Today, I started working on a MacBook Pro A2289 it showed only 5 volts with .345 amps while plugged in. I was able to find a hot spot via thermal camera on the FDMF5808A (U7220) which I believe is some type of CPU monitor chip. Once chip was removed the laptop booted without issue, I do not have a backup chip currently available I had to order one. My question is will utilizing laptop without said chip cause any type of damage?
MacBook Pro A2289 (FDMF5808A) (U7220)
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by Loki_FidoHi ya folks,
I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
I replaced it and the SSD are fine. No more shorts.
But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
Chip marking... -
by SSBDADC234
When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
Testing the chip pins with a multimeter revealed a short circuit inside the chip.
Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software....04-19-2024, 08:51 PM -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
- Loading...
