820-02020 one usb c 5v and one 20V
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hi all,
    i am working on 820-02020 that confusing. this board has no water damage, all clean like new.
    the problem is one usb port get 20v and the other one only 5v.
    i replace the cd3217 related to the 5v and still no 20v to get.
    measurements when get 5V
    - LDO 3.28V
    - both fuse 5V
    - pp1v8_s2 pulsing from 1.8v and 0V
    - ppbus on F5200 pulsing 12.2v to 8.7v
    measurement when get 20v
    - LDO 3.28V
    - both fuses 20V
    - pp1v8_s2 1.79v
    - ppbus on f5200 11.9V
  • mon2
    • Dec 2019
    • 14672
    Re: 820-02020 one usb c 5v and one 20V
    On the usb port that is stuck to 5 volts, flip the power adapter connector by 180 degrees during insertion.
    Does this port now function at 20v ?
    Each usb C port features a CCx communication line. This line is used to negotiate the power delivery contract. It is possible that the esd diode on the CCx line is damaged and halting the proper communication of the power delivery contracts. By flipping the power adapter head, you are exercising the other side of the USB C connector and testing the other CCx line but still validating the same ACE controller.
    Next, remove all power.
    Meter in DIODE mode.
    Red meter probe, yes RED to ground.
    Black meter probe onto CC1 line of the ACE controller stuck at 5 volt.
    What is the reading?
    Repeat for the CC2 line of the same ACE controller.
    Compare the results to the working ACE controller side.
    Suspecting that an ESD event is stopping the 20v power delivery contract due to a damaged esd diode on the CCx line(s).
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      Originally posted by mon2
      Hi @mon2,
      Hi @mon2,
      On the usb port that is stuck to 5 volts, flip the power adapter connector by 180 degrees during insertion. --> still get 5V
      USBC0_CC1 = 6.3M ohm
      USBC0_CC2 = 6.3M ohm
      USBC0_CC1 = 6.0M ohm
      USBC0_CC2 = 6.0M ohm
      • mon2
        • Dec 2019
        • 14672
        These are resistance readings.
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          yes it is resistance reading. if you asking about continuity mode, i checked there is no short on both lines for 5V and 20V as well
          • kingskie
            • Oct 2014
            • 249
            • indonesia
            i try to plug in charger through 20v usb and the macbook turn on but only shows exclamation logo on lcd
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              update:
              tried to dfu mode to connect with apple configurator but nothing happened.
              any suggestion?
              • mon2
                • Dec 2019
                • 14672
                Review this webpage:
                https://support.apple.com/en-us/HT201314#internet
                • kingskie
                  • Oct 2014
                  • 249
                  • indonesia
                  still cannot do recovery mode. i think this macbook can not do dfu mode because M1 macbook must use usb c near lcd to connect but since that usb c is only draw 5v it cannot do dfu mode.
                  • ugamazing
                    820-02918 PPBUS Cycling, Minor Liquid.
                    by ugamazing
                    Working on an 820-02918 board that had a minor liquid spill, but it was directly to the ISL/U5200. Essentially the entire area had to be replaced due to corrosion. Got it all cleaned up and everything looks good and checks out, but we're hitting a cycling PPBUS issue now. PPBUS_AON cycles quickly from ~9v-12v, indefinitely.
                    Knowing this is typically a sign of a possible short on a lower rail, we checked all around and found no obvious damage or shorts. We have VERY LIMITED parts for this model (exactly 1 single U5200 chip), but I suspect it will end up being a continuity issue or...
                    02-18-2025, 11:21 AM
                  • iMuhtaseb
                    820-02098 M1 Pro 14" PPBUS partial short
                    by iMuhtaseb
                    board came with no signs of life whatsoever, taking only 5V.. measured PPBUS and it was partially shorted (I kinda know this is not an easy one when it's a partial short) around 9 ohms in resistance and 0.012 in diode mode.
                    Injected 2 volts since 1v was not enough and my initial suspicion was correct it was the haunted TPS62180.. and on board it looked little discolored to my on the visual inspection..
                    Removed and replaced successfully now left ports take 20V for 2 seconds then switch to 5v and cycle.. on the right side it does not even power on the amp meter.....
                    01-04-2024, 01:53 AM
                  • kjchatman
                    820-02020 a2338 motherboard has a ppbus short to ground
                    by kjchatman
                    this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
                    08-21-2025, 12:13 PM
                  • JM1010
                    Macbook A1707 short on PPBUS - nothing gets hot
                    by JM1010
                    After using a bad charger (cord chewed by dog...) Macbook died.
                    Getting 20V and oscillating 0 and .2amp on amp meter
                    PPBUS is shorted (.8V)
                    After checking resistance with Vcore (ok), injected 1 amp, then 2 finally 3 amp on PPBUS and nothing seems to get hot except the PCH (barely tolerable to the touch at 3amp.)
                    If I can't detect anything getting hot @ 3 amp, what else can I do??
                    Thanks in advance.
                    12-18-2021, 08:31 PM
                  • shlomim412
                    Macbook Pro a2141 820-01700 - short on PPBUS
                    by shlomim412
                    Hello
                    working on a dead a2141 logicboard - 820-01700
                    no power, on usb c ampmeter it's on 5v drawing 0.01a
                    visual inspection under the microscope - board look good, no liquid damage on any kind of damage.
                    ppbus_g3h is 0.3v, and is shorted to ground showing around 50ohms (continuity beep) and climbing..
                    i removed F7000 and F7001 and now getting 12v on PPBAT_G3H..
                    also verified the short is on the system side (pin2 of F7000\1)..
                    i tried to inject voltage, 1v to ppbus_g3h but it's only drawing...
                    07-01-2023, 04:09 AM
