No visdeo ASUS X580
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    No visdeo ASUS X580
    Hi guys, an asus vivobook with X580VD REv2 mainboard arrived in the laboratory and it turns on and I have video on the hdmi output but no on the internal monitor.
    The problem happened after the internal monitor flex cut and shorted out. I changed monitor and gflat and setsso problem, I have nothing on video, I changed bios and same thing. From the diagram I checked and on U4501 I have 3v input but 0v output and on pin 3 I have about 0.14V. On the display connector on pins 26 27 28 I have 3V and on pins 36 37 38 I have 19v, what can I check?
  • mon2
    • Dec 2019
    • 14677
    Re: No visdeo ASUS X580
    What is the voltage to ground at pin #1 of U4501?
    U4501 is an active high load switch so pin #3 has to be a logic '1' (high) to enable.
    The output voltage from this load switch is powering the eDP pins 26..29.
    So the voltage level should be the same at each label with netname of +3VS_LCD.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      on pin 1 have 0,14v and pin 3 is 3,3V
      • mon2
        • Dec 2019
        • 14677
        With care and flux, remove u4501 off the board.
        Then check again if the voltage on pin #3 of u4501 pcb pad remains.
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          yes confirm remains 3v on the pin of the printed circuit
          • dclass-pro
            • Dec 2022
            • 157
            • Italy
            i tried to change u4501 to a new one but the result is the same
            • mon2
              • Dec 2019
              • 14677
              Does this lcd have a touch panel? The same pin is being used for the touch panel interface over USB.
              • dclass-pro
                • Dec 2022
                • 157
                • Italy
                no it doesn't have a touch panel
                • dclass-pro
                  • Dec 2022
                  • 157
                  • Italy
                  but what do you think is the problem? shouldn't pin 3 be high? because from the diagram I see that the chipset manages it...
                  • mon2
                    • Dec 2019
                    • 14677
                    Trying to understand the purpose of U4501.
                    U4501 is a load switch (aka solid state relay / switch) that should enable ONLY when the EN pin is a logic high = '1' = 3v3.
                    Then the input voltage will be passed onto the display panel but you always have 3v3 present on the LCD panel so what is the purpose of this switch?
                    Also, EN is a logic LOW so this switch is OFF.
                    From is this voltage being supplied onto the LCD pins?
                    Remove all power and check the resistance to ground of pin # 3 on U4501.
                    Also, then use DIODE mode on the meter. Remove all power.
                    RED meter probe, yes RED to ground.
                    Black meter probe to pin # 3 of U4501.
                    Correct that the PCH is driving the enable pin of U4501.
                    • dclass-pro
                      • Dec 2022
                      • 157
                      • Italy
                      between pin 3 and ground in diode mode I have 0.590 on the tester
                      • mon2
                        • Dec 2019
                        • 14677
                        So pin 3 is not shorted with this diode reading.
                        • dclass-pro
                          • Dec 2022
                          • 157
                          • Italy
                          exact and therefore what may depend on the fact that I have no video on the internal monitor?
                          • Bartoloni
                            • Jul 2018
                            • 140
                            • Italy
                            OMG, i have the same motherboard and the same issue... destroyed LED panel.. and video output only on HDMI ... i was thinking was the GTX1050 to reflow, but after this nothing changes.. i also noticed an high frequency noise coming from the GPU when LED panel is connected
                              ASUS VivoBook X580 Notebook Pro Specification for Upgrade or Repair
                              This specification for the ASUS VivoBook X580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X580 boardview and X580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS VivoBook X580...
                              09-06-2024, 06:00 AM
                              by momaka
                              03-15-2023, 10:17 PM
                            • keepread
                              Dell monitor PSU vs Dell laptop PSU
                              by keepread
                              Hi there!
                              Someone gave me their old monitor, it's Dell S2715ht.
                              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                              10-30-2025, 04:45 PM
                            • myth77
                              ASUS PG27U MONITOR
                              by myth77
                              First, i dont work on monitors only on laptops and that also for a hobby. So, i received this monitor in the title and it was completely dead, and power supply when used was going off to a power protection. I found that one of the voltage regulators for backlight GS9238 is dead, so i replaced it and monitor is working fine now. But...on the main motherboard first thing i tested was a main power rail and after power jack there is one mosfet Nikos PD537BA. The thing is when i tested all pins of that mosfet are shorted in between. Now when i plug the adapter the monitor just goes on. I dont think...
                              03-19-2024, 08:58 AM
                              ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                              This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                              09-07-2024, 02:50 AM
