Macbook A2338 820-02020 No Image
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste.
    I have a Macbook A2338 820-02020 with No Image and No Backlight.
    The device came in with a liquid spill at the Display Connector. The Macbook was on (tested with an external display).
    Cleaned the Board for any corrosion and Reballed UP7800.
    Post that we have backlight on the screen but still no Image.
    One weird thing is that even if we disconnect the Screen and connect it to an external video we still dont get the password screen - it shows a blank screen with wallpaper ( like it does when the screen is connected).
    The charging connector on the board JF600 is also burned out so only 1 charging port works.
    Any help ?
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • dicky96
    HP Elitebook Screen blank - backlights but no image
    by dicky96
    Hi guys
    I'm trying to fix this laptop screen
    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
    OK so I have the original screen which works but has lines across the bottom quarter of the screen
    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
    04-28-2021, 07:30 AM
  • MagJ_
    MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
    by MagJ_
    Hello Everybody,
    I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
    10-09-2024, 02:51 PM
  • sofles
    Macbook Pro 16" A2141 screen artefacts, kernel panic
    by sofles
    Hi there.
    I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
    I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
    Now situation looks like this, If...
    02-05-2025, 05:05 AM
