Macbook A1534
  • Instafixx
    • Jul 2022
    • 374
    • India
    Macbook A1534
    I have a Macbook A1534 the 12 Inch Version.
    The mac boots up fine till the Login Screen and then as we enter the password, the display shows lines and grids ( like an old television) and then the Machine just hangs and turns off eventually.
    Tried with a known good screen. Same Issue.
  • mon2
    • 14659
    Re: Macbook A1534
    Could be a corrupt OS.
    Try an internet boot to see if it is stable.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Re: Macbook A1534
      You mean Internet Recovery?
      • mon2
        • 14659
        Re: Macbook A1534
        Yes - just to see if the screen shows the graphics without corruption.
        You can also try to boot a known good OS from USB as a test (or using your external hub).
        • Instafixx
          • Jul 2022
          • 374
          • India
          Re: Macbook A1534
          yes - just to see if the screen shows the graphics without corruption.
          You can also try to boot a known good os from usb as a test (or using your external hub).
          nope. The apple logo is fine with the loading bar. But the graphics become weird after some point of time (assuming the internet recovery option came at that time).
          Lemme try and disconnect the display cable and use an external display and see if i can load a new os here.
          Update: Same Issue with the External Display (Internal Display Disconnected). Internet Recovery Starts but after sometime the Graphic goes haywire.
          • mon2
            • 14659
            Re: Macbook A1534
            You have a GPU failure.
            What is the 820-xxxx number of the logic board?
            With no power, meter in resistance mode -> Check the resistance to ground of each coil / inductor.
            This is to confirm that each power rail is not shorted. If the GPU is not powered, this issue will follow.
            • Instafixx
              • Jul 2022
              • 374
              • India
              Re: Macbook A1534
              Unfortunately i could not find the board number written on this tiny board. Can you help me out?
              • Instafixx
                • Jul 2022
                • 374
                • India
                Re: Macbook A1534
                It's 820-00045. All Coils seem fine. You want me to check any specific line ?
                • mon2
                  • 14659
                  Re: Macbook A1534
                  What is the voltage to ground of:
                  PP1V1_S0SW_SSD ?
                  • Instafixx
                    • Jul 2022
                    • 374
                    • India
                    Re: Macbook A1534
                    PP1V1_S0SW_SSD ?
                    Its 1.08V
                    • mon2
                      • 14659
                      Re: Macbook A1534
                      Voltage of PP2V5_S0SW_SSD ?
                      • Instafixx
                        • Jul 2022
                        • 374
                        • India
                        Re: Macbook A1534
                        Its 2.5V
                        • mon2
                          • 14659
                          Re: Macbook A1534
                          Voltage to ground of ALL_SYS_PWRGD ?
                          • Instafixx
                            • Jul 2022
                            • 374
                            • India
                            Re: Macbook A1534
                            Its 3.3V.
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              Re: Macbook A1534
                              Will be CPU-related problem as always on A1534.
                              • Instafixx
                                • Jul 2022
                                • 374
                                • India
                                Re: Macbook A1534
                                Sure? Should we try a CPU Re-Ball ?
