820-02020 No backlight 0,8v on BKLT_EN_R
  • hassie2001@gmail.com
    • Aug 2020
    • 12
    • Neteherlands
    I have no backlight on my screen, tested with 2 different known working screens. Logicboard is perfect clean no traces of liquid only on pin 17 en 18 of UP800. Got chip off and saw that pin 18 was corroded bad. Cleaned it and replaced UP800 with one from 820-01598 (according to PDF, same model) Chip should get 5v.
    Diode mode readings are ok except for pin 17 and 4
    Pin 17 (BKLT_EN_R) is 0.187 should be 0.374 and give 0,82v
    Pin 4 (LCDBKLT_FET_DRV) is 0.422 should be 0.550 (According to PLDaniels database).
    Could it be that UP800 has to be from another a2338 M1 donor. I used one from a a2159 intel based Mac?
    And what else can I check..
  • mon2
    • Dec 2019
    • 14351
    Re: 820-02020 No backlight 0,8v on BKLT_EN_R
    Check the voltage to ground of IPD_LID_OPEN_1V8.
    There is a hall effect sensor in the trackpad to sense if the lid is open or closed.
    If the trackpad is connected, test without it.
      • Aug 2020
      • 12
      • Neteherlands
      Thank you for the reply, I already checked IPD_LID_OPEN_1V8 As I read many of your posts on this forum! (great job by the way). it is 1.8V
        • Aug 2020
        • 12
        • Neteherlands
        board is out of housing, so no trackpad connected
        https://photos.app.goo.gl/qvWHaGg9jyct71YH9
        • mon2
          • Dec 2019
          • 14351
          Remove carefully RP482.
          Remove all power.
          Meter in DIODE mode.
          Red meter probe, yes red to GROUND.
          Black meter probe to pin #17 (BKLT_EN_R) on UP800.
          What is the reading ?
          Black meter probe to BL_PWR_EN on UP800.
            • Aug 2020
            • 12
            • Neteherlands
            I guess you meant RP842.
            Here are the Diode mode readings
            RP842 pin 1 0.170 (BL_PWR_EN) I'm thinking something here is wrong...
            RP842 pin 2 0.516 (BKLT_EN_R)
            • mon2
              • Dec 2019
              • 14351
              Yup, a resistor is a resistor ☺️
              This seems to imply that the pin driving the enable pin is defective. Do wait for other comments but you can test to see if the driving side is going logic high or not without this 0 ohms series resistor.
              That is, the led driver ic appears to be fine but driver side is with a low diode reading.
              Are 100% sure the tested LCDs are fully compatible with this logic board? The backlight driver will not enable if the display is not detected.
              Does the board boot ok with your OS and you can toggle the caps key led?
                • Aug 2020
                • 12
                • Neteherlands
                The enable signal (BL_PWR_EN) comes directly from u8100, does that mean that u8100 is failing? It produces 0.8v but not enough to logic high (1.2v-1.8v)? There was some corrosion between pin 18 and 17 of UP800 so maybe 5v went to pin 17 and directly to u8100... Can't I just boost the low signal u8100 is giving to 1.8v?
                The board works perfectly on an external display even on internal perfect without backlight! So this is my only dilemma!
                The tested screens are all a2338 Screens from previous repairs. Where working perfectly then. Can't test now, because I don't have another m1 board.
                How can I be sure the screen is detected apart of lid sensor? It came in as "dropped damage" It has a small dent at the bottom case but no visual damage on board...
                Last edited by hassie2001@gmail.com; 02-09-2023, 12:31 PM. Reason: Adding something
                • mon2
                  • Dec 2019
                  • 14351
                  Besides this enable pin, there are:
                  BKLT_SCL
                  BKLT_SDA
                  lines that are used to dial up the backlight intensity.
                  Can you measure the voltage to ground of each of these lines ?
                    • Aug 2020
                    • 12
                    • Neteherlands
                    RP850 (BKLT_SCL) starts with 5.1v as soon as image apears goes to 4.9v, diode mode 0.491
                    RP851 (BKLT_SDA) starts with 5.1v as soon as image apears goes to 4.8v, diode mode 0.491
                    • mon2
                      • Dec 2019
                      • 14351
                      These lines are not stuck. Good.
                      Measure the mosfet pins (source;gate;drain) - voltage to ground of QP800.
                      • mon2
                        • Dec 2019
                        • 14351
                        Based on the assumption that the logic board is able to detect this display, this enable pin should be a logic high. Locate a 3v3 rail and you can feed that voltage directly onto this enable pin to force the enable state. Do this with the 0 ohm resistor off the board as you will be driving the pin directly.
                          • Aug 2020
                          • 12
                          • Neteherlands
                          Source 12v
                          Gate 11,9v
                          Drain 0v
                          No shorts
                          • mon2
                            • Dec 2019
                            • 14351
                            This is a P-channel mosfet so the gate must be lower than the voltage being between source and drain.
                            The gate will be lower if the led backlight circuit creates the pull down on the gate resistor. Then gate will be lower from the created voltage divider.
                            To use the backlight IC, it must be enabled and the I2C must be working.
                              • Aug 2020
                              • 12
                              • Neteherlands
                              Tried but no luck! What I noticed is that
                              “RP851 starts with 5.1v as soon as image apears goes to 4.8v” this is not 4.8v it stays 5.1v.
                              But the scl line still starts with 5.1v and goes to 4.8v. So as I understand there is no good communication…
                              What can I look at more?!?
                                • Aug 2020
                                • 12
                                • Neteherlands
                                Figured out something else! On the small lcd flexcable pin 24 is broken. On the connector on the logicboard I get a good diode measurement (0.507) but when I connect the small lcd flex cable I get a O/L on the other side... So the LCD doesn't get a connection!
                                Tried different Flex cables but when I use another one I don't get image. Is there a difference between the M1 small lcd flex cable and the once before the m1?
                                To bad I only have 1 M1 here, so can't check... Maybe I can try to repair the flex cable?!
                                Could this be the reason why BKLT_EN is low?
                                • radear
                                  • Jul 2021
                                  • 7
                                  • spain
                                  The signal BL_PWR_EN comes from u8100. Have you tryed another screen? reinstall bridgeOs by DFU?
                                  If you take a look on schematic, the signal bl_pwr_en can have max 1,2v an min 0,4v.. so if you having 0,8 you be abble to trigger the enable..
                                  • radear
                                    • Jul 2021
                                    • 7
                                    • spain
                                    • radear
                                      • Jul 2021
                                      • 7
                                      • spain
                                      i tried to upload an imag but i cant
                                        • Aug 2020
                                        • 12
                                        • Neteherlands
                                        Don't think this is correct.
                                        As per schematic, VIH=1.2V; so it comes from 1.8V powered logic.
                                        0.82V is prohibited value, can't be correctly recognized.
                                        0 logic is between 0-0.4V and 1 logic is 1.2-1.8V...
                                        • Timp74
                                          820-02100/02098 LCD Backlight Controller IC UP800..
                                          by Timp74
                                          Hi All.
                                          Does anyone know if Macbooks will power on without their display backlight controller ICs? Explicitly I have an a2485(very similar to a2442) that has the UP800 IC broken/missing. On attaching a USB PD charger it stays at 5v ~1A for 20 seconds and then resets and repeats the cycle.
                                          The history is that the machine was water damaged to IC UP800. A Renesas 209100b1 Buck Boost controller. The machine still worked, but without the display backlight coming on. UP800 wasn't generating any switching signals to the four driver mosfets. I removed UP800 and check the...
                                          11-25-2022, 11:57 AM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • omicronns
                                          Macbook M1 pro 820-02098 no backlight after UP800 (RAA209100B1) replacement
                                          by omicronns
                                          I liquid damaged a Macbook, disassembled it and spotted short near UP800. After desoldering it short was gone so I ordered the chip from https://aliexpress.com/item/1005005500396324.html.
                                          Laptop is turning on, I can see something on the display if I flash strong light at it.
                                          After replacing the chip, there is still no backlight. I measured components near the chip on both sides of the board again but everything seems fine.
                                          Next I measured voltages near the chip, there is 5V, 1.2V, also 2.5V on LUXE_C_VDD (seems like it's internally generated by the chip, since...
                                          02-03-2024, 05:11 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
