGA SIBUGAY
                                        is this the right connection?
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
