macbook 820-00239 a no power bypass ic cd3215c00
  • reset1986
    • Dec 2014
    • 308
    • italia
    hi all I have this mac with a shorted ic cd3215, I unsoldered the short and it went away but it won't turn on with the other usb-c ports,
    some pitches are missing and I wanted to ask if it is possible to switch on excluding the usb c ports managed by the 3215
  • reset1986
    • Dec 2014
    • 308
    • italia
    Re: macbook 820-00239 a no power bypass ic cd3215c00
    any suggestions?thanks
    • mon2
      • 14659
      To power by usb c ports, each cd3215 must be working. Then 20v power delivery contract can be negotiated.
      Alternatively, you could try to power up with a charged battery. That may work.
      • reset1986
        • Dec 2014
        • 308
        • italia
        couldn't i fool smc by making a bridge? the printing of a 3215 cd is damaged, many pads skipped, for the battery then it could not be recharged anyway
        • mon2
          • 14659
          You should first test if a charged battery can run the board. You will have to charge the battery outside this logic board. Otherwise the cd3215 are required to charge the battery.
          • reset1986
            • Dec 2014
            • 308
            • italia
            ok, this battery carries the flat that goes on the motherboard to be activated, with a bench power supply I could try but I don't know if it is then activated
            • Cemal Odabasioglu
              MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
              by Cemal Odabasioglu
              I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
              Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
              Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
              Observations...
              01-14-2025, 03:54 PM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • oxonater
              Apple MacBook Pro A2141 16" IC BYPASS
              by oxonater
              Hi everyone hope all are well
              I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
              I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
              The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
              I suppose it's worth noting googling the part package brings up various...
              10-23-2024, 11:21 PM
            • harounHD
              Macbook a1989 and a2338 icloud bypass
              by harounHD
              Is there a solution for Macbook a1989 and a2338 icloud bypass , i saw a video on youtube of someone using a bootable usb to unlock it
              02-01-2025, 03:23 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
