Where is BIOS Chip on Thinkpad Gen1 P4 - Model 20Y4S04W00
  • samstown
    • Mar 2021
    • 122
    • Switzerland
    I see two Gigadevice chip on motherboard but I am not sure if that could be the BIOS ROM.
    Sam
  • samstown
    • Mar 2021
    • 122
    • Switzerland
    Re: Where is BIOS Chip on Thinkpad Gen1 P4 - Model 20Y4S04W00
    Ok, I think found it.
    Winbond 25Q16JWNIQ.
    Following an update Laptop stopped booting. It start with black screen then stops, I guess it's BIOS issue.
    • mon2
      • Dec 2019
      • 14662
      This flash chip is too low density to be the main bios chip.
      Perhaps the bios chip for the local EC controller or wifi / ethernet interface.
      The larger Gigadevice chips are probably the main bios flash ICs.
      • samstown
        • Mar 2021
        • 122
        • Switzerland
        And attached is what I read from the chip.Now I need to find another BIOS and try to flash it.
        • samstown
          • Mar 2021
          • 122
          • Switzerland
          Thank you. OK, then it will be more complicated to read.
          • samstown
            • Mar 2021
            • 122
            • Switzerland
            You read those with Pomona SOIC-Clip ? I 've tried a couple of time.. no communication. I have the chip in my reader DB so setup should be ok.
            • mon2
              • Dec 2019
              • 14662
              No, the pomona clips (most are clones) are useless for this package.
              From memory, believe this is the WSON-8 package. Please search for the datasheet for the device to confirm.
              Then, you will need a flash memory breakout / dip conversion board. There is someone in the UK that sells a PCB to support this package but China has clones that should be also ok. In a nutshell, you want to hot air off this flash device -> solder onto another PCB that should offer a DIP (through hole pins) conversion. Then you can R/W/E the flash device.
              Be sure to review all details before purchasing / proceeding. This and other forums should mention the full details of this bios device.
              • samstown
                • Mar 2021
                • 122
                • Switzerland
                Thank you for the details then I will give up. The PC still under warranty, customer should return it to Lenovo if there is no other option than heat gun to flash it.
                • mon2
                  • Dec 2019
                  • 14662
                  This is the guy with assorted tools. The PCB to DIP is a very simple design but not too many boards out there - Aliexpress has a few.
                  https://www.cmizapper.com/index.html
                  Something like this but is from a quick search (not 100% sure if your package is the same size - there are many variations in the marketplace):
                  https://www.aliexpress.com/item/1005...d=0oXdO1X2cs4u
                  The real pain is that the zero force sockets are $$$ for the real deal. These are hacked sockets but can work for low volume. I recall having chats with a zero force socket manufacturer and in high volume, they wanted ~$40 USD each. The investment for just the socket MOQ would be more than my car. No thanks.
                  • samstown
                    • Mar 2021
                    • 122
                    • Switzerland
                    Thank you. I'll see if I can get one of those for test.
                    • DynaxSC
                      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                      by DynaxSC
                      Hi
                      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                      08-04-2025, 12:20 PM
                      by SMDFlea
                      Bad...
                      09-02-2021, 04:40 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
                    • BMCappelletti
                      Asus Chromebox CN62 - wrong chip put on BIOS reader
                      by BMCappelletti
                      Long story short:
                      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                      - gave the computer to his son a couple years later
                      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                      (seems like the story was not that short)
                      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                      01-08-2025, 07:27 PM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
