RZ09-01953 no power
  • 08caine15
    • Aug 2020
    • 20
    • Philippines
    RZ09-01953 no power
    Hello . Those anyone have schematics for this or atleast is there anyone who can help me with this board "RZ09-01953"
    It has 20v on MOSFET but no voltage on 4pins
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: RZ09-01953 no power
    You mean you have 20V on drain of 1st mosfet but no voltage on Gate/Source of same mosfet?? If yes
    01.Check resistance between pin1-4/pin4-8/pin1-8 of the 2 dc in mosfets. Meter should be in 200K or higher scale.
    02.Which charging IC is used here??
    03.Resistance on CLR ??
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Thomas Smith
      Asus Tuf gaming fx506l no power, mosfet does not open
      by Thomas Smith
      Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
      Initial Symptoms:
      • The laptop has no power at all (no LEDs, no fan spin).
      • No 3.3V or 5V present on the board.
      • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
      Power Rail Checks:
      1. Charger input (FETs PKCH2BB)
        • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
      2. BQ24780S Charger IC:
        • VCC and ACDET are present.
        • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
        • Shunt resistor has 10Ω to ground.
      03-30-2025, 03:38 AM
      03-31-2024, 02:12 PM
