MBP A1707 2017 RAM issue
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    Short history of this machine...
    Runs on Catalina, customer wants to upgrade to BigSur. Crash and not possible to install no matter which OS.
    Reinstalled a TimeMachine backup from Catalina on an empty SSD. Succes.
    Worked well, customer doesn't do heavy tasks. A few years later, he had to upgrade to Monterey, same problem.
    I did the same (install a TM backup), but once booted in OS machine does weird things, but is operative.
    Let run Memtest en gives a RAM error. Look on thumbnail
    https://www.badcaps.net/forum/images/attach/jpg.gif
    During the whole test one thing repeats: only when testing reaches 14GB-15GB errors are generated.
    In the error list, "failing adress" displays always (14.5GB).
    Is there a way to determine which RAM chip gives me the issue?
    tnx
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MBP A1707 2017 RAM issue
    Only 4 RAM chips on this board, shouldn't be a problem to replace them all at once.
    However in this screenshot only the 62nd data bit is failing so that narrows it down to only 2 ICs on 2 different channels.
    Finding which channel it is is very difficult (if not impossible) because the addressing is pretty complex and documentation about physical addressing with Intel memory controllers is not publicly available.
    There is some reverse-engineered documentation but unfortunately it doesn't cover all situations and it could contain some mistakes. (e.g. https://cdn.badcaps-static.com/pdfs/...5e7875c4f4.pdf "DRAMA: Exploiting DRAM Addressing for Cross-CPU Attacks")
    Btw Memtest86+ is a great open-source tool, but I'd recommend also confirming with the proprietary Memtest86. Apple has a bunch of quirks in their EFI implementation and the proprietary Memtest86 has several workarounds for that.
    • Beeldbuisje
      • Jul 2020
      • 57
      • Belgium
      I don't have BGA rework tools by myself. But I have a donor board with 99% for sure good Ram chips.
      I spoke to my friend with all the necessary BGA rework tools. He told me it's easier to replace the 4 chips at once as one by one, testing,... etc.
      When it's almost impossible to determine which chip is defective, I'll change them all.
      PS: thanks for the documentation provided!
      • sofles
        Macbook a1707 2017 model 820-00928 GPU issue
        by sofles
        Hello there
        I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
        I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
        11-21-2024, 05:25 AM
      • CG_Dionysos
        MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
        by CG_Dionysos
        I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
        • Model: A1707
        • 15-inch, Mid 2017
        • 3.1 GHz Core i7
        • 16 GB RAM
        • Radeon Pro 560
        • 1 TB SSD
        • Board number: 820-00928-A
        I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
        Thanks in advance!
        Greetings from Germany...
        09-16-2025, 06:43 AM
      • janoszw
        MacBook Pro A1707 Graphics issue.
        by janoszw
        Hi, I'm having a problem with my MacBook Pro A1707.
        There are graphics glitches all over the screen.
        I took a screenshot, so it's not a screen issue, but either the graphics card or VRAM chips.
        Has anyone had this issue before? I don't want to replace unnecessary components.
        The system is otherwise quite stable, it's just a visual problem.
        Thanks....
        03-31-2024, 04:18 PM
      • Stephen
        MacBook Pro 15" 2017 A1707 USB C MAJOR ISSUE
        by Stephen
        Device powers on and charges etc. Heres the deal, swapped out the USB C ports because it was not charging, charges now, but now the USB C ports kill my external devices (USB EXTERNAL THUMBDRIVES) . so far it killed three thumbdrives. Again macbook operates normally and charges, but I cannot connect any external devices to the ports until I figure out what is causing this issue. Remember I swapped out multiple USB C ports and they all are causing the same issue, even with . new ones. So if there needs to be a logic board repair can someone point me to the right direction?
        08-17-2021, 01:54 PM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
