Problem with charge Lenovo LA-H131
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Hi guys I have this Lenovo notebook that is driving me crazy:
    The customer says he goes into office but when the battery is downloaded all no longer, it has been for the day that we have in Test in the laboratory, I changed 2 new IC Charge batteries and the KBC (I reprogrammed it) and lplying it with a Banch power supply giving 20v to the laptop, start loading, then goes into stop, then after 5 sec. Start again, then stop and then start again and always load.
    I cotnrolled the 2 4K resistances on acin and are ok, what do you recommend?
  • mon2
    • 14673
    Re: Problem with charge Lenovo LA-H131
    Does the laptop work with the adapter?
    What is the voltage on the gate pins of the DCin mosfets? Should be ~25v.
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      on pin 30 of the charger I have 25v as soon as I connect the power supply, after 2sec I have 20/21V
      • mon2
        • 14673
        Often the fault is in the first 2*DCin mosfets.
        Remove all power. Meter in resistance mode.
        Measure the resistance across each of the DCin mosfets.
        So check:
        Source (1-2-3) & drain (5-6-7-8)
        Source (1-2-3) & gate (4)
        Gate (4) & drain (5-6-7-8)
        Post each measurement.
        Start with the 2nd DCin mosfet. Often it gets killed first and needs to be replaced.
        Since the board works when you bridge the first mosfet, sounds like the 2nd mosfet is leaking.
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          PQ712
          Source (1-2-3) & drain (5-6-7-8) 1Mhom
          Source (1-2-3) & gate (4) 1.7 Mhom
          Gate (4) & drain (5-6-7-8) 10Mhom
          PQ740
          Source (1-2-3) & drain (5-6-7-8) 3.4Mhom
          Source (1-2-3) & gate (4) 5.5 Mhom
          Gate (4) & drain (5-6-7-8) 8Mhom
          • mon2
            • 14673
            Mosfets look to be ok.
            What is the voltage to ground of ACOK pin #2 on PU703 (charger IC) ?
            • dclass-pro
              • Dec 2022
              • 157
              • Italy
              3,2v
              • mon2
                • 14673
                The adapter is the proper one to power this laptop ? ACOK is at a good status.
                Confirm that resistor PR763 is present and its resistance matches the schematic @ ~4k ohms. No power power in resistance checks.
                As a test, remove PQ707 2N7002 mosfet. Power up again and check the voltage on pin #30 of the charger IC.
                • dclass-pro
                  • Dec 2022
                  • 157
                  • Italy
                  then guys i figured out the problem describing the customer and it really occurs:
                  If I unplug the battery for 15 sec, when I plug it back in and plug in the power supply, it never charges... NEVER... but that only happens the first time... if I then remove and plug in the power supply then it resumes charging work well. That's why the customer tells me that when it's totally flat the battery doesn't work anymore, it's a really strange problem
                  • dclass-pro
                    • Dec 2022
                    • 157
                    • Italy
                    Now that I can have the problem checked, when it doesn't charge on pin 30 of the charger I always have a fixed 25V
                    • dclass-pro
                      • Dec 2022
                      • 157
                      • Italy
                      If I remove PQ707 have always 25V on pin 30
                      • mon2
                        • 14673
                        Apply the 4k resistor on the gate pins back and test again without the 2n7002 you removed. Leave it off the board.
                        • agswireless
                          Lenovo Y50-70 (LA-B11P) no charge problem
                          by agswireless
                          ok so I have this Lenovo y50-70 touch that has a no charge problem, maybe someone can point me in the right Direction since I cannot find a schematic for Borderview
                          what are you guys opinion on where to start to check why its not charging?
                          Back story:
                          I bought this with a bad charging port, previous owner stated it charge fine but his kid kicked the cord and rip the plug and port out.
                          so I ordered a new one, but when I was replacing the plug the open wire touch and made a spark because I completely forgot to unplug the battery.
                          so I went a head changed out...
                          01-30-2024, 01:39 AM
                        • ravi_1617
                          Lenovo B540 ,Starting Problem
                          by ravi_1617
                          Hello !
                          Model Lenovo B540
                          Board Details 09244-1
                          LA14 DIS MB
                          48.4DMO4.01.1
                          This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
                          when connected CMOS dont start.
                          3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
                          One more thing i want to mention ( by mistake i started at...
                          10-14-2025, 02:08 AM
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • s_specialist
                          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                          by s_specialist
                          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                          07-07-2025, 11:47 AM
                        • perzyk23
                          Lenovo T580 - LCD Panel problem - error 0288
                          by perzyk23
                          Good morning,
                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                          10-25-2024, 12:42 AM
