Macbook A1707 820-00281
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello ,
    Namaste.
    I have a Macbook Pro 15inch A1707 820-00281. The Macbook had Display problem (as told by the customer) he used ti use it with an external display with the Display Connector disconnected.
    Now the Machine runs for sometime on external display but the fan goes high and switches off.
    Tried a known good display but there was an Apple Logo for some time , the load bar goes to 30% and the again the Macbook Switches off.
    Please help.
  • mon2
    • 14340
    Re: Macbook A1707 820-00281
    Try SMC / pram reset.
    High fan often means sensor fault. Check trackpad cable. Remove it and test again.
    Try to boot from another known good os with USB media.
    • leonemax81
      Macbook a1707 820-00281 Battery no Power
      by leonemax81
      Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
      08-23-2024, 09:24 AM
    • sofles
      Macbook a1707 2017 model 820-00928 GPU issue
      by sofles
      Hello there
      I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
      I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
      11-21-2024, 05:25 AM
    • jesi
      MacBook Pro 820-00281-A A1707 macbook
      by jesi
      hi all techs
      require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
      adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
      update:
      when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
      08-23-2025, 02:35 PM
    • tommy97
      Apple MacBook A1707 No Audio/Sound
      by tommy97
      I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
      I've also replaced U6300, but the problem persists.
      Here are the current voltage readings:
      • PPV18_S0: 1.8V
      • R6402: 1V
      • R6405: 1V
      • R6403: 1V
      • AUD_SPKRAMP_RESET_L: 1.3V
      • PPBUS: 12.6V
      03-10-2025, 11:22 AM
    • Cemal Odabasioglu
      MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
      by Cemal Odabasioglu
      I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
      Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
      Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
      Observations...
      01-14-2025, 03:54 PM
