Acer Not Powering la-k701p
    Hi goodday to all , Im having a quite issue, if the PU301 si need replacing because I dont have any parts avalble, and needed it to be ordered overseas.
    Unit wont power, no water damage and corrosion, unit was not used for almost a year (customer said)
    BOARD: GH5JJ/GH7JJ LA-K701P REC:1C 2021-01-08
    MAINPWON 3.3v goes 1.2v every 5 sec
    PU301 READING
    1.BST- 3V
    2,3,4,5 - +19VB_3V- 19V
    6. LX_3V - 0V-
    7,8 - GND
    9. SPOK_3V
    10. NC
    11. ENLDO_3V - 4.4V STABLE
    12.3V_EN -0V
    13. 3V_FB - 0V
    14.+3VALWP- 0V- not shorted kilo ohms reading 4k
    15.NC-
    16,17. +3VLPP- 3.3V
    18.GND
    19,20- LX_3V- 0V
    +3VLP 3.3V STABLE
    EC_ON
    3.3V STABLE
    5V_3V_EN 3.3V
    PCH_DPWROK 0V
    +RTCVCC 3.1 V no cmos connected
    3V_EN_R 0v RB16 1k ohms reading resistor ok not shorted on both sides
    ON/OFFBTN# 3.3v if pressed goes 0v and back to 3.3v
    Link to schematic -> https://www.badcaps.net/forum/troubl...c-or-boardview
    Re: Acer Not Powering la-k701p
    Power cycling of the enable is EC not getting a power good from PU301 (or something further down in the power sequence).
    Check the boost and feedback circuits first before blaming the IC.
      Which feedback circuit sir? sorry for bad english
        Placed a year of machine, it is recommended that the replacing PL302 inductance
          PC302, PC315, PR306 etc. I could count on one hand the number of inductors I've had fail.
            Hi sir this is what I got
            RESISTANCE TO GROUND READINGS
            PC302- 2.6Mohms pin 2 to ground
            PC305 - non stuff ( not present on board)
            PL302 - 3.9k to ground
            RB16- 1K value ok
            RB17- 1MK ok
            PC315- 4.0Momhs
            PR303- 150K ok
              DB1,pin1 MAINPWON present??
                DB1
                PIN1 - 3.3V stable sir
                Thank You for checking by sir
                  Remove RB16 & RB17 and DB1. Jumper DB1 between both pads. Hope you will have a working machine back.
                    Thanks sir Ill try and update
                      Thank You sir , Unit now is fully working at no issue at all, my I ask why do I need to remove those resistor and diode? please illaborate it to me , thanks
                        Glad to know that. Have a look at the schematic and answer lies there. We've just bypassed "thermal protection". Common issue on many acer models-Whatever you do, this protection doesnt go away and i dont know why.
                          So means the unit wont tart becasue of the thermal protection.
                            Yes and this trick will help you on many acer boards with same issue and the solution is same-to bypass thermal protection.
                              Sir update after 2 days unit response became same, no shorted test voltage on the jumper of DB1 it has 3.3v
                                Perhaps a new fault and unrelated to earlier repair. So need to probe from the beginning.
                                  ok sir , 3v and 5v is present as always pwoer button has 3.3v and unit is only consuming 30milliamp and also tried flashing from acer website
                                    Fan just turn and stop and unit goes no power no led indicator present
                                      3V_EN -3.3v
                                      PCH_DPWROK -0v - not shorted
                                      SLP_SUS# - 0v
                                      PCH_PWR_EN -0v
                                      +1.8VALW - 0v
                                      EC_RSMRST# -0v
                                      AC_PRESENT - 0v
                                      SYSON - 0v
                                      +3VLP_EC -3.3v
                                      +3VLP - 3.3v
                                      AC_IN - 3.2v
                                      LID_SW# -3.3v
                                      SUSP# - 0v RST ( resistance to ground ) 10koms
                                      +5VALW -5.1v
                                      PM_SLP_S3# - 0v
                                      PM_SLP_S4# -0v
                                        EC_RSMRST# -0v This is cause of concern. Without RSMRST# present, you cant expect get anything from PCH like PM_SLP_X. Try removing DB2/DB/3/DB4 one by one and see any changes happens or not. However, before RSMRST# 1.05V/1.8V ALW rails should be present.
