Bad battery or bad motherboard? HP 14-dq1043cl
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Trying to determine if the motherboard is at fault or we can just replace the battery.
    Issue is it works fine when plugged in but as soon as it's unplugged it goes dead and will not power on unless plugged in. In Windows it says 0% not charging.
    Ran HP diagnostics and the result is in the attached picture but also here, perhaps so others with this error can find this thread.
    Battery Check: Primary - Replace (49),
    Primary: Logic State - Not Available (49), Charge State - Not Available.
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Bad battery or bad motherboard? HP 14-dq1043cl
    hard to say without you trying the battery in another unit or replacing with a new one
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Yeah, I guess so. Ordered one for $23, will update when it arrives.
      • Shinju
        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
        by Shinju
        Hey All!
        Long time forum member here with a problematic laptop issue!
        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
        The laptop would not power on with the new battery installed without the power supply being plugged in.
        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
        10-20-2021, 04:58 PM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
      • cope
        Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
        by cope
        I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
        Some history:
        Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
        As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
        Now, with a new battery the system will start up and run off...
        05-13-2024, 09:40 AM
      • Thomasraud
        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
        by Thomasraud
        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
        QUOTED
        -It works on charger (without battery connected-only charger)
        -It works on battery (without charger connected-only battery)
        -& it also works when plugged in battery & charger, but it's not charging the battery
        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
        and..
        QUOTE
        The IC cannot maintain the input current level
        06-28-2022, 06:47 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
