820-01958 intermittent power on 20v then plugged again 5V 0.24A on 2 USB-C
  • Wachenaggo
    • Jul 2018
    • 66
    • Philippines
    No Water Damage
    Issue
    -5V 0.24A on 2 USB-C sometimes it powers on slow high fan speed and 1% battery.
    -12.3v PPBUS
    no burn or water damage?? something is loosened?
  • mon2
    • 14662
    Re: 820-01958 intermittent power on 20v then plugged again 5V 0.24A on 2 USB-C
    Are you using the official and recommended power adapter? If not, post the full specs of the power adapter.
    Remove all power. Rotate the power adapter head by 180 degrees. Insert into the laptop again. Does it work now?
    Remove all power. Meter in DIODE mode.
    Red meter probe, yes RED to ground.
    Black meter probe to the CC1 line of this type C connector.
    What is the voltage measurement?
    Repeat for the CC2 line diode mode check.
    Post each reading. The CCx lines are used to communicate with the power delivery capable adapter. If the tvs esd diodes are blown, the logic board will be unable to switch to use the 20v power delivery contract.
    • expertreader
      Dell 5520 not booting up - on light comes on momentarily
      by expertreader
      Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
      Hi all, looking for some help to get started on troubleshooting without schematics
      I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
      I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
      • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
      • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
      • i have measured 16.5V available at the capacitor
      10-19-2025, 08:20 PM
    • Shinju
      Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
      by Shinju
      Hey All!
      Long time forum member here with a problematic laptop issue!
      I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
      The laptop would not power on with the new battery installed without the power supply being plugged in.
      When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
      TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
      10-20-2021, 04:58 PM
    • rilley
      MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
      by rilley
      I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
      I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
      My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
      And the resistor L4004 is literally burned.
      From what I see from the schematics, it does not affect any other rails, only the connection to the display...
      07-10-2024, 01:57 AM
    • protocold
      MacBook Pro 15" 2010 820-2850 intermittent charging
      by protocold
      I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
      I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
      when it is not intermittent:
      PPVBAT_G3H_CHGR_R is 12.07v
      when it is intermittent:
      When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
      when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
      data line on the battery...
      07-25-2025, 08:18 PM
    • drscoot
      usbc connector replacement on mobile
      by drscoot
      I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
      The battery is still charging (red led), but no power on.
      I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
      07-13-2025, 02:37 PM
